Suppose I am working on an existing, reasonably large system. I have an object, myObject
of class MyClass
(for the example's sake, suppose I'm working in Java). myObject
is a composition containing a Collection
, say, a List
and other objects which (I think) are irrelevant. It contains delegate methods which just serve to call upon the methods of the List
it is composed of, in order to ensure the List
it has is not exposed (sorry if I've got my terminology wrong).
Let's say that this List
is a List<String>
but, for some reason, the main access method is a mask method for class SomeOtherClass
. If I wanted to insert a new value pair into my List
, then I'd have an object of SomeOtherClass
called someObject
. I'd call myObject.insert(someObject)
and inside the insert
method there would be some magic that would retrieve a String
to put into the List<String>
Supposing now that I've only got a String
value, and no SomeOtherClass
object to insert. Assuming I can't modify the insert
method because it would break everything in this system. Then should I overload the insert
method? Or should I create a new object of SomeOtherClass
every time I want to call insert
I guess if I did overload it, it would look something like this...
public void insert(String s) {
public void insert(SomeOtherObject obj) {
this.insert(obj.magicStringMethod());
(This example is a contrived puzzle based upon a similar (slightly more complex) situation regarding overloading that I encountered yesterday. I'll expand it if there's anything that was unclear)
Would this be an appropriate place to overload a method? If not, when should I overload a method?
