How can I check automatically what is seen and what not? Or at least, how can I organize some partly automatic tests?
IDE: Eclipse (could use also IntelliJ Idea if necessary)
Testing tool: Junit (again, could use something else if advised, but better if it is free)
Application OS: Android
Developer's OS: Linux (could change for MAC or Windows(reluctantly))
Language: Java
All the work goes in the external device. No emulator.
The application is a user wrapper for the firmware TV player, called as external activity. So, 70% of the code is for GUI. (The other 30% speak to servers and provides info to the GUI)
Before I programmed the testing function myself, not using any tools. Now I have a tool at hand. But I can't imagine how could I test the UI, with the tool or without it. (Strictly said, with the Internet connections I have problems too, but I'll leave them probably for the other question.) The answer needn't be too platform-dependent, the principles and ideas will help, too.
Of course, it is good to check, is some element in another and checked or not. Some regression checks would be nice for that. But I should also be sure that the element mentioned is not cut by some other elements and winks as I ordered by animation.
The advices here: https://softwareengineering.stackexchange.com/questions/63245/is-there-a-tool-to-test-java-ui won't help - there are only tools, not principles, and none of the tools could help in my situation.
Gangnus
  • 2,805
  • did you consider asking at http://sqa.stackexchange.com/ ? BTW what is available for you to capture in testing - GUI objects, screen pixels, keyboard/pointer device events? – gnat Feb 03 '12 at 09:28
  • Thank you. I didn't know about that server here. Maybe, later some moderator will move my question there. (BTW, I don't understand why the testing needs its own server). As for your other sentence, I think, it is as usual in Android - objects - yes, pixels - may be, through some tricks? - I don't know, events - yes. Can Junit read pixels from gui? – Gangnus Feb 03 '12 at 09:38
  • A great open-source automated testing tool for Android is [Robotium](http://code.google.com/p/robotium/). – Corey D Feb 03 '12 at 21:28
Most often the best advice for automatic GUI testing is to develop your application in a Model-View-Presenter style and write your tests against the Presenter. The topic is discussed here:
http://danbunea.blogspot.com/2005/11/model-view-presenter-is-testing_27.html
(there are further links at the end of that article).
Of course, that might not help you to "check automatically what is seen and what not", but it may help you to test the most of the UI logic.
Doc Brown
  • 199,015
  • 367
  • 565
  • Thank you for the article. The problem is, that in my application, on the contrary, the view is the most complicated part, and the presenter and model are primitive enough, and it is view part that I need to test. I want exactly as I have said, to "check automatically what is seen and what not" Or partly automatically. – Gangnus Feb 03 '12 at 10:10
  • +1, You have conducted me to another question (http://programmers.stackexchange.com/questions/133134/is-model-view-presenter-mvp-scheme-useful-for-android) :-) I would be glad to read your opinion on it. – Gangnus Feb 03 '12 at 10:44
There are testing frameworks that allow you to interact with the screen directly; at my job we use IBM Rational Functional Tester, which allows us to click buttons and so on as well as the usual programmatic testing. Obviously, that's not free, but looking it up on wikipedia provides this list of alternatives. Since you're looking at Java, there's CubicTest, which is an Eclipse plugin; alternatives include Maveryx and Abbot.
Yamikuronue
  • 702
  • +1 for your attempt. But these tools don't work for Android, as I see. – Gangnus Feb 03 '12 at 20:13
  • @Gangnus Drat, I was hoping at least one would. I'm not familiar with Android-specific development, unfortunately – Yamikuronue Feb 03 '12 at 20:42
  • Alas, I have a really hard problem - my app is being debugged not on the emulator, that is in a PC, but on the external Andoid device. So, I am almost sure there is no ready tool for testing it. I should organize the process myself. But how... What have I to check, what are the problems of making such testing, how the regressive test are organized... Everybody gives me links to tools, but I need links to thoughts. Of course, i would take a tool very gladly, but there isn't one... What a sad world... :-) – Gangnus Feb 03 '12 at 21:11
  • @Gangnus My coworker informs me that even the emulator makes life difficult for debugging the GUI unless you have something designed for it, since it's a whole extra layer to deal with. As for modelling the tests, we use a tool to create flowcharts outlining the path through the program; our tool I think is made in-house, but it has the ability to generate lists of all possible traversals of the flowchart (which become our test scripts), which sounds like a feature you ought to be able to find easily enough or do yourself – Yamikuronue Feb 03 '12 at 21:35
I use testcomplete. Its a most comprehensive tool I've used to automate GUI testing. http://smartbear.com/products/qa-tools/automated-testing/ check them out I am really positive that this will be a good fit for you and it does support Java
  • Thank you, but it is: a) Windows b) not for Android c) not free. I could overcome "c" and even "a", but "b" is too bad. – Gangnus Feb 03 '12 at 10:26
-2
I've been using https://marketplace.atlassian.com/plugins/com.thed.zephyr.je/cloud/overview for a while. It has plugins like ZAPI that help automate testing.
    Answers that are essentially "link-only" are not very useful. Now if you added examples of how there plug-ins address the OP's question, you could make this answer useful. – Jay Elston Oct 23 '17 at 19:44
