What reasons are there for web browsers to not have a library of popular web frameworks.
For example if a web page included jQuery, why shouldn't the browser have it's own static version, which is separate from the normal cached items?
I would imagine if most libraries were preloaded into a browsers cache, before any request was made with a document that included a library, then this would remove the initial request to a CDN and have a potential performance improvement.
But if the browser 'preloaded cache' didn't include the library then the browser should request the resource that is included in the document.
ChrisF
  • 38,878
  • 125
  • 168
Deanos
  • 75
  • The question is a bit unclear. What makes you think there would be any advantag in having a static version inside the browser? – sleske Jan 10 '12 at 16:47
    The only advantage I could see is that it would remove the need for the initially request and potentially deliver a performance increase. – Deanos Jan 10 '12 at 16:51
    isn't this the reason the Jquery site advocates using the google hosted version so that users have one version that works for tons of sites. – Ryathal Jan 10 '12 at 16:56
Because within a month, the browser's built-in version of jQuery would be out-of-date, negating the whole reason for using a third party library in the first place. Within 6 months, developers would be wanting to use features in the latest release of jQuery that weren't in what was built-in to the browser, but they wouldn't without including the whole new version of jQuery - negating the whole reason of bundling it in in the first place.
Browsers should follow and implement standards and developers will benefit years later when the older browsers stop being used or by writing browser-specific code to take advantage of the newest features. The path for browsers to get more jQuery-like functionality is via that standards process.
The whole point of the cross browser framework is that you can specify one specific version of the framework and know that you get the exact same behavior everywhere right now because that version of the framework takes care of it for you. That would never be the case with built-in frameworks (because the web developer is stuck with a different version of jQuery built into each targetted browser) so developers would just go about including the latest version of the framework and now you'd not be leveraging what was built-in.
jfriend00
  • 3,572
  • Jfriend00, I would envisage that if the browser didn't have the framework in it's cache it would just use resource included in the document – Deanos Jan 10 '12 at 16:53
  • @Deanos - what would the browser use it for? – jfriend00 Jan 10 '12 at 16:56
    The browser would use it to save making a request, and improve the page performance. – Deanos Jan 10 '12 at 17:02
    Why not have then **every known release** of all popular JS libraries from a common CDN specifically for the browser? This solves the problem of various web apps requiring extremely specific versions of a JS library, and also has the added benefit of actively discouraging developers from including manual hacks within a framework library (which is far too common a practice unfortunately). – maple_shaft Jan 10 '12 at 17:12
    @maple_shaft - how does that help you? Aren't all releases of jQuery on the Google CDN already? What are you asking for beyond that and how does it help you? Doesn't good web design practice already call for using one of the most common CDNs to promote use of a cached version of jQuery? – jfriend00 Jan 10 '12 at 17:32
  • @Deanos - duh, if the browser had the exact right version of jQuery built-in, it could save a page request, but all the issues in my answer still apply. The browser can only build-in the version of jQuery that exists at the time the browser is distributed. From then on, it's out-of-date and the browser cache is how it caches newer versions. – jfriend00 Jan 10 '12 at 17:34
  • @jfriend00 Your solution requires full scale adoption of a best practice, when 90% of javascript developers can barely code a for loop let alone understand that the browser needs to make a seperate request to get their JS file. It may not help you, but it helps me and my bandwidth when my browser doesn't need to download an 800kb specific JS file just to visit a poorly coded webapp. What I call for is different, in that the cached JS libraries downloaded from the common CDN's are more permanent than other temp internet files. This solves the problem for those of us who browse privately too. – maple_shaft Jan 10 '12 at 17:50
  • @maple_shaft - I don't understand what you're proposing. If a web-site not following best practices (since that's what you seem to be talking about) puts a jQuery version on their own site and includes it from there, how is the browser supposed to make that more efficient than it is today? – jfriend00 Jan 10 '12 at 18:10
  • @maple_shaft I like the idea of more permanent caching of certain items. – Deanos Jan 10 '12 at 18:51
  • @jfriend00 - What if the browser was to regulary check for new libraries/items to cache – Deanos Jan 10 '12 at 18:56
    Along with updates, most libraries have open copyrights that allow customization. The web developer, not the client knows which version the page was intended for. – Nilpo Jan 10 '12 at 18:58
    @Deanos - The browser would have to build in very specific knowledge of a few things to look for and where to look for them (like jQuery versions from the Google CDN). It would save a small amount of page load time the first time that resource was needed, but it would use more total bandwidth anytime a cached item or version of that cached item was never needed. I suspect the benefits are relatively small vs. complexity or Google probably would have already tried it in Chrome with their own CDN. Keep in mind that things can live in the disk cache for a long time. – jfriend00 Jan 10 '12 at 19:05
