I was sent out to discuss a system that a certain company is currently using and what should be done with it.
The company manufactures various carton displays. This system was developed to keep track of clients, orders and prices. Lots have happened since the system was created and the system is now, as the manager described it, "locked up" and "problematic", which I translate as "not dynamic" and "unstable".
Some info about the system
  • It was developed around the year 2000
  • Fairly small system, 2-5 users, 6 forms, ~8 tables with average quantities of data
  • Built on early Visual Basic, forms created with the drag and drop design. Interface is basically just a window with a menu and some forms
  • Uses MSSQL database (SQL2005 server) to store data and ODBC driver to query, data was migrated from excel before this system, and before excel it was handled, calculated and written by hand and paper
  • Users work in Microsoft XP environment (and up)
Their main problem is that they can't adjust and calculate prices, can't add new carton types etc, correctly anymore because they can't (or rather, they don't know how to) touch the data on the server.
I suggested 3 possible solutions
  1. Attempt to patch the current system
  2. Create a fresh new interface (preferably similar environment, VB.net or VB based)
  3. Bring it back to an Excel solution, considering it is such a small system
There might be more options, but these are the ones I could think of.
My questions are
  • What should I recommend and why?
  • What is or could be the pros and cons of these alternatives?
  • Are there other (possibly better) alternatives?
Deco
  • 2,466
    You cannot decide how badly broken the current system is until you have documented the database schemas. –  Mar 20 '12 at 11:15
  • @ThorbjørnRavnAndersen That's true. I have only peeked at the database. Judging from the age it was created, I'm going to assume that it's really __really__ terribly designed and is in need of first aid... or surgery. – ShadowScripter Mar 20 '12 at 11:21
    Do you know who wrote the original system? Was it an inhouse effort or was it contracted out? – maple_shaft Mar 20 '12 at 11:22
    Don't do that. Tell the client that the state of the database is crucial to the cost of the various options, and should be done regardless of which option they choose. Even for a rewrite from scratch they most likely want their data ported over. –  Mar 20 '12 at 11:23
    Developers like to default to "rewrite from scratch" and refactor only when necessary. I'd rather default to "refactor gradually" and only rewrite when necessary. – quant_dev Mar 20 '12 at 11:28
  • @ThorbjørnRavnAndersen Thanks. It's good that you mentioned it, because I hadn't really thought about it that much. I was hung up on the interface. – ShadowScripter Mar 20 '12 at 11:29
  • @maple_shaft It was an inhouse effort, and the person who did it is now... well let's just say he's not even in the same country anymore. :P – ShadowScripter Mar 20 '12 at 11:30
  • If the system merely keeps track of clients, orders and pricing for a very small business why not use some "off-the-shelf" commercial software? This doesn't sound like it needs to be a custom application. – Angelo Mar 20 '12 at 14:14
  • @Angelo Funny that you mention it. They had actually tried commercial software, but the manager said that "it didn't work as we wanted it" and "there was no support available after we bought it" which, to me, sounded odd. Either way, they wasted too much time and resources on it and lost a lot of money as a result. That is why they reverted back to the old application in the first place: it was cheaper. – ShadowScripter Mar 20 '12 at 14:45
  • @Angelo If you have some suggestions on commercial software that might suit them, please list them. I would like to take a look at them and see if one of them works for the job. It would make this so much easier to be honest. :) – ShadowScripter Mar 20 '12 at 14:51
  • On "Transferring all existing data" consider an approach I've seen work well for small companies and/or small systems. DO NOT assume you need to port all data, port only what is necessary to get the new system running. When the new system comes on line, leave the old system accessible for historical data & to complete existing order etc. Over time the old system will be used less and less, until (generally after a business year) it can be removed completely. P.S. The "porting" may be done manually if the minimum data set is small enough. – Binary Worrier Mar 20 '12 at 17:23
6 Answers6
Something with only 6 forms and such should be easy to rebuild on a more modern framework. I've worked with migrating VB6 projects that had around 200 forms along with dozens of classes and database tables. It doesn't sound like you're looking at anything that messy but looks can be deceiving.
I'd have to analyze the code, the database and business requirements to say if rewriting or refactoring the existing code base would be best. Given what you've said, I'd lean toward a rewrite. But, there could be hidden difficulties that you don't see right now.
jfrankcarr
  • 5,082
  • Given its small size, I agree. At a glance, it doesn't seem too complex either. Judging from the answers, a rewrite does seem most appropriate. I'll take a closer look before making a final decision though. Thanks for the advice! :) – ShadowScripter Mar 20 '12 at 11:55
  • @ShadowScripter I'd take a look at writing it in a better language than VB while you're at it. Check out the open source [lazarus](http://lazarus.freepascal.org/) project. – Spencer Rathbun Mar 20 '12 at 17:51
I have slightly different advice the most of the responses so far.
I would at least learn the current system well enough to explain to the client how to use it. I would take this time to explain the flaws in their current system, avoid negative words, just tell them what it cannot do even if all the known bugs were fixed.
After you have learned everything you can with their current setup. Provide them with options, if you can address their concerns with their current system, there really isn't anything wrong with their current system. The only concern of course is that Visual Basic 6 support might not exist in 5 years.
Another concern is the way it communicates with the database. Microsoft is slowly getting rid of some of the older ways to communicate with its database products ( Access, MSSQL ) so the way you interact with those products will determine if the solution can be used on Windows 9, and Windows 10 in the future.
This answer entirely depends on the fact they have the source to the application itself. If they do not have the source then it will be hard to address their concerns, fix the current major bugs, or even make it a tool they can actually use.
I don't feel there is anything "wrong" with a Visual Basic 6 application, besides the fact, its support for future versions is unknown. Even today with Windows 7 and 64-bit operating systems its getting harder and harder to support. This is a major reason a rewrite into a modern language with proper 64-bit support might be a good idea.
If they don't have the source at that point a rewrite is really their only solution.
Ramhound
  • 871
  • Could you cite a reference to "`Microsoft is slowly getting rid of some of the older ways to communicate...`"? Would like to read more about it. – ShadowScripter Mar 20 '12 at 17:40
  • @ShadowScripter - For instance the Microsoft.Jet.OLEDB.4.0 Provider in order to access legacy Access database files is not supported when the process is not a 32-bit process. WinRT might also change how we connect to these Microsoft products. I forget where I read about a future change, my understanding is after MSSQL 2012 Microsoft will only support specfic way of connecting to it also. This of course in the context of the providers built into Windows and its development offerings – Ramhound Mar 21 '12 at 18:05
Rewriting the interface is an excellent option, given that the system is relatively small. Advantages are -
  1. Improved stability (assuming you do it well!)
  2. Improved maintainability
  3. Modern interface
The main disadvantage is that it will still probably cost a fair bit more than hacking the existing code.
Craig Schwarze
  • 3,276
  • 35
  • Rewriting the interface is what I was leaning towards as well. And to be honest, I'm not sure where I'd begin with the old interface, judging by today's standards, it's just so... bad all around. – ShadowScripter Mar 20 '12 at 11:26
I would also tend to rewrite, but you need to be 100% sure you understand the current functionality fully as well as any functionality which is broken, missing or inadequate. The latter two are important as you mentioned adjusting and calculating prices. Do you fully understand the consequences of adding this feature?
I once worked on what was supposed to be a "website", but was in actual fact taking over a custom Access based CRM style tool from the late 1990s and bringing it into the modern, web based, world. The original developer was long gone, the Database had been modified umpteen times, original documentation was thus out of date and no one really understood how the system worked. But they knew how to use it, just. Probably 80% of the budget for this project went on three things:
  • gathering requirements
  • understanding the current system
  • coming up with a meaningfull database schema for how they intended to use the software
The project was, financially, not a success!
ZweiBlumen
  • 669
  • I hear what you're saying: before I make a final decision I need to be fully cognizant of its current failings, functions and purpose. It's not like I want to go all in, with guns blazing, screaming `All right, let's do this. LEEEEEEEROOOOOOOY...`! :P – ShadowScripter Mar 20 '12 at 15:27
Another option could be a compromise between rewriting the whole thing and hacking the existing app.
Give them the new functionality in a new application built from scratch.
This could potentially be easier to do, and not cost as much as a full rewrite.
Once this has been done and they are happy they can add/update data, it opens the doot ro a phase two could be replacing the existing funcationality in the new app.
This might be a more palatable approach.
ozz
  • 8,322
  • 62
    I suppose that's a good idea, but if phase two never happens, they will end up with an old separate application that is dependent on the other new application, leaving them with two applications and double the trouble. – ShadowScripter Mar 20 '12 at 11:43
Rewrites often have a tendency to run out of budget... Badly.
But having a modern skeleton for the application, might be a good investment, especially if no one knows how old system works, and if things break as soon as you start touching them.
Also, VB6 is bad for support. When you'll need to find specialists in 10 years, that will be pretty problematic.
Coder
  • 6,958
  • 49
