13
If I create this method
public void foo()
And then I create an overloaded version like this
public void foo( string bar )
Do we say that the second functions overloads the first, or are both methods equally "overloaded"?
This would imply (I think), that there is a base type function, that is being overloaded, by another function (somewhat like inheritance, but not really).
Assuming that one method can "overload another", would also imply terms like "overloader" and "overloadie", if that is a word at all. But that doesn't feel right at all, especially since you can have several overloads.
I got to this question when I wanted to write down the process of creating an overloaded method and I wanted the most correct way of writing it down.
Examples:
  • I am overloading foo
  • I am overloading foo with foo( string bar )
  • I am creating an overloaded method
  • I am making foo overloaded
So yeah, this kind of got me thinking, I am not sure what to make of it. There are hundreds, if not thousands, of descriptions of function overloading online, but at a first glance I couldn't find any addressing this.
Null
  • 125
  • I would like to know why the word overload was used for this. It does not seem to make any sense. What is being loaded? How is it loaded again or excessively? – Martin Maat Sep 26 '16 at 20:12
  • @MartinMaat Have you read the [accepted answer by thiton](http://programmers.stackexchange.com/a/145238/121035) and [kindall's comment](http://programmers.stackexchange.com/questions/145231/does-one-method-overload-an-other-or-are-both-methods-overloaded#comment274653_145238) on it? They seem to do a good job of explaining what's being (over)loaded. – 8bittree Sep 27 '16 at 16:34
  • I have read those, they explain the concept, not the ethomology. – Martin Maat Sep 27 '16 at 16:43
When talking about overloads, the name of the function is overloaded, not the function itself. The functions overloading the name are "overloads" and overload the name, but not each other. In your example, "public void foo()" and "public void foo( string bar )" both overload the name "foo". Therefore, you cannot speak in terms of overloader and overloadee of one of the functions, because they have no direct relationship.
In your examples, you can say that you are overloading "foo" (the name) with "foo( string bar )" (the function), but you cannot say that you create an overloaded method, because methods are never overloaded. You can say that you create an overloading method. To formulate "making foo overloaded" is just a worse way of saying "overload foo".
thiton
  • 5,348
  • 26
  • But would then not every function overload its name, even if no other function has the same one? – leftaroundabout Apr 19 '12 at 19:17
  • I agree with this as the answer to the general question above. But if one called one of the functions from the other, then I perceive a sense in which one overloaded the other. – Joshua Drake Apr 19 '12 at 21:00
    @leftaroundabout: "Overloading" implies that you're doing more "loading" than usual, so the term is only used when you have more than one function with the same name. – kindall Apr 19 '12 at 21:36
  • Agreed with @kindall; the word "overload" in a software development context means "to assign more than one meaning to"; overloading columns in a DB (meaning depends on other fields), overloading parameters (meaning depends on other parameters), etc. One method doesn't overload any other, but if there is more than one method with one *name*, the name is "overloaded". – KutuluMike Apr 20 '12 at 00:22
15
I would simply say foo is overloaded. There is certainly no master/slave or parent/child relationship going on here.
DeadMG
  • 36,794
  • 70
  • 139
    Agree -- it's the *name* of the method or operator that's overloaded, not the method itself. Not to be confused with *overriding*, where the implementation of a given method in a subclass supplants the implementation in the parent class. – Caleb Apr 19 '12 at 16:52
    I agree with this too, but i think thiton does a better job at explaining it. Thank you for your answer ! – Willem D'Haeseleer Apr 19 '12 at 16:56
I think that a good way to express this is to focus on the final result, not on changes made to the class over time. Thus, instead of saying "I overloaded 'foo' with 'foo(other parameters)'," you say "foo is an overloaded function, with 'foo()' and 'foo(other parameters).'"
mjfgates
  • 2,064
