I'm trying to do the following: take a single IA32 instruction in the Intel syntax (such as ADD EAX, EBX) and produce the corresponding machine code for this instruction. Is there some small library, preferably open source, that can do this for me?
Frederick
  • 183
  • You could probably extract that part from, say, NASM, and turn it into a library -- but I don't know of one that's already built to do exactly that (and it's not clear how it would work in some cases, such as jmp instructions, which normally need a series of instructions so the assembler can compute the offset to the target). – Jerry Coffin Apr 05 '12 at 08:14
  • Jerry, for JMPs I'd like to be able to specify the target address and the resulting object code should imply include the address verbatim. – Frederick Apr 05 '12 at 09:15
  • Do you want to write a small assembler, or do you need to have an assembler in your program? –  Apr 05 '12 at 09:59
  • @Thorbjørn I need the assembler inside my program. – Frederick Apr 05 '12 at 11:22
You can do it with FASM.
There is a sample GUI application distributed with FASM DLL
Or, you can use Python interpreter, with Python binding for FASM DLL
Abyx
  • 1,439
