I agree with @FrustratedWithFormsDesigner in that it is quite possible, AND that the script for updating your database structure should not be brought along with your application code. Because of this your application would require other permissions allowing to create tables, alter tables, etc. which you most probably don't need during the "normal" usage of your application. So, in terms of security, not a good thing, since your application should only have the permissions needed to work properly.
Anyway, back to the main point. It is quite possible to properly do that by creating a special table in your database, let's say X_VERSION, in which you will simply have the current version of the database schema (it may be a timestamp too).
Whenever you alter your database schema, you put that change into a SQL script named [Timestamp-XXX-WhateverItIsYouAreDoing.sql], where:
- Timestamp is the timestamp, for example 20110111-165500
- XXX is a number, which will be useful later to know the order of execution of the scripts
- Whatever, etc. is some text that will help you remember what you do in that script
Whether your database updating program is in your application or outside does not matter for the following steps; whenever you deliver a new version of your application, your update program should do this:
When all scripts are done, you know your application can safely start.
Bonus:
If you want to have a safe way to go back to a previous version, whenever you create a script altering your database, always create somewhere a script that will allow you to go back to the previous version. It may sometimes be a bit hard (like removing a column for example, not all DBMS allow this), but always try. You will then be prepared to revert to a previous version if necessary.
