16
I've got an app which uses MVC, but I'm struggling a little as to how the controller should be architected. For example, the View is only viewing some subset of the model's data at once. However, I'm unsure as to exactly how this should be arranged. Is it normal for the View or Model to directly call functions on the Controller, for example? Through some sort of interface? Or are they totally encapsulated and never know about the Controller or each other?
Just as an edit; this is a custom app not written in any web framework, so I'm not looking for framework-specific details here and have the freedom to make my own choice.
DeadMG
  • 36,794
  • 70
  • 139
    I won't answer because my experience is limited in MVC architectures, but from all I've heard and talked to others about, the M&V are tightly coupled to each other but not the C. The M generally calls functions on the C and the V often only databinds to some subset of the M. – Steven Evers May 12 '12 at 20:13
    @SnOrfus: That's exactly opposite to what I thought- the M & V are coupled to the C but not to each other. – DeadMG May 12 '12 at 21:43
    How can so many answers be so wrong. Here read MS's version http://msdn.microsoft.com/en-us/library/ff649643.aspx – Reactgular May 13 '12 at 15:56
  • Give this article a read: http://www.objectmentor.com/resources/articles/taskmast.pdf – Edward Strange May 13 '12 at 19:56
7 Answers7
15
The controller controls the flow of activity. The user performs this action, the controller passes the view data to the domain which does whatever it needs to do then, based on the response(s), the controller tells the framework which view to show next (and gives it enough data to do so).
The controller must thus be coupled to the domain model, to some extent. ie. You could put a service layer in between but, by strict definition, that becomes part of the domain.
It is also coupled to the view data but not the view itself. ie. it simply says "show the customer view using this customer detail." The framework then decides where it should find that view.
Now this should allow you to decouple the domain model from the view, by using a view model of the same data. Some developers do this, some don't, and I do think it's largely a matter of personal preference.
In Rails, you are very much encouraged to push the domain objects (ActiveRecord) to the view and trust that the view doesn't take advantage of that access (eg. you shouldn't call customer.save from the view, even though it would be available).
In the .NET world, we tend to reduce risk by not allowing things that shouldn't happen and, possibly for that reason, it seems to me that the detached view model is more popular.
pdr
  • 53,387
  • 137
  • 224
    View model is a very common practice when it comes to unit testing. You would normally auto map domain model or a DTO object to a view model. You would then use your view model in a view. View model is easily testable and it's not tied to a layer below. – CodeART May 13 '12 at 16:16
Note: Robert C. Martin (aka Uncle Bob) explains this in a much better and humorous way in his keynote, Architecture the Lost Years. A bit long but teaches lots of good concepts.
tl;dr: Don't think and plan your app in terms of MVC. The MVC framework is just an implementation detail.
The most confusing thing about MVC is, developers tries to use all the components glued together.
Try thinking in the terms of a program, not in the terms of the framework.
Your program has a purpose. It takes some data, does things with data, and returns some data.
That way, the controller is the delivery mechanism of your program.
  1. A user sends a request to your program (let's say, add a product to the shopping cart).
  2. The controller takes that request (product info and user info), it calls the necessary part of your program that will handle this request $user->addToCart($product)
  3. Your program (addToCart function of the user object in this case) does the work it's intended to do and returns a response (let's say success)
  4. The controller prepares the response using the relevant view: eg. in the controller object $this->render($cartView('success')
This way, the controllers are decoupled from the program, and used as delivery mechanism. They don't know how your program works, they just know which part of the program need to be called for the requests.
If you want to use another framework, your app won't need a change, you will just need to write relevant controllers to call your program for requests.
Or if you want to make a desktop version, your app will stay the same, you will just need to prepare a delivery mechanism.
And the Model. Think of it as a persistence mechanism.
In the OO way, there are objects in your program that holds the data.
class User {
    private $id;
    private $shoppingCart;
class Product {
    private $id;
When you add a product to the shopping cart, you can add the the product::id to the user::shoppingCart.
And when you want to persist the data, you can use the model part of the framework, which generally consist using an ORM, to map the classes to the database tables.
If you want to change the ORM you use, your program will stay the same, only the mapping information will change. Or if you want to avoid the databases all together, you can just write the data to plain text files, and your app will stay the same.
So, write your program first. If you programming with the 'OO' way, use plain old objects of the language. Don't think in terms of MVC at first.
Hakan Deryal
  • 1,403
  • Great video. Thanks. I would disagree with your interpretation of it though. MVC isn't a detail in the meaning that Uncle Bob has there. You'll note that MVC is an architectural pattern much like his "Interactor/Entity/Boundary" pattern he's establishing. On the other hand, any particular MVC system, such as Spring or whatever, is indeed something he's recommending to defer. As he explains though, these frameworks being called "MVC" is sort of a bastardization of the term. – Edward Strange May 13 '12 at 19:16
  • Yea, I wrote that in the way that people think what a `MVC` is. That's why I wrote `MVC Framework`. – Hakan Deryal May 13 '12 at 19:45
Martin Fowler does a good job of describing the MVC paradigm. Here is a link to his article on it http://martinfowler.com/eaaDev/uiArchs.html
Note his quote about Separated Presentation "The idea behind Separated Presentation is to make a clear division between domain objects that model our perception of the real world, and presentation objects that are the GUI elements we see on the screen."
Johnnie
  • 1,123
Here is a simple example of how MVC can be used in a typical Java Swing application ...
Let's say you have a Panel containing a Button and a TextField. When the Button is pressed, an event is fired, leading to some state change in the application. Once the state change is registered, the TextField becomes disabled.
This, then, would be the typical approach taken by a simple MVC application ...
The Controller registers itself as the listener of the View's events. When the Button is clicked, the View itself does not handle the event; the Controller does. The Controller is Swing specific as it must deal with Swing related events.
The Controller receives this notification and must decide who must handle it (The View or the Model). Since this event will change the state of the application, it decides to forward the information to the Model who is responsible for data and program logic. Some make the mistake of placing program logic in the Controller but in OOP, Models represent both data AND behavior. Read Martin Fowler on his take of this.
The message is received by the Model in the proper context. That is, it is completely void of any reference to Swing or any other GUI specific references. This message speaks to the Model and ONLY the model. If you find yourself importing javax.swing statements in the Model, you are not coding the Model correctly.
The Model then sets its state to 'disabled' and proceeds to notify any interested parties of this model change. The View, being interested in this event has already registered itself as an Observer of any model changes. Once the Model state change event is picked up by the View, it proceeds to disable its TextField. It is also legal for the View to get Read-Only information directly from its Model without having to go through the Controller (usually through a specific interface exposed by the Model for such activity)
By promoting such loose coupling between the Presentation and Business Logic and Data Layers, you will find your code is much more maintainable. As systems grow, so too will your approach to MVC. For example, Hierarchical MVC is an extension often used to link MVC triads together to form large enterprise wide systems without coupling subsystems together
Constantin
  • 545
Coupling (the sort you want to avoid) involves a mutual dependency between two classes. That is, a Foo depends on a Bar and a Bar depends on a Foo so that you can't really modify one without modifying the other. That's a bad thing.
You can't really avoid having SOME dependencies, however. Classes have to know a little bit about one another, otherwise they'd never communicate.
In the MVC pattern, the Controller controls communication between the domain Model and the presentation View. As such, the Controller must know enough about the Model to ask it to do what it's supposed to do. The Controller must also know enough about the View to be able to present it to the client or users. So, the Model Controller has dependencies on both. However, the View can exist perfectly well without the Controller--there is no dependency there. Likewise the Model has no depencies on the controller--it simply is what it is. Finally, the Model and View are completely separate from one another.
Essentially, the Controller is the level of indirection that decouples the View from the Model, so that they do not have to know about one another.
Matthew Flynn
  • 13,345
  • 38
  • 57
-5
In my experience, generally the model only depends on a view, not a specific one, often as an observer...if it has any such coupling at all.
The view generally couples to whatever it's looking at, which makes sense. Hard to come up with a view that could be decoupled from what it's viewing...but sometimes you can have a partial coupling or something.
The controller often tends to couple to both. This also makes some sense since it's job is to turn view events into model changes.
Of course, this is only a tendency I've observed and doesn't really say anything about any specific example.
To understand what MVC is and what the coupling relationship tends to be you should look into how MVC came to be. The environment in which MVC was created was one in which "widgets" as form elements you can build dialogs with did not exist. A "view" was a box and it drew stuff. A text view would be a box that would draw text. A list view was a box that would draw a list. The "controller" received all mouse and keyboard events from the UI system that took place in that view; there were no "textChanged" or "selectionChanged" events. The controller would take all these low level events and generate interaction with the model. The model, upon being changed would notify its views; we have since come to see this relationship as "observer" and it's used in other ways as its own pattern.
THAT is the essence of the MVC pattern. Since this kind of low-level UI programming is generally not done anymore, the MVC has evolved in many different directions. Some things that go by that name today are hardly anything at all like the MVC and should really be called something else. It can still be used though in the sense of a dialog as a whole interacting with a larger object. There's many better alternatives though.
Basically, everything the MVC was meant to solve happens inside of widgets now and is something we no longer have to use.
For those that think they know better:
http://www.codeproject.com/Articles/42830/Model-View-Controller-Model-View-Presenter-and-Mod
I'm sure there are more but those are just the top of the list in google. As you can see, the model very much depends on a view interface in MANY implementations. Generally a model is observable and the view is an observer.
But why let facts get in the way...
An article already posted in another answer also supports my statements:
If people want to continue saying that EVERYONE in the design industry is wrong then that's fine.
Edward Strange
  • 9,172
    This is plainly wrong. A model mustn't depend on a view ever! Even if that view is abstract or an interface. A model ought to be fully decoupled from the presentation! – Falcon May 13 '12 at 08:18
    Answer is wrong. Model does not depend on a view or controller. – CodeART May 13 '12 at 15:35
    My apologies. That was my bad. I didn't read the word "not" in your comment. I've +1 the comment. Sorry. – Reactgular May 13 '12 at 16:02
  • @Falcon - I've cited my answer. Can you say the same? – Edward Strange May 13 '12 at 17:44
  • @CodeWorks - I've cited my answer. Can you say the same? Oh wait, you guys didn't actually provide ANY answer. – Edward Strange May 13 '12 at 17:44
    @Crazy Eddie You said: "In my experience, generally the model only depends on a view, not a specific one, often as an observer" Your cited reference says: "However, the model depends on neither the view nor the controller." Have you even read the cited article? Doesn't look like it. – CodeART May 13 '12 at 18:32
  • @CodeWorks - there's something wrong with your brain: "public abstract class Model { private readonly ICollection Views = new Collection(); " - "Now we know that the Model acts as a Subject from the Observer pattern and the View takes on the role of the Observer object." <- I honestly don't know how it could be made clearer for you. – Edward Strange May 13 '12 at 18:57
  • @Crazy Eddie I guess you still haven't read the article that you've cited. – CodeART May 13 '12 at 19:10
    @Crazy Eddie: I don't care what someone on crappy codeproject writes. This is a horrible design. Using an observer to listen for changes is ok, but putting a presentation interface in a domain model is oh so wrong. The cited code from the article is flawed in some fundamental ways in regard to MVC. It even lets the model implicitly depend on the controller. What a crap. – Falcon May 13 '12 at 19:11
  • "I don't care what someone on crappy codeproject writes." So why did you cite the articles? :D – CodeART May 13 '12 at 19:12
  • @CodeWorks: Are you talking with me? I just meant I don't care if someone on codeproject claims to have the right interpretation of MVC in general. I would not use such a design. – Falcon May 13 '12 at 19:16
  • @Crazy Eddie: "generally the model only depends on a view" Most people probably stop reading after this sentence. For a reason. Because this design violates common layer architectures. A view must not ever be incorporated in a domain model - unless your domain is about views as a domain type. This sentence is like putting a MessageBox in domain logic or device drivers. – Falcon May 13 '12 at 19:17
    The simple, plain truth is that you guys don't know what you're talking about. The absolutely most common MVC (and the original) implemented an obverver/observed relation between the model and view. Concrete views implement an interface that the model uses to notify them that there are changes. There are two approaches then used: push -> model pushes changes to the view; and pull -> view requests information from the model. If you want to say it's "bad" then be my guest. It's certainly overused. What it is though, is what it is and that's what I described. – Edward Strange May 13 '12 at 19:28
    @Crazy Eddie: lol @ downvote rampage. Did I enrage you? – Falcon May 13 '12 at 19:36
  • Hello everyone! This lovely exchange stops here, comments aren't suitable for extended discussions, and this one has taken a quite unproductive turn. Already deleted some of the comments, don't make me come back (got better things to do, you know). – yannis May 13 '12 at 19:44
    I'm not sure why this was down-voted so much. The answer may not be worded very well, but it is correct. – Cypher May 10 '13 at 01:41
-7
  • Controller dispatches model to a view and it processes submitted model from the views, however it is not tightly coupled to a view or a model.
If controller was tightly coupled to a view, then we'll be in a world of web forms. You'd have a code behind which would be tied to a template file (Applicable to ASP.NET web forms)
Because of this, controller is not coupled to a model or a view. It's just a mechanism for processing requests and sending responses.
  • View is tightly coupled to a model. Make changes to your model (e.g. change its property) and you'll have to make changes to your view.
  • Model is not tightly coupled to a view. Make changes to a view, and it'll have no affect on a model.
  • Model doesn't know anything about controller or views where it may be used. Therefore model is not tightly coupled to a view or controller.
Another way to think about this:
  • Make changes to a controller - view and model will be unaffected
  • Make changes to a model - view will break as it relies on a model
  • Make changes to a view - model and controller will be unaffected
This loose coupling in MVC projects is what makes them easy to unit test.
CodeART
  • 3,992
