45
Possible Duplicate:
Why are interfaces useful?
Like most faculty, my java faculty introduced interface without explaining or even mentioning its practical use. Now I imagine interfaces have a very specific use, but can't seem to find the answer.
My question is: a class can directly implement the functions in an interface. eg:
interface IPerson{
    void jump(int);
class Person{
int name;
    void jump(int height){
        //Do something here
What specific difference does
class Person implements IPerson{
    int name;
        //Do something here
? make
Deduplicator
  • 8,591
  • 50
SoWhat
  • 561
    [Why are interfaces useful?](http://programmers.stackexchange.com/questions/108240/why-are-interfaces-useful) – gnat Apr 21 '12 at 12:11
  • It would be less confusing if you named the interface better. I would have called it IJumper. This is the interface that allows things to Jump (as a distinct group which may be larger than the Person group). – Martin York Apr 21 '12 at 16:28
  • Wait, are you asking why the interface must be explicitly declared? It doesn't. Google's Go language uses interfaces with implicit interface (if you have a `void jump(int)` method, then you are an IPerson). Haskell is very strongly typed, but also uses type inference and some very nifty stuff with TypeClasses to handle similar situations. – CodexArcanum Apr 21 '12 at 22:41
10 Answers10
99
It starts with a dog. In particular, a pug.
A pug
The pug has various behaviors:
public class Pug
    private String name;
    public Pug(String n)
        name = n;
    public String getName()
        return name;
    public String bark()
        return "Arf!";
    public boolean hasCurlyTail()
        return true;
Labrador Retriever
And you have a Labrador, who also has a set of behaviors.
public class Lab
    public Lab(String n)
        name = n;
        return name;
        return "Woof!";
        return false;
We can make some pugs and labs:
Pug pug = new Pug("Spot");
Lab lab = new Lab("Fido");
And we can invoke their behaviors:
pug.bark()           -> "Arf!"
lab.bark()           -> "Woof!"
pug.hasCurlyTail()   -> true
lab.hasCurlyTail()   -> false
pug.getName()        -> "Spot"
lab.getName()        -> "Fido"
Two cute dogs in a cage
Let's say I run a dog kennel and I need to keep track of all the dogs I'm housing. I need to store my pugs and labradors in separate arrays:
public class Kennel
    Pug[] pugs = new Pug[10];
    Lab[] labs = new Lab[10];
    public void addPug(Pug p)
    public void addLab(Lab l)
    public void printDogs()
        // Display names of all the dogs
But this is clearly not optimal. If I want to house some poodles, too, I have to change my Kennel definition to add an array of Poodles. In fact, I need a separate array for each kind of dog.
Insight: both pugs and labradors (and poodles) are types of dogs and they have the same set of behaviors. That is, we can say (for the purposes of this example) that all dogs can bark, have a name, and may or may not have a curly tail. We can use an interface to define what all dogs can do, but leave it up to the specific types of dogs to implement those particular behaviors. The interface says "here are the things that all dogs can do" but doesn't say how each behavior is done.
public interface Dog
    public String bark();
    public String getName();
    public boolean hasCurlyTail();
Then I slightly alter the Pug and Lab classes to implement the Dog behaviors. We can say that a Pug is a Dog and a Lab is a Dog.
public class Pug implements Dog
    // the rest is the same as before
public class Lab implements Dog
I can still instantiate Pugs and Labs as I previously did, but now I also get a new way to do it:
Dog d1 = new Pug("Spot");
Dog d2 = new Lab("Fido");
This says that d1 is not only a Dog, it's specifically a Pug. And d2 is also a Dog, specifically a Lab.
We can invoke the behaviors and they work as before:
d1.bark()           -> "Arf!"
d2.bark()           -> "Woof!"
d1.hasCurlyTail()   -> true
d2.hasCurlyTail()   -> false
d1.getName()        -> "Spot"
d2.getName()        -> "Fido"
Here's where all the extra work pays off. The Kennel class becomes much simpler. I need only one array and one addDog method. Both will work with any object that is a dog; that is, objects that implement the Dog interface.
public class Kennel
    Dog[] dogs = new Dog[20];
    public void addDog(Dog d)
Here's how to use it:
 Kennel k = new Kennel();
 k.addDog(d1);
 k.addDog(d2);
 k.printDogs();
The last statement would display:
 Spot
 Fido
An interface give you the ability to specify a set of behaviors that all classes that implement the interface will share in common. Consequently, we can define variables and collections (such as arrays) that don't have to know in advance what kind of specific object they will hold, only that they'll hold objects that implement the interface.
Deduplicator
  • 8,591
  • 50
Barry Brown
  • 4,095
    Great explanation BB :) – Rocklan Apr 23 '12 at 06:12
    This is the best definition out of the top 3. You've really got to the bottom of why it doesn't make sense to avoid implementing an interface. ie classes implementing interfaces can have their objects declared as the interface to pass to methods/ classes. Any other reasons? – dewd Feb 11 '14 at 19:34
  • very nice. helped my lots – Robert Jul 23 '15 at 03:49
  • Thanks a lot Barry, understood the utility of interface for the first time in my life. :) – Sourav301 Dec 25 '15 at 10:12
    In your example Dog is an interface, and Pug/Lab implement Dog, and you say `We can say that a Pug is a Dog and a Lab is a dog.` But no, an interface is not what you "are" it's what you "do". So Dog should have been a base class, because Pug/Lab ARE dogs, rather than being objects that implement dog behaviour. – 404 Feb 09 '16 at 20:20
  • Yep @eurotrash it only starts to make sense when you're dealing with multiple inheritance, or behaviors that defy the class definition. Dogs, Aligators and Bunnies are walkable, but only a dog is a dog. – BeardedO Feb 17 '16 at 22:10
    @eurotrash From a theoretical perspective the only observable properties of a type are its behaviors. An interface is just a special name for a type which has no concrete behaviors. In a language that allows multiple inheritance, an interface is indistinguishable(modulo programming language warts) from a virtually inherited abstract base class, exactly for this reason. – Tim Seguine Feb 26 '18 at 16:55
29
Having an IPerson interface allows you to have multiple implementers (Man, Woman, Employee etc...), but still treat them all through the interface in other classes.
So, in another class you simply state:
void myMethod(IPerson person, Integer howHigh)
   person.jump(howHigh);
You don't have to have a separate method for each implementer.
Deduplicator
  • 8,591
  • 50
Oded
  • 53,326
  • 166
  • 181
    +1, 'nuff said. It'll become clearer once you get to the concept of polymorphism. – suszterpatt Apr 21 '12 at 10:26
    SO you could pass an object of any class as long as it implements the same interface? – SoWhat Apr 21 '12 at 12:00
    @SomeshMukherjee - correct. – Oded Apr 21 '12 at 12:34
    To add to that: Interfaces also provide a degree of information hiding because they limit knowledge of the object to just what the interface defines. If a `Man` and `Woman` have other methods beyond what's in `IPerson`, they're completely invisible to anything referring to the objects using that interface. – Blrfl Apr 21 '12 at 16:08
  • Ironic, this is the tl;dr version of the answer directly above it. +1 to both of you. – Jimmy Hoffa Nov 26 '12 at 17:49
19
Remember, Java is finicky about type.
Let's extend your example a bit and rename the class to Jumpable.
interface Jumpable {
    void jump(int);
class Person extends Mammal implements Jumpable {
    //other stuff
    void jump(int howHigh) {
        //jump method
class Dog extends Mammal implements Jumpable {
    //other stuff
        //jump method
        //also make him bark when he jumps
class Cat extends Mammal implements Jumpable {
    //other stuff
        //jump method
        //make it stretch its legs as well
class FlyingFish extends Fish implements Jumpable {
    //other stuff
        //jump method
        //make it come out of water
class Mantis extends Insect implements Jumpable {
    //other stuff
        //jump method
class Ant extends Insect { //Cannot jump
    //other stuff
class Whale extends Mammal { //Cannot jump (hopefully)
    //other stuff
Note that here we have a variety of classes, organised in some hierarchy. Not all of them can jump, and jump-ability is not universally applicable to any category--each parent class (Animal, Mammal, Insect, Fish).
Lets say we want to hold a jumping competition. Without interfaces, we would have to do something like this:
void competition(
    Person[] pCompetitors,
    Dog[] dCompetitors,
    Cat[] cCompetitors,
    FlyingFish[] fCompetitors,
    Mantis[] mCompetitors
    for(int i=0; i<pCompetitors.length; i++) {
        pCompetitors[i].jump((int)Math.rand() * 10);
    //Do the same for ALL the other arrays.
Here, since there is no "enveloping class" that holds all classes that can jump, we have to invoke them individually. Remember, we cannot just have an Animal[] or Mammal[] array, since the compiler won't allow us to invoke jump(); and not all Animals/Mammals can jump().
Also, this becomes impossible to extend. Lets say you want to add another jumping class.
class Bob extends Animal { //Bob is NOT a human. Bob is something....else....
Now, you have to modify competition(.........) to accept a Bob[] parameter as well. You also have to modify all instances of competition[] to either create their own Bob[]s, or pass empty Bob[] parameters. And it gets icky.
If you used interfaces, your competition method becomes thus:
void competition(Jumpable[] j) {
    for(int i=0; i<j.length; i++) {
        j[i].jump((int)Math.rand() * 10);
This can be extended without any hassle as well.
Basically, interfaces let the compiler know the expected behavior of the object -- what methods/data the compiler can assume exist. That way we can write general programs.
Also you can multiple-inherit interfaces, you can't do that with extends in Java.
Some real-world examples: The first one that comes to mind is the event handlers of AWT. These allow us to pass a method as a parameter and make it an event handler. This will only work if the compiler is certain that the method exists, and thus we use interfaces.
Deduplicator
  • 8,591
  • 50
Manishearth
  • 688
The purpose of an interface is not to relocate or reuse code but more to ensure that some methods that operate on a wide range of types can use these types (which will be passed to them as arguments) in the exact same way even though they may not have common parent classes.
Interface is used to make the contract - the expected functionaity to exist in a certain class.
For example:
interface Transmittable {
     public byte[] toBytes();
class Person implements Transmittable {
     public byte[] toBytes() {
         return this.name.getBytes()
class Animal implements Transmittable {
            return this.typeOfAnimal.getBytes()
class NetworkTransmitter {
     public void transmit(Transmittable object) {
          byte data[] = object.toBytes();
         //do something....
class TestExample {
    public static void main(String args[]) {
           NetworkTransmitter trobj = new NetworkTransmitter();
           trobj.transmit(new Person());
           trobj.transmit(new Animal());
Note that this is not like inheritance where object of one class inherits (or overrides) a method of the same name from the parent. The classes that implement a interface need not be descendant from the same parent class but other classes that want to ensure a contract exists, can call the same methods on objects of all classes that implement the interface. Interface ensures that this contract is available.
Deduplicator
  • 8,591
  • 50
mwallace
  • 2,444
I think all developers can understand your confusion - trying to get your head around the use of interfaces isn't always explained well. I began to really understand the use of interfaces when I started working as a developer on real world projects.
There is a great article at BlackWasp, which explains the use of an interface with a brilliant example - have a read and try it out, it really helped me to understand it better:
http://www.blackwasp.co.uk/Interfaces.aspx
Dalbir Singh
  • 857
Using an interface allows you to cast a number of different classes as a common type, regardless of how the individual classes might be implemented.
Here's a quick and dirty example:
class Puppet : IMovement { ... }
class Vehicle : IMovement { ... }
class Car : Vehicle { ... }
class Bicycle : Vehicle { ... }
class Person : IMovement { ... }
class Child : Person { ... }
class Adult : Person { ... }
As per the example, each of the classes implements the IMovement interface, either directly or indirectly. However, the important thing to note is that any of the classes in the example could be cast as the same common interface type:
((IMovement)puppet).Move()
((IMovement)car).Move()
((IMovement)child).Move()
Interfaces allow you to easily introduce new behaviour to your classes without altering their existing interfaces. Thus an interface allows for polymorphism independent of inheritance. This is very useful when you are trying to handle a number of completely different types of object in a similar manner.
Deduplicator
  • 8,591
  • 50
S.Robins
  • 11,385
  • 52
  • Do you call this a cast in Java? Urgh. It's a _reference_ cast, or base-class-pointer cast as we'd call it in C++. Which does _not_ actually cast the object in the sense that anything changes about its implementation (like when you cast a `float` to `double`), it just creates are more general pointer that can dispatch over the class hierarchy's vtable. IMO quite an important distinction. – leftaroundabout Apr 21 '12 at 23:20
    @leftaroundabout I don't recall calling this a cast in any language in particular. Yes, it's ugly, but the point being made isn't about how to cast, but rather that the interface allows each of the classes represented to be called in the same way. I'm aware that I could have use an "as" operator, or that I could have simply passed each object to a method. As a quick example however ugly, this allows me to make a specific point, in the simplest manner I could think of. – S.Robins Apr 22 '12 at 01:14
There are very interesting use cases of having an interface. Here's one:
Suppose I am creating a OS monitoring system and you tell me what to do after occurrence of a certain event. Say when the disk space is >90% full or cpu usage is very high or when some user has logged in etc. I am still monitoring it, but it's the responsibility of the client code to provide the what happens now functionality.
In my code (that's the OS monitoring system), I will expect you to provide me an Object with certain methods implemented. Say some method like void OnDiskUsageHigh() etc. In my code I'd simply call this method of yours when disk space goes down.
This is a callback mechanism, and without the interface and the defined set of policies between you and me my code won't be able to service a general set of clients.
Here's the interface you should implement (i.e. make a concrete class):
interface Callback {
  void OnDiskUsageHigh();
  void OnCpuUsageHigh();
And you initialize my OSMonitoring class with an object whose class implements Callback as in
new OSMonitoringTool(new ConcreteCallbackClass());
You should read some more about policy/contract based programming.
Deduplicator
  • 8,591
  • 50
Fanatic23
  • 7,533
  • 56
I think your confusion comes down to badly named classes and interfaces in the the example.
Personally I think it would be less confusing if you named the interface better as IJumper. This is the interface that allows things to Jump (as a distinct group which may be larger than the Person group).
If you wanted to stay with the same analogy. I would rename Person to EarthPerson. Then you can have alternative classes that implement the IPerson interface such as MarsPerson, JupitorPerson etc..
All of these different people will be able to Jump but how they jump will depend on how they evolved. Yet your code will work for people from other planets without any modification as you provided a generic interface that works with IPerson rather than a person from an explicit planet.
This also makes it easier to test your code.
If for example the Person object is very expensive to create (it looks up all the details of a person in the Earth Wide DB). When testing you don't want to use a real Person object as the data (take a while to create) and may change over time and break your test. But you can create a TestPerson (which implements the IPerson interface) object (a mock of a Person) and pass that to any interfaces that accept a person and make sure they do the correct thing.
Martin York
  • 11,150
  • 42
  • 70
  • I suppose that is true. I wanted to know what programmatic use of an interface would be – SoWhat Apr 21 '12 at 16:40
    @SomeshMukherjee: It allows you to write your code so that works for **all** people without needing to know what planet they are from. So it de-couples your code from specific implementations thus making it more robust/testable and easier to maintain. – Martin York Apr 21 '12 at 16:43
In addition to the comments of others, interfaces make it easier to do testing since you've clearly defined what the critical parts of the interface should be for any mock/stub classes. TDD should be doing interfaces all over the place.
anon
  • 1,474
There is no need to do so, unless you want to be able to have more than one class providing that behavior.
A good example is the JDBC Connection interface which represents a connection to an SQL database, where you as the programmer can send SQL commands and get the result back. You do not care how the underlying driver talks to the database but you do care that the implementation implements the Connection interface, so you can just use any connection that the DriverManager choose to give you.
