Jon Purdy has the right idea. git flow
makes the actual management of these branches easy, as well, and branch management is an argument for moving to git
Let's start with a basic rundown of git
, since you're coming from the svn
-to-git
perspective. Consider in git
the following:
master--...............-.....-..............-
---develop---------............../
--feature---
Above, you branch master
to develop
(denoted by the \
), and branch develop
to a feature
branch. We merge those branches back up (denoted by /
), with commits (-
) along a branch. (If there's no commit but the merge is way to the right, there are .
indicators to show that the next -
is the next commit).
Easy enough. What if we have a hotfix in our main release?
master--...............-.....-................-...........-.........-
\ / / / -hotfix-- V /
---develop---------............../..............-...----
\ / \ V /
--feature--- --feature2...----
Above, develop
branched from master
. The bug discovered in master
was fixed by branching from master
, fixing it, and merging back into master
. We then merged master
into develop
, and then develop
into feature2
, which rolled the new code from hotfix
into these branches.
When you merge feature2
back to develop
, its history includes develop
with the hotfix
. Likewise, develop
is merged into feature2
with the new code from master
, so merging develop
back to master
will happen without a hitch, as it's based on that commit in master
at that time—as if you had branched from master
at that point.
So here's another way to do that.
master--..........-........-
---1.0-- --1.1--
Your 1.0 releases get tagged—1.0.1
, 1.0.2
, 1.0.3
, and so forth.
Now here's a trick: you found a bug in 1.0 and it affects 1.1, 1.2, and 1.3. What do you do?
You branch off your latest or earliest maintained release and fix it. Then you merge your new hotfix
branch into 1.3
—and into 1.2
, 1.1
, and 1.0
. Don't branch from each of the maintenance version branches; don't merge 1.0
into master
or merge master
back into 1.0
. Take the one hotfix
branch and merge it into all your version branches. If there are conflicts, it will tell you; review your code to ensure the changes are correct (git diff
is your friend).
Now that specific change is applied everywhere. The lineage is branched, but it's okay. It's not haphazard. Tag the 1.3
head as 1.3.17, merge it into every feature-in-progress branched from 1.3
, and move on.
The git flow
extension helps manage these maintenance, feature, and hotfix branches for you. Once you get the workflow down, this is trivial and takes a huge amount of trouble out of source code management.
I've seen this done on programming teams, but I've not worked that deeply as a programmer myself, so I'm still getting my head around the day-to-day workflow myself.
