Hopefully this won't be flagged for being too vague, but I'm really looking for suggestions from anyone with experience in this sort of situation.
I work for a group that develops very specialized engineering calculations for Intel x86 platforms.
We do not intend to continue using this existing x86 code. Instead, we would like to start a new code base capable of targeting both x86 PCs and iPad and/or Android tablets. Clearly the UI code will have to be maintained independently. But I suspect the backend engineering code, which we want to keep common, is possible to be shared among all platforms.
I would like to know if there are any development environments or techniques for simplifying this multiple-platform development with a common backend code base, or will it be necessary to develop this backend code for each platform independently as well.
Please let me know if you need any clarification!
Thanks
EDIT
For example, we would need to write a large amount of code in C. Is it true both the iOS SDK's objective-C compiler can build native iOS code using the (relatively) same C code we would use to build native windows code using MSVC? Mind you, the code would not need to rely on specialized OS-dependent facilities.
Are there any tools for assisting in this sort of cross-platform development that may require multiple compilers? or perhaps any individual compilers that can target both platforms?
