49
I'm looking at diving into Haskell for my next (relatively trivial) personal project. The reasons that I'm tackling Haskell are:
  1. Get my head into a purely functional language
  2. Speed. While I'm sure this can be argued, profiling that I've seen nails Haskell close to C++ (and seems to be quite a bit faster than Erlang).
  3. Speed. The Warp web server seems to be crazy fast in comparison to virtually everything else.
So, given this, what I'm looking for are the downsides or problems that come along with Haskell. The web has a tremendous amount of information about why Haskell is a Good Thing, but I haven't found many topics about its ugly side (apart from gripes about its syntax which I don't care about at all).
An example of what I'm looking for could be like Python's GIL. Something that didn't rear its head until I really started looking at using concurrency in a CPython environment.
Thomas Owens
  • 79,623
  • 192
  • 283
Demian Brecht
  • 17,555
  • 47
  • 81
    Found this on stackoverflow: http://stackoverflow.com/questions/1695076/pros-and-cons-of-haskell – FrustratedWithFormsDesigner Jan 25 '12 at 19:43
    I've heard lesser programmers have dealt with brain melting issues. It is a very expensive condition to treat. – ChaosPandion Jan 25 '12 at 19:43
    @FrustratedWithFormsDesigner: Thanks for the link. However, there *still* isn't any reference to any technical downsides to Haskell.. Could it be there *aren't* any? ;) – Demian Brecht Jan 25 '12 at 19:50
    @ChaosPandion: I've heard the same.. But if you're **not** melting your brain, are you actually *trying*? ;) Also, I wouldn't really regard myself a lesser programmer, so I'm not overly concerned about that ;) – Demian Brecht Jan 25 '12 at 19:52
    @ChaosPandion: And most health plans don't cover it. :( – FrustratedWithFormsDesigner Jan 25 '12 at 19:59
  • @DemianBrecht: It could be that there aren't any technical downsides. I've never used it, I just searched the web to see what others were saying. – FrustratedWithFormsDesigner Jan 25 '12 at 19:59
  • I've never used or even looked at haskell, but I've heard good things about it. BUT, I would be very surprised if there are no downsides to a language (haskell or otherwise). I seem to remember reading somewhere, "There are no silver bullets." – Kevin Jan 25 '12 at 23:08
    "I haven't found many topics about its ugly side". We wanted to diversity our company from OCaml-only in 2007 and I was challenged with investigating Haskell. I found many problems and later wrote them up in a blog post "Why is Haskell used so little in the industry?". http://flyingfrogblog.blogspot.com/2010/05/why-is-haskell-used-so-little-in.html – J D Feb 26 '12 at 12:53
    To summarize that blog post: lack of compelling examples, lack of genuine case studies, user unfriendly, commerce unfriendly, ill-advised by its creators and backed by a lot of bad science. – J D Feb 26 '12 at 12:55
  • Not a full answer, but in my experience a lot of useful features of the language are squirreled away into language extensions, each of which have upsides and downsides of their own. They're often incredibly useful to know about, but hard to discover without a mentor who can guide you to them. – KChaloux Jan 26 '15 at 17:58
  • If there was a language with no downsides, wouldn't everyone be using it? – user253751 Mar 27 '17 at 04:11
  • @immibis: Tremendously helpful comment... 5 years after the fact. I thought the question was pretty clear that I was looking for specific downsides. It's good to have a clue about potential pitfalls and gotchas from others who have been using a language for a while instead of just diving head first and being blindsided down the road. Due diligence. – Demian Brecht Mar 27 '17 at 23:32
A few downsides I can think of:
  • Due to the language's nature and its firm roots in the academic world, the community is very math-minded; if you're a pragmatic person, this can be overwhelming at times, and if you don't speak the jargon, you'll have a harder time than with many other languages.
  • While there is an incredible wealth of libraries, documentation is often terse.
  • Gentle entry-level tutorials are few and hard to find, so the initial learning curve is pretty steep.
  • A few language features are unnecessarily clumsy; a prominent example is how record syntax does not introduce a naming scope, so there is no way to have the same record field name in two different types within the same module namespace.
  • Haskell defaults to lazy evaluation, and while this is often a great thing, it can bite you in nasty ways sometimes. Using lazy evaluation naively in non-trivial situations can lead to unnecessary performance bottlenecks, and understanding what's going on under the hood isn't exactly straightforward.
  • Lazy evaluation (especially combined with purity and an aggressively optimizing compiler) also means you can't easily reason about execution order; in fact, you don't even know whether a certain piece of code actually gets evaluated in a given situation. Consequently, debugging Haskell code requires a different mindset, if only because stepping through your code is less useful and less meaningful.
  • Because of Haskell's purity, you can't use side effects to do things like I/O; you have to use a monad and 'abuse' lazy evaluation to achieve interactivity, and you have to drag the monadic context around anywhere you might want to do I/O. (This is actually a good feature in many ways, but it makes pragmatic coding impossible at times.)
tdammers
  • 52,406
  • 106
  • 154
    There are actually some *really* good introductory books available for free online now. [Learn You a Haskell for Great Good](http://learnyouahaskell.com/) is one of the best beginner programming books I have ever read and [Real World Haskell](http://book.realworldhaskell.org/read/) is a great intermediate resource. – Tikhon Jelvis Jan 26 '12 at 03:20
    @TikhonJelvis: Those are indeed the only two candidates I found worth using; "Learn You A Haskell" confused me more than anything, "Real World Haskell" worked for me but assumes a bit of a programming background. There's also "Gentle Introduction to Haskell", but it's all but gentle, especially if you lack a background in Math. – tdammers Jan 26 '12 at 11:38
  • I use "Gentle Introduction to Haskell" and "Real World Haskell". The combination of the two gave me a lot of useful information. I am at a level where I am ready for a non-trivial project but unfortunately I do not have much time for it. – Giorgio Jan 27 '12 at 15:54
    "if you're a pragmatic person...": sometimes using a math-oriented language can be a very pragmatic decision if it avoids you a lot of bug-fixing later. Of course, you should always find a balance between how much time you save by using a tool, and how much extra time you need to learn how to use it. – Giorgio Sep 21 '13 at 07:00
  • Monads would (and do in other languages) work the exact same in a strict language. You absolutely do not "abuse" lazy evaluation to achieve interactivity, it is trivial to write a strict interactive program in Haskell. – semicolon Feb 04 '17 at 00:31
19
Most of Haskell's downsides (as well as most of Haskell's upside) come from its two defining characteristics: It's lazy and purely functional.
Being lazy makes it harder to reason about performance. Especially for people not used to laziness, but even for experienced Haskellers it can be hard to see how laziness will affect performance in certain cases.
Laziness also means that it's harder to create accurate benchmarks without using libraries like Criterion.
Being purely functional means that whenever you need to use mutable data structures (in cases where it's not possible to achieve the desired performance without them - though thanks to GHC's optimizer that doesn't happen as often as you might think), you'll be stuck in the IO (or ST) monad, which makes the code more cumbersome.
Since you mentioned speed as one of your goals, I should point out that there are often huge differences in performance between hand-optimized Haskell code and Haskell code that was written without giving much thought to performance (more so than in other languages). And hand-optimized Haskell code is often quite ugly (though I suppose that is also true in most other languages).
sepp2k
  • 4,339
    Purely functional is actually a selling feature, not a downside. A language being "lazy" makes no sense, lazy vs strict is a matter of types, and both lazy and strict types have their uses. (So Haskell is just as crippled by not having strict types as most languages are crippled by not having lazy types.) Haskell's main downsides are its crappy module system (modules are not first-class) and the fact type classes actually *break* modularity (the "one instance per type" rule forces the compiler to keep a global list of type class instances). – isekaijin Jun 23 '13 at 13:38
    "And hand-optimized Haskell code is often quite ugly (though I suppose that is also true in most other languages)." This. When people want to show the elegance of Haskell, they publish short and sweet code, which unfortunately would give you quite bad performance if run on a production-like amount of data. When people want to show that "Haskell is as fast as C++", they publish convoluted and hard to read code, which is still slower than a much more readable version in C. – quant_dev Sep 20 '13 at 17:01
12
I am not a Haskell expert: I have learnt the basics but unfortunately I haven't had the chance to do some serious project in Haskell (I would like though, because I like this language a lot).
However, from what I know and from a discussion with somebody who's been working in a field quite close to functional programming, Haskell might not be the best solution when you want to implement graphs algorithms, where you need e.g. to walk through the graph and perform many local changes on the graph structure.
Since a graph does not have a recursive structure in general, my feeling is that the best approach is to build one copy of the graph using structures and pointers between them (as you can do e.g. in C++) and manipulate that copy by changing pointers, creating or destroying nodes, and so on.
I wonder how such data structures and operations can be handled properly in Haskell, since to my knowledge in Haskell it is not possible to use the above representation / approach. Some problems with graph algorithms in Haskell are briefly discussed in this article
EDIT
I recently spoke with an expert of functional programming and he confirmed that implementing certain graph algorithm efficiently can be quite tricky in Haskell: moving around pointers like you do in C or C++ can be much faster.
Giorgio
  • 19,486
  • 84
  • 135
  • Interesting notes (and link) on graph manipulation/traversal in a pure functional world. Hadn't considered that. – Demian Brecht Jan 25 '12 at 20:21
    Purely functional graph algorithms are an interesting topic. The idiomatic solution is to emulate the imperative representation by replacing pointers with purely functional dictionaries, e.g. mapping a given vertex to the set of vertices that it has edges to. However, unless a weak dictionary is used this will leak memory because unreachable subgraphs cannot be collected and there is no known purely functional weak dictionary. At the end of the day, a state-of-the-art purely functional solution is both far more complicated and far less efficient! – J D Feb 26 '12 at 16:15
    On the other hand, graph algorithms can be notoriously difficult to debug and persistent data structure can alleviate this problem... – J D Feb 26 '12 at 16:20
  • I was wondering if it would be possible to develop a graph data type (following the idea of ByteString: efficient internal representation plus conversion / access functions). Using monads it should be possible to make such graphs mutable. Of course this would address the issue of of representing graphs but not that of implementing graph algorithms. – Giorgio Feb 26 '12 at 17:49
  • DAGs are one thing. For everything else, you can exploit laziness and "tie the knot". – danielm Oct 05 '15 at 01:31
  • Implementing graph algorithms in Haskell is generally frivolous because ADTs give you better tools to reason about what would be graphs in other languages. Any time you traverse a structure via pointers and then manipulate data there is a really good example of a place Haskell would do better. –  Feb 05 '18 at 04:24
  • If the downvoter can suggest how I can improve my answer I will be glad to change it. – Giorgio Feb 05 '18 at 21:49
  • @danielm Not if you want to mutate the graph afterwards and not without the possibility of using large amounts of memory. – user253751 Nov 20 '18 at 23:04
  • You could make an unsafe Monad that had functions(statements?) allowed you to do pointer manipulation. – aoeu256 Mar 24 '21 at 04:49
The down side to Haskell is that its different. It's a bigger step away from languages that are more commonly taught or talked about, so there will be a larger learning curve. It's also less popular of a language which may limit availability of help if you get stuck. These really aren't major downsides though.
The one thing that is a potential downside is that it's a functional language, so it is less useful for certain problem domains, but this is true for object oriented languages as well. Generally languages don't have true negatives beyond learning curves, at least for the relatively popular languages. As long as a language is Turing complete it is theoretically capable of anything.
gnat
  • 21,442
  • 112
  • 288
Ryathal
  • 13,317
    Turing completeness is a red herring. Theory of computation != practical programming. –  Jan 25 '12 at 21:00
    @delnan that's why i said theoretically – Ryathal Jan 25 '12 at 21:02
    What are those "problem domains" for which Haskell is allegedly less useful? – Andres F. Jan 26 '12 at 01:05
    While it's true the community is *smaller*, it is actually disproportionately active. I think the #haskell channel on freenode is only behind #python in popularity within the language channels, and answering questions about Haskell on SO is surprisingly competitive :) – Tikhon Jelvis Jan 26 '12 at 03:22
  • @AndresF. - I wouldn't go so far as to say "less useful," but here are some areas where Haskell is definitely still showing its infancy: 1) heavy DP -- I coded up a simple knapsack algorithm, and was literally shocked at how slow it was. That was using boxed arrays, so I expected some overhead, but it was a lot worse than I anticipated. 2) large non-trivial games -- AFRP is in its infancy, so there are no particularly good frameworks, and performance is still too difficult to predict. It will be a long time before we see the Haskell version of Doom. (frag doesn't count -- it has no AI.) – rtperson Jan 31 '12 at 15:15
The "problems with Haskell" tend to appear in certain domains. Haskell is a wonderful language for applications programming, far more pleasant to write than just about anything else. The problems tend to crop up when you try to do something there isn't good support for, such as:
  • Cross compiling. GHC can be built as a cross compiler, but the process is rather involved.
  • Embedded applications. Haskell has memory management via a garbage collector, so this one isn't too surprising.
  • Speed. Haskell is not as fast as Rust, though in most cases it will compete fairly well. It depends heavily on the application domain - pure computations get optimized well, but something like "read a file into a buffer and count the number of lines" is harder to express in Haskell.
  • Embedded & Realtime applications can be done via using Haskell as an macro language for a low level eDSL that is embedded in Haskell using ADTs, here is an example: https://ivorylang.org/index.html This is how Naughty Dog made Crash Bandicoot and Jack & Daxter with their Lisp eDSL called GOAL. – aoeu256 Mar 24 '21 at 04:55
