I program primarily in ColdFusion but this is a general OOP question.
Is there any benefit to using:
getProp() {
return prop;
setProp(val) {
prop = val;
As opposed to simply
obj = new Obj();
obj.prop = "1";
getProp() {
return prop;
setProp(val) {
prop = val;
obj = new Obj();
obj.prop = "1";
I think you must try to use getters and setters always. In your case you have something like:
obj = new Obj();
obj.prop = "1";
What if you have other 1000 references to obj.prop
? And then, you decide that obj.prop
cannot be a negative like "-4" (just an example). If that's the case, how would you control that nobody passes such values to the object? If you used a setProp method it will be easy:
setProp(val) {
if(val < 0)
// doSomething
prop = val;
In general, that's the kind of situations where using setter and getter would make your code easier to maintain. There are many other situations like that and most of them encourage you to use setter and getter.
However, I sometimes use classes with public fields. I do it when that class is an inner private class; which means that it is not used outside the parent class. In such cases the excuse is: "I always know what data to assign and that it is valid". Though, it is always a case of laziness.
Some guys say it is faster in runtime to assign the values directly, and that might be true but I think it is difficult to note a significant difference one way or the other.
In languages without C-style structs, it's generally accepted, even encouraged, to use public fields for "Plain Old Data" classes, like complex numbers, points, etc. Otherwise, getters and setters are recommended.
In addition to Cristian's excellent point about maintainability, it also makes debugging much easier to have only one place where a value can be changed. For example, maybe a field is used to index an array and you get an out of bounds exception. Without a setter, you're going to go through the entire code finding the one place that sets it to the wrong value. With a setter, you just put a breakpoint in the setter and you know very quickly. Setters also allow you to enforce data validation.
In other words, it's slightly more typing in the short run that maybe is not needed later on, but is extremely useful when it is.
There's no particular reason to use getters/setters if you dont need them. Public properties are there, after all, for a reason. Otherwise you're just cluttering the code with getter and setter functions that may never do anything more than assign a value.
Some of it is language dependent - some languages steer you more to them than others. Delphi, for example, has properties, which can effectively act as either a wrapper around a private variable, or a getter/setter. So there's no actual need to use a getter/setter method if you dont immediately need it, since a public variable can be recast as a property using getter/setters, keeping the interface to that class the same for the code that uses it (i.e., even though it may be a getter/setter under the hood, to code setting an object's property, it still does so as if it was a public variable).
Basically my advice is what it always is... worry less about how other people say you should be coding, and more about making sure your projects get done and are easily maintainable. If that means getters/setters to you, then use 'em. If it doesnt, thats good too.
In addition to the good points already mentioned, for C#.NET:
A - Unlike fields, a property does not have any associated storage space within the object.
B - The property value is set (or calculated) when accessed not when the object is instantiated.
Note: A field value may be set only when used if you use the volatile keyword when defining the field.
C - A property could assign a calculated value based on specific instance data to the result (or input) whereas in the case of a field, you need to invoke a method to do that, this makes your code confusing because it would require both methods and properties to obtain the object state.
D - Fields can’t be writeonly but Properties can (writeonly is rarely used but is still part of the language).
Reference: Source for A and B above is the book: Accelerated C# 2010. Information have been re-phrased based on my own understanding. For more information on volatile keyword, see Black-Wasp-Volatile Keyword.
