I come from a PHP background and I have been considering looking at DART in more detail.
DART is an, open source, front-end/back-end, language for web development.
PHP has a special $ (dollar) character to indicate variables:
$variable
CONSTANT
'string'
"etc"
I find that dollar sign to be really useful for speeding up the proces of refactoring, especially if PHP code is mixed with HTML or content. It reduces the number of false positives when, say, doing a find and replace.
As DART is a completely fresh language (with no legacy) that can be embedded in HTML, it surprised me to see that it does not have any special identifier to indicate variables.
What's the reasoning behind that design decision?
user
  • 2,703
JW01
  • 3,579
  • "Not necessary". Could you expand on that? Do you mean 'not necessary' to: (a) function, (b) 'to understand', (c) 'to automatically refactor' (d) perform static analysis? etc .Does a language only have to include necessary things? I do not know much about the theory of language design. Which is why i ask the question. – JW01 Jan 24 '12 at 10:08
  • You might want to ask the people behind Dart at https://groups.google.com/a/dartlang.org/group/misc/topics?pli=1 Many languages dont have special characters to indicate variables. Marking a variable by a leading character is neither common nor uncommon. In the case of Dart there might not be an IDE that would offer refactoring (never worked with it, so i couldn't say). For other languages like java or c/c++ who don't use variable name marking, the corresponding IDE's usually offer the functionality to easily refactor variable-/function-/class-/struct-/...names – Ingo Jan 24 '12 at 10:25
  • @Ingo It was easier to ask here (I am habituated to this interface). But, yes. I'll probably join the group at some point soon. I've never done any heavy refactoring of Java or c/c++ but always wondered how one copes without the leading variable name marking. I find it almost essential for my sanity. – JW01 Jan 24 '12 at 11:02
  • In most langauges, there are a few keywords. Any other names are available as variables, funtionnames, etc. Syntax clearly identifies the type for a user specified name. Well formatted code makes it even easier. Hand refactoring can be error prone as the same name may be used for many different variables. Tools which can find uses and references of a particular variable help significantly with refactoring. – BillThor Jan 25 '12 at 02:26
    "What's the reasoning behind that design decision?" - It's a bit strange to ask this, as if there was a conscious design decision to not have variable names start with a special character. Most languages don't require a special character. – Jesper Jan 25 '12 at 13:16
  • I was assuming that they looked at the features of existing languages. Then, carefully considered the costs and benefits of each feature. Then, decided to either adopt it or not. I've never designed a language, but I'd probably take an approach like that. Despite the religious hatred, PHP still managed to become one of the most popular and easy-to-learn web languages. Hence, I assumed they'd looked at its features. – JW01 Jan 25 '12 at 17:20
    That's generally referred to as a [sigil](http://en.wikipedia.org/wiki/Sigil_(computer_programming\)) and only a few languages use them any more. – jiggy Jan 31 '12 at 04:36
    The more interesting question is not why DART, like most other languages, doesn't use a special character (sigil) to mark variables. It's why PHP does. PHP started as Perl scripts, and Perl uses them. Perl probably uses them because there is some use in shell scripting, and Larry Wall thought it a good idea at the time. (There's lots of Perl syntax that looks like somebody, probably Larry, thought it a good idea at the time, and were arguably incorrect.) – David Thornley Jan 31 '12 at 17:18
  • To those who vote down...its a perfectly valid question. If you want to ask a different 'better' question then feel free to ask it. – JW01 Sep 04 '12 at 22:55
  • Love it! I feel EXACTLY the same way; I came from CoffeeScript where all member variables being with an at-sign (e.g., @color) instead of this.color and it was just a joy to use. – Pete Alvin Nov 02 '19 at 16:37
Actually you can use $ as a a prefix to variable names.
I tried it for you: http://try.dartlang.org/s/lKco
Please note what happens to the great string interpolation feature. Basically you can access vars in a string with ${yourvar}. If you name a variable with $, then it looks ugly: ${$yourvar}. Therefore I do not recommend the $prefix style.
I have started with PHP too. But I found out soon as I switched to Java, that $ is not really common usus. What is the sense behind - the PHP developer would probably say, easy identification of variables. The Java developer would cry in pain.
The Dart developers try to make an "unexciting" language. It should look familiar to many. Without doubt Java syntax is more widespread than PHP syntax. Maybe this is the reason why Dart developers have left out the $.
On the other hand, personally speaking, I think it is really not necessary and after getting used to Java, I find it ugly. Ruby doesn't use it. JS doesn't use it. And so on.
Anyway here are more answers to the language: http://www.dartlang.org/support/faq.html#language
If you want to follow the recent blogs on Dart I recommend you: http://www.dartosphere.org
Christian
  • 336
  • Thanks for the answer. Just out of interest, when you switched from PHP to Java did you have to make any changes to the way you do _find and replaces_ of variable names? Do you rely more on a specific tool? I guess with good naming conventions, my worries would be unfounded. – JW01 Jan 24 '12 at 11:06
  • With Java there are some cool tools in place. For example, you can use Eclipse Refactoring features to rename a variable (works with most other editors too). You just say: rename this, give it a new name and then all references to this name are updated. I never do the "find/replace" way I needed with PHP. This was a huge improvement to me. In Dart you can have a Dart Editor based on Eclipse. Not sure if does refactoring of this style too, but for sure there are good chances. – Christian Jan 24 '12 at 11:32
The reason why most language designers don't like constructs like starting variables with special chars is that most language designers want to minimize the amount of repetitive "stuff" that is required of the programmer, so long as the compiler / interpreter can figure it out. So, to many language designers, the code:
var x = new Something()
has less cruft than:
Something x = new Something();
("Why repeat the type specification? The compiler can infer it. Why have the semicolon? The compiler can figure it out.") which in turn has less cruft than:
Something $x = new Something();
("Why make every variable start with a '$'? The compiler knows that the token at that position must be a variable name")
This design aesthetic is something that most language designers would probably agree with in principal, but of course beauty is in the eye of the beholder. The "inferred semicolons" in JavaScript, for instance, can lead to surprising behavior.
Your opinion that there's value in quickly identifying variables by their $ is perfectly valid, but another person might say "Well, the only real semantic benefit is that you can have variables named similarly to keywords ($if) and that's a dubious benefit." In the specific case of refactoring, in languages with tighter type semantics, many refactorings can actually be done in not just a quick, but "guaranteed safe" way, since the refactoring is not being done on "just some string" but on a very specific element in the parse tree.
Larry OBrien
  • 4,927
  • The semicolon is a really bad example. Javascript is an excellent example of how the compiler *can't* figure it out. It is significantly difficult to cut the semicolon from a C-derived language. – DeadMG Jan 31 '12 at 01:19
  • @DeadMG Well, that was kind of my point: the aesthetic drives lang designers to think "Oh, we can infer that" and the reality is that inferring semicolons in C-derived languages is tricky (see also Scala) – Larry OBrien Jan 31 '12 at 01:22
  • @DeadMG, it's actually pretty straightforward to make semicolons optional in a C-derived language. JS just has a particularly awful way of doing it. – munificent Feb 10 '12 at 01:18
Dart doesn't use $ to denote variables because that is not familiar to JavaScript or Java developers. One of Dart's design goals is to be familiar to a vast majority of developers, which is why it looks kind of like C, Java, and JavaScript.
Seth Ladd
  • 1,724
Very few languages use special characters to denote variables. Perl and PHP are the only ones which are commonly used that do; the value that either derives from it is dubious; nobody complains that Python, for example, is more opaque than PHP. Note that many languages have solutions which do allow easy substitution of variables in strings, which is the only place where a variable indicator is really useful:
Python
example = "The capital of {0} is {1}.".format(state, capital)
Scala
val example = "The capital of %s is %s.".format(state, capital)
asthasr
  • 3,439
