I have a PBF file that contains the following information about a country:
  • Nodes, each with their own longitude, latitude and properties; used to store points in a 2D space.
  • Ways, each with their properties, they are connected through nodes; used to store roads, boundaries.
While this file is only 80 MB in its compressed form, it's 592 MB when uncompressed and stored in a DB.
Yeah, and that's only for one country, Belgium. Imagine storing France, Germany and Italy alongside.
Let's take a single highway for example, from Antwerp through Brussels to Charleroi. This would consist of a ton of nodes to store all the turns in the highway, but do I need all these turns? I doubt it.
Let me tell you what I want to be able to do:
  • I want to view the map at different zooming levels; major cities, minor cities and street level at least.
  • I want to be able to get routing information between two points.
  • I want to be able to compute the nearest road to my GPS location.
  • Search for a location, by means of an index in the database.
But most importantly, the database shouldn't be too big as it will be stored on a mobile device.
So, I thought about a combination of two techniques:
  • Image tiles for viewing purposes, to working around storing/processing all the individual nodes.
  • Storing the endpoints of roads for routing information, alongside information about the road.
The problem with this is that I can't compute the nearest road to my GPS location with only this information; imagine that a bend in a highway, I can't determine that I'm on the highway with just the two endpoints. I was thinking about storing intermediate nodes between endpoints but that would be very costly to generate, I think. Also, determining the endpoints of roads (that are like a T-split) is most likely not even that easy as I need to figure out whether I need to store the midpoint at the top of that T-split or not.
So, viewing is easy using image tiles; but I can't find an easy way to do routing and GPS location finding, what kind of storage technique should I be looking into? I find it a bit inconvenient that a 80 MB file turns into a database of 592 MB, I want to reduce that size a much as possible...
What can I do to do this as efficiently as possible? In terms of disk and CPU. I'm targeting a WP7...
Tamara Wijsman
  • 8,259
  • 58
  • 94
  • how much of the 580MB is node/way data and how much is index to have fast access to the data – k3b Jun 17 '14 at 16:04
It seems to me that the main issue is only including nodes that add significant information about a road.
i.e. without your GPS requirement, you could just store nodes at junctions and endings (which I think you call start/end nodes). Obviously including weight/costs etc.
One way I can think of approaching this is to first, add all start/end nodes. This is the minimum needed. Obviously this doesn't account for winding roads.
Then, for every road (defined as ending to junction or junction to junction) do the following:
  1. Loop through all intermediate nodes and work out the minimum distance from each node to the road as defined by nodes included so far (to start with only the start and end).
  2. If the sum of the above is larger than (some constant threshold * number of intermediate nodes) we need to add intermediate nodes. If not, exit the loop.
    • To add intermediate nodes find the node that had the largest distance from the current representation of the road and add it.
George Duckett
  • 511
  • That makes more sense, now I only wonder what a good threshold would be. Seems tricky to implement all that, although I can start from the 582 MB database I already have instead of starting from the 80 MB compressed file. Will leave the question open to see what other ideas show up... :) – Tamara Wijsman Feb 06 '12 at 13:39
  • You'd have to balance the threshold between including more nodes (larger size) and including fewer nodes (less accurate) I guess. Suppose the first step is being able to generate a smaller DB containing only junctions and end points. – George Duckett Feb 06 '12 at 13:51
  • You are stuck having to have the data between the nodes, including the actual path. There are costs between nodes, but they can change between intersections. Speed limits and the number of lanes don't just change at the intersections. Knowing the exact path is required to calculate the nearest road. The connecting lines between the nodes in addition to the actual path will need all the meta data for that segment. This meta data will be needed for the routing and directions. – mhoran_psprep Feb 06 '12 at 15:42
  • For path-finding you can probably get away with reducing the number of nodes, for example, if a road (between junctions) has several nodes, where there are changes in the speed limit that doesn't matter as once you're on that road you have to continue to the next junction. Just take care when reducing nodes to take into account different speed limits and lengths of those speed limits. The same goes for # of lanes, you'd just have to reduce it to an appropriate edge weight. – George Duckett Feb 06 '12 at 15:51
  • It also depends on the definition of 'junction' the meaning that would reduce the most, but would be least accurate would simply be where 2 or more roads meet. An alternative could be where a property of the road changed (i.e. Minor->Major, 30km->40km etc). – George Duckett Feb 06 '12 at 15:53
  • You have to have the actual path for the start or the end of the journey. To go from address or GPS Coordinate to the first node requires knowing which road you are on. It might not even connect to the nearest node. In fact your first 3 roads on your path may be needed to get to the nearest node. – mhoran_psprep Feb 06 '12 at 17:41
  • Chances are the road you are on will be the edge you're nearest to though. I suppose the only issue would be which of the 2 nodes on the should you go to first. Possibly you could store the 'mid-point' along each edge at which it makes no difference, then always initially move away from that point. – George Duckett Feb 06 '12 at 18:20
