22
I recently designed a time series module where my time series is essentially a SortedDictionnary<DateTime, double>.
Now I would like to create unit tests to make sure that this module is always working and producing the expected result.
A common operation is to compute the performance between the points in the time series.
So what I do is create a time series with, say, {1.0, 2.0, 4.0} (at some dates), and I expect the result to be {100%, 100%}.
The thing is, if I manually create a time series with the values {1.0, 1.0} and I check for equality (by comparing each point), the test would not pass, as there will always be inaccuracies when working with binary representations of real numbers.
Hence, I decided to create the following function:
private static bool isCloseEnough(double expected, double actual, double tolerance=0.002)
    return squaredDifference(expected, actual) < Math.Pow(tolerance,2);
Is there another common way of dealing with such a case?
PersonalNexus
  • 2,989
  • 42
SRKX
  • 1,939
I can think of two other ways to deal with this problem:
You can use Is.InRange:
Assert.That(result, Is.InRange(expected-tolerance, expected+tolerance));
You can use Math.Round:
Assert.That(Math.Round(result, sigDigits), Is.EqualTo(expected));
I think that both ways are more expressive than a dedicated function, because the reader can see precisely what's going on with your number before it gets compared to the expected value.
Sergey Kalinichenko
  • 17,393
  • 57
  • 73
    Just a note that this answer is NUnit specific and showcases the "Constraing-based" assertion model. The classic assertion model would look like: Assert.AreEqual(expected, actual, tolerance); – RichardM Feb 07 '12 at 14:16
    @RichardM: Post that as an answer and I will select it accept it. – SRKX Feb 07 '12 at 14:22
  • The answer by @dasblinkenlight is correct, just adding some detail (since it may not be clear - the classic assertion model is also NUnit). Other test frameworks (not MSTest) likely have their own assert model to deal with floating point values. – RichardM Feb 07 '12 at 14:26
    `Assert.That(result, Is.InRange(expected-tolerance, expected+tolerance));` will fail if `tolerance/abs(expected) < 1E-16`. – quant_dev Feb 07 '12 at 15:50
  • @quant_dev You are absolutely right. Since OP talks about calculating returns as percentages, I assumed that `abs(expected)` would be single to double digits. I also assumed the tolerance in the vicinity of 1E-9. Under these assumptions this admittedly simplistic approach could serve you reasonably well (I use `Is.InRange` in my tests). – Sergey Kalinichenko Feb 07 '12 at 16:05
As RichardM suggested, if you do not use NUnit, the best way seems to be using Assert.AreEqual(double,double,double), where the last one is the precision.
SRKX
  • 1,939
It depends what you do with the numbers. If you are testing a method which is supposed to e.g. select an appropriate value from an input set based on some criteria, then you should test for strict equality. If you're doing floating-point calculations, usually you will need to test with a non-zero tolerance. How big the tolerance is depends on the calculations, but with double precision a good starting point is to choose 1E-14 relative tolerance for simple calculations and 1E-8 (tolerance) for more complicated ones. YMMV of course, and you need to add some small absolute tolerance if the expected result is 0.
quant_dev
  • 5,117
  • 26
