51
My coworkers tell me there should be as little logic as possible in getters and setters.
Yet, I am convinced that a lot of stuff can be hidden in getters and setters to shield users/programmers from implementation details.
An example of what I do:
public List<Stuff> getStuff()
   if (stuff == null || cacheInvalid())
       stuff = getStuffFromDatabase();
   return stuff;
An example of how work tells me to do things (they quote 'Clean Code' from Uncle Bob):
    return stuff;
public void loadStuff()
How much logic is appropriate in a setter/getter? What's the use of empty getters and setters except a violation of data hiding?
Maarten van Leunen
  • 1,009
    This looks more like tryGetStuff() to me... – Bill Michell Dec 23 '11 at 09:46
    This is not a 'getter'. This term is used for the read accessor of a property, not a method you accidentally put a 'get' in the name. – Boris Yankov Dec 27 '11 at 20:00
    I don't know if that second example is a fair example of this *clean code* book you mention, or someone getting the wrong end of the stick about it, but one thing that brittle mess is not, is clean code. – Jon Hanna Jan 24 '14 at 17:36
  • @BorisYankov Well... _the second_ method is. `public List getStuff() { return stuff; }` – R. Schmitz Apr 01 '19 at 15:40
  • Depending on the exact use case, I like to seperate out my caching into a separate class. Make a `StuffGetter` interface, implement a `StuffComputer` which does the calculations, and wrap it inside an object of `StuffCacher`, which is responsible for either accessing the cache or forwarding calls to the `StuffComputer` that it wraps. – Alexander Apr 03 '19 at 00:15
16 Answers16
75
The way work tells you to do things is lame.
As a rule of thumb, the way I do things is as follows: if getting the stuff is computationally cheap, (or if most chances are that it will be found in the cache,) then your style of getStuff() is fine. If getting the stuff is known to be computationally expensive, so expensive that advertising its expensiveness is necessary at the interface, then I would not call it getStuff(), I would call it calculateStuff() or something like that, so as to indicate that there will be some work to do.
In either case, the way work tells you to do things is lame, because getStuff() will blow up if loadStuff() has not been called in advance, so they essentially want you to complicate your interface by introducing order-of-operations complexity to it. Order-of-operations is pretty much about the worst kind of complexity that I can think of.
Mike Nakis
  • 32,003
  • 76
  • 111
  • 26
    +1 for mentioning the order-of-operations complexity. As a workaround, maybe work will ask me to always call loadStuff() in the constructor, but that would be bad too because it means it will always have to be loaded. In the first example, data is lazily loaded only when needed, which is as good as it can be. – laurent Dec 23 '11 at 09:49
    I usually follow the rule of "if it's really cheap, use a property getter. If it is expensive, use a function". That usually serves me well, and naming appropriately like you indicated to emphasize it seems also good to me. – Denis Troller Dec 23 '11 at 15:37
    if it can fail - it's not a getter. In this case what if the DB link is down? – Martin Beckett Dec 23 '11 at 15:58
  • @Martin Beckett that's a valid concern, and you should have written an answer where we could discuss it. I think that with exceptions, and with Java's ability to publicly declare that a method may throw (see `throws` keyword) failability is not such a big deal in determining whether something should or should not be a getter. But I may be wrong. – Mike Nakis Dec 23 '11 at 16:05
  • @Mike - it was just rule of thumb guideline, no real justification. – Martin Beckett Dec 23 '11 at 17:17
    +1, I'm a bit in shock at how many wrong answers have been posted. Getters/Setters exist to hide implementation details, otherwise the variable should just be made public. – Izkata Dec 23 '11 at 17:20
    Don't forget that requiring the `loadStuff()` function be called prior to the `getStuff()` function also means that the class is not properly abstracting away what is going on under the hood. – rjzii Jan 04 '12 at 15:24
    @Martin: if the DB link is down, it's unlikely the application would have reached this point. And if it does, what can be done about it in the application layer? If recovery is possible, the DAO layer should handle it. Otherwise you may as well throw a RuntimeException and handle it at a high level. – kevin cline Sep 01 '14 at 20:06
  • @Izkata There are languages without properties, AFAIA even Java. In that case a (simple) getter allows binary compatibility with future versions, when e.g. a field needs some validation, or is removed altogether in favour of being calculated on-demand etc etc. – R. Schmitz Apr 01 '19 at 15:50
  • I have **AccommodationService** and **AccommodationBO** view object(POJO). AccommodationBO has the list of **RoomBOs** that not needed in the first place(Lazy loading). There is a method in the AccommodationService that get RoomBOs when needed. The only thing i have to do, call this method in the getter method of the AccommodationBO(passing AccommodationService interface as a constructor parameter). should i do that or use the proxy pattern? – Arash Jan 26 '20 at 10:29
23
Logic in getters is perfectly fine.
But getting data from a database is a whole lot more than "logic". It involves a series of very expensive operations where lots of things can go wrong, and in a non-deterministic way. I'd hesitate do that implicitly in a getter.
On the other hand, most ORMs support lazy loading of collections, which is basically exactly what you're doing.
Michael Borgwardt
  • 51,037
  • 124
  • 176
18
I think that according to 'Clean Code' it should be split as much as possible, into something like:
public List<Stuff> getStuff() {
   if (hasStuff()) {
       return stuff;
   loadStuff();
   return stuff;
private boolean hasStuff() {
    if (stuff == null) {
       return false;
    if (cacheInvalid()) {
       return false;
    return true;
private void loadStuff() {
Of course, this is complete nonsense, given that the beautiful form, which you wrote, does the right thing with a fraction of code that anyone understands at a glance:
   if (stuff == null || cacheInvalid()) {
   return stuff;
It shouldn't be the caller's headache how the stuff is got under the hood, and particularly it shouldn't be the caller's headache to remember to call things in some arbitrary "right order".
Joonas Pulakka
  • 23,534
  • 64
  • 93
    -1. The real headache will be when the caller is stuck figuring out why a simple getter call resulted in a slow-as-hell database access. – Domenic Dec 23 '11 at 14:23
    @Domenic: The database access has to be done anyway, you're not saving anyone performance by not doing it. If you need this `List`, there's only one way to get it. – DeadMG Dec 23 '11 at 14:28
    according to clean code you should write if (hasStuff()) { return stuff; } lodadStuff(); return stuff; – Lukasz Madon Dec 23 '11 at 19:39
    @lukas: Thanks, I didn't remember all the tricks used in 'Clean' Code to make trivial bits of code yet one line longer ;-) Fixed now. – Joonas Pulakka Dec 24 '11 at 08:19
    You are slandering Robert Martin. He would never expand a simple boolean disjunction into a nine line function. Your function `hasStuff` is the opposite of clean code. – kevin cline Sep 01 '14 at 20:11
    I read the beginning of this answer, and I was going to bypass it, thinking "there goes another book worshiper", and then the "Of course, this is complete nonsense" part caught my eye. Well said! C-:= – Mike Nakis Mar 16 '15 at 12:44
They tell me there should be as little logic as possible in getters and setters.
There needs to be as much logic as is necessary to fulfil the needs of the class. My personal preference is for as little as possible, but when maintaining code, you usually have to leave the original interface with the existing getters/setters, but put lots of logic in them to correct newer business logic (as an example, a "customers" getter in a post-911 environment has to meet "know your customer" and OFAC regulations, combined with a company policy prohibiting the appearance of customers from certain countries from appearing [such as Cuba or Iran]).
In your example, I prefer yours and dislike the "uncle bob" sample as the "uncle bob" version requires users/maintainers to remember to call loadStuff() before they call getStuff() - this is a recipe for disaster if any single one of your maintainers forgets (or worse, never knew). Most of the places I've worked in the past decade are still using code that is more than a decade old, so ease of maintenance is a critical factor to consider.
kowsky
  • 103
Tangurena
  • 13,294
  • 65
You are right, your colleagues are wrong.
Forget everyone's rules of thumb about what a get method should or should not do. A class should present an abstraction of something. Your class has readable stuff. In Java it is conventional to use 'get' methods to read properties. Billions of lines of frameworks have been written expecting to read stuff by calling getStuff. If you name your function fetchStuff or anything other than getStuff, then your class will be incompatible with all those frameworks.
You might point them to Hibernate, where 'getStuff()' can do some very complicated things, and throws a RuntimeException on failure.
kevin cline
  • 33,608
  • 71
  • 142
  • Hibernate is an ORM, so the package itself expresses the intent. This intent is not as easily understood if the package itself is not an ORM. – FMJaguar Sep 01 '14 at 00:05
  • @FMJaguar: it's perfectly easily understood. Hibernate abstracts database operations to present a network of objects. The OP is abstracting a database operation to present an object that has a property named `stuff`. Both hide details to make it easier to write the calling code. – kevin cline Sep 01 '14 at 20:15
  • If that class is an ORM class, then the intent is expressed already, in other contexts: the question remains: "How does another programmer know the side effects of calling the getter?". If the program contains 1k classes and 10k getters, a policy that allows database calls in any of them could be trouble – FMJaguar Sep 01 '14 at 20:42
Sounds like this might be a bit of a purist versus application debate that might be affected by how you prefer to control function names. From the applied standpoint, I would much rather see:
List<String> names = clientRoster.getNames();
List<String> emails = clientRoster.getEmails();
As opposed to:
myObject.load();
Or even worse:
myObject.loadNames();
myOjbect.loadEmails();
Which just tends to make other code much more redundant and harder to read because you have to start wading through all of the similar calls. Additionally, calling loader functions or similar breaks the whole purpose of even using OOP in that you are no longer being abstracted away from the implementation details of the object you are working with. If you have a clientRoster object, you shouldn't have to care about how getNames works, as you would if you have to call a loadNames, you should just know that getNames gives you a List<String> with the names of the clients.
Thus, is sounds like the issue is more about semantics and the best name for the function to get the data. If the company (and others) has an issue with the get and set prefix, then how about calling the function something like retrieveNames instead? It says what is going on but doesn't imply that the operation would be instantaneous as might be expected of a get method.
In terms of logic in an accessor method, keep it to a minimum as they are generally implied to be instantaneous with only nominal interaction occurring with the variable. However, that also generally only applies to simple types, complex data types (i.e. List) I find harder to properly encapsulate in a property and generally use other methods for interacting with them as opposed to a strict mutator and accessor.
rjzii
  • 11,274
  • 71
Calling a getter should exhibit the same behavior as reading a field:
  • It should be cheap to retrieve the value
  • If you set a value with the setter and then read it with the getter, the value should be the same
  • Getting the value should have no side-effects
  • It should not throw an exception
Sjoerd
  • 145
    I don't completely agree on this. I agree that it should have no side effects, but I think it's perfectly fine to implement it in a way that differentiates it from a field. Looking at the .Net BCL, InvalidOperationException is widely used when looking at getters. Also, see MikeNakis answer on order-of-operations. – Max Dec 23 '11 at 11:43
  • Agree with all points except the last one. It's certainly possible that getting a value may involve performing a calculation or some other operation that depends on other values or resources which may not have been set. In those cases I would expect the getter to throw some kind of exception. – TMN Dec 23 '11 at 13:14
    @TMN: In a best case scenario the class should be organized in a way such that getters *don't need* to run operations capable of thowing exception. Minimizing the places that can throw exceptions leads to less unexpected surprises. – hugomg Dec 23 '11 at 14:12
  • +1, this is the best answer. Point 2 is huge and often missed. Point 3 is very important as well. I agree on point 4, despite some counterarguments from other commenters; I think if a getter is throwing an `InvalidOperationException` then the API should have been designed differently, so as not to expose that property as a getter. It even looks weird: `try { var x = myFoo.Bar; }` makes no sense---what are you `try`ing to do?---whereas `try { var x = myFoo.FetchBar(); }` says that you're trying to fetch bar. – Domenic Dec 23 '11 at 14:27
    I'm going to disagree with the second point with a specific example: `foo.setAngle(361); bar = foo.getAngle()`. `bar` could be `361`, but it might also legitimately be `1` if angles are bound to a range. – zzzzBov Dec 23 '11 at 15:00
    -1. (1) *is* cheap in this example - after the lazy loading. (2) currently there is no "setter" in the example, but if someone adds one after, and it just sets `stuff`, the getter *will* return the same value. (3) Lazy loading as shown in the example does not produce "visible" side effects. (4) is debatable, maybe a valid point, since introducing the "lazy loading" afterwards *can* change the former API contract - but one has to look at that contract to make a decision. – Doc Brown Jan 11 '15 at 09:06
  • @zzzzBov is spot on here. Logic in a getter/setter should be no more than constraints (or maybe conversions). If there is anything else, it _isn't_ a getter/setter. – Baldrickk Apr 03 '19 at 07:04
A getter which invokes other properties and methods in order to compute its own value also implies a dependency. Eg, if your property has to be able to compute itself, and doing so requires another member to be set, then you have to worry about accidental null-references if your property is accessed in initialization code where all members are not necessarily set.
That doesn't mean 'never access another member that isn't the properties backing field within the getter' it just means pay attention to what you are implying about what the required state of the object is, and if that matches the context you expect this property to be accessed in.
However, in the two concrete examples you gave, the reason I would choose one over the other is entirely different. Your getter is initialized on first access, eg, Lazy Initialization. The second example is assumed to be initialized at some prior point, eg, Explicit Initialization.
When exactly initialization occurs may or may not be important.
For example it could be very very slow, and needs to be done during a load step where the user is expecting a delay, rather than performance unexpectedly hiccuping when the user first triggers access (ie, user right clicks, , context menu appears, user has already right clicked again).
Also, sometimes there is an obvious point in execution where everything that can affect/dirty the cached property value occurs. You may even be verifying that none of the dependencies change and throwing exceptions later on. In this situation it makes sense to also cache the value at that point, even if it isn't particularly expensive to compute, just to avoid making the code-execution more complex and harder to follow mentally.
That said, Lazy Initialization makes a lot of sense in a lot of other situations. So, as often happens in programming its hard to boil down to a rule, it comes down to the concrete code.
James
  • 121
Just do it as @MikeNakis said... If you just get the stuff then it's fine... If you do something else create a new function that does the job and make it public.
If your property/function is doing only what it's name says then there isn't much room for complication left. Cohesion is key IMO
    Be careful about this, you can wind up exposing too much of your internal state. You don't want to wind up with a lot of empty `loadFoo()` or `preloadDummyReferences()` or `createDefaultValuesForUninitializedFields()` methods just because the initial implementation of your class needed them. – TMN Dec 23 '11 at 13:21
  • Sure... I was just telling that if you do what the name states that there shouldn't be many problems... but what you say is absolutly true... – Ivan Crojach Karačić Dec 23 '11 at 14:11
There are more important issues then just "appropriateness" here and you should base your decision on those. Mainly, the big decision here is wether you want to alow people to bypass the cache or not.
  1. First, think about if there is a way to reorganize your code so all necessary load calls and cache management are done in the constructor/initializer. If this is possible you can create a class whose invariant allows you do to the simple getter from part 2 with the safety of the complex getter from part 1. (A win-win scenario)
  2. If you cannot create such a class, decide if you have a tradeoff and need to decide wether you want to allow the consumer to skip the cache-checking code or not.
    1. If it is important that the consumer never skip the cache check and you don't mind the performance penalties, then couple the check inside the getter and make it impossible for the consumer to do the wrong thing.
    2. If it is OK to skip the cache check or it is very important that you are guaranteed O(1) performance in the getter then use separate calls.
As you might have already noted, I am not a big fan of the "clean-code", "split everything into tiny functions" philosophy. If you have a bunch of orthogonal functions that can be called in any order splitting them will give you more expressive power at little cost. However, if your functions have order dependencies (or are only really useful in a particular order) then splitting them only increases the number of ways you can do wrong things, while adding little benefit.
hugomg
  • 2,102
  • -1, constructors should construct, not initialize. Putting database logic in a constructor makes that class completely un-testable, and if you have more than a handful of these your application startup time will become immense. And that's just for starters. – Domenic Dec 23 '11 at 14:28
  • @Domenic: This is a semantic and language-dependent issue. The point that an object is fit to use and provides the appropriate invariants after, and only after, it is fully built. – hugomg Dec 23 '11 at 16:30
Personally, I would expose the requirement of Stuff via a parameter in the constructor, and allow whichever class is instantiating stuff to do the work of figuring out where it should come from. If stuff is null, it should return null. I prefer not to attempt clever solutions like the OP's original because it's an easy way to hide bugs deep inside your implementation where it's not at all obvious what might be going wrong when something breaks.
EricBoersma
  • 2,004
In my opinion, Getters should not have a lot of logic in them. They should not have side effects and you should never get an exception from them. Unless of course, you know what you're doing. Most of my getters have no logic in them and just go to a field. But the notable exception to that was with a public API that needed to be as simple as possible to use. So I had one getter that would fail if another getter hadn't been called. The solution? A line of code like var throwaway=MyGetter; in the getter that depended upon it. I'm not proud of it, but I still do not see a cleaner way to do it
Earlz
  • 22,658
  • 60
This looks like a read from cache with lazy loading. As others have noted, checking and loading may belong in other methods. Loading may need to be synchronized so you don't get twenty threads all loading at the same time.
It might be appropriate to use a name getCachedStuff() for the getter as it won't have a consistent execution time.
Depending on how the cacheInvalid() routine works, the check for null may not be necessary. I wouldn't expect the cache to be valid unless stuff had been populated from the database.
BillThor
  • 6,232
The main logic I'd expect to see in getters that return a list is logic to make sure the list is unmodifiable. As it stands both of your example potentially break encapsulation.
something like:
    return Collections.unmodifiableList(stuff);
as for caching in the getter, I think this would be OK but I might be tempted to move out the cache logic if building the cache took a significant time. i.e. it depends.
jk.
  • 10,216
  • 43
Depending on the exact use case, I like to seperate out my caching into a separate class. Make a StuffGetter interface, implement a StuffComputer which does the calculations, and wrap it inside an object of StuffCacher, which is responsible for either accessing the cache or forwarding calls to the StuffComputer that it wraps.
interface StuffGetter {
     public List<Stuff> getStuff();
class StuffComputer implements StuffGetter {
class StuffCacher implements StuffGetter {
     private stuffComputer; // DI this
     private Cache<List<Stuff>> cache = new Cache<>();
         if cache.hasStuff() {
             return cache.getStuff();
         List<Stuffs> stuffs = stuffComputer.getStuff();
         cache.store(stuffs);
         return stuffs;
This design lets you easily add caching, remove caching, change the underlying derivation logic (e.g. accessing a DB vs returning mock data), etc. It's a bit wordy, but it's worth while for sufficiently advanced projects.
Alexander
  • 3,562
IMHO it is very simple if you use a design by contract. Decide what should your getter provide and just code accordingly (simple code or some complex logic that may be involved or delegated somewhere).
Kemoda
  • 616
  • +1: I agree with you! If the object is just meant to hold some data, then the getters should only return the current content of the object. In this case it is some other object's responsibility to load the data. If the contract says that the object is the proxy of a database record, then the getter should fetch the data on the fly. It can get even more complicated if the data has been loaded but is not up to date: should the object be notified of changes in the database? I think there is no unique answer to this question. – Giorgio Jan 04 '12 at 15:35
