Directly under the list of rules is the following statement:
Never be a slave to the rules in real life. For training purposes you need to follow these rules to make your mind strong, but in real life sometimes these rules are just stupid. If you think a rule is stupid, try not using it.
It looks like the rules are setup to be overly cautious because the target audience is just starting. By doing this, it forces the student to form good habits when writing future code. If you are able to explain why you no longer think the rule is worth following (and support it with a good reason), you are already thinking deeply on the issue. This means you have weighed the options and decided to accept what risk there might be. You are also less likely to make a mistake the rule would have prevented if you have spent that much time thinking about the rule.
