The use of a managed language like Java, C# etc. has absolutely nothing to do with the way data is accessed from the drive, and in any case it certainly does not deprive developers from an iota of control over precisely how, when, and in what order data will be accessed from the drive.
The problem is elsewhere: managed languages suffer from the overhead of managed-to-native and native-to-managed transitions, where data often need to be copied from native buffers into managed buffers, and from the fact that they do not offer quick and easy support for inherently unsafe operations like picking four bytes from within an array of bytes and interpreting them as an integer. So, when you want to do a thing like that you have to invoke a function that will do the conversion for you, where in C++ you would just use a single machine instruction which dereferences a pointer.
Therefore, an implementation of a B-Tree in a managed language will suffer, but it will not be due to lack of control over precisely how, when, and in what order data is accessed from the drive.
