Possible Duplicate:
Techniques to re-factor garbage and maintain sanity?
What is a good way to refactor a large, terribly written code base by myself?
Really open question here. I'm not after an answer.. only advice. Any past experience people have had with re-factoring legacy systems that they could pass on would be amazing. Here's some information about the software I am to re-factor (you'll cringe!):
- Web application
- Database driven (MySQL)
- PHP4 and PHP5
- Most of the code is PHP4
- Nearly all the code is procedural
- Code that is PHP5 isn't OO.. example: 10,000 line+ file with one class and one function
- Global variables used everywhere
- No source control was used to write the software (you can see from the comments in the code)
- Massive amounts of code repetition
- No separation of concerns - user interface and logic is combined everywhere
- Application relies on order of database tables
- Few code comments
- 250,000+ lines of code
- Application in heavy use
Basically, the software is our core product and I have been hired to do a major re-factor (amongst other things). It's a massive task and I can't just dive in and fix all the little things.. I need an overall strategy. I've written some scripts to tidy indentation up, removed commented-out code everywhere and made the project into a repo but now it's time to do the real stuff.
I kind of have a vague idea but not sure how to go about it. I could somehow leave the current code alone and write some layer of software over it that abstracts away from all the horribleness. It would be good if the new layer was some sort of MVC architecture. At the same time I would go into the current code, remove redundancies because otherwise the new layer would be using bad code anyway so the code could slow down even more.
As you can see.. need some clues/hints/tips/advice/experiences!
Thanks very much :).
