Here is a starting point/idea for the design:
// Your framework probably provides this
class Point {
private int x, y; // x,y coordinates of top left of View
// Your framework probably provides something like this
/** Container class for all other types */
abstract class MindMapView {
public MindMapView(int width, int height, Point position) {
// Initialize fields
/** Top-Left */
private Point mPosition;
/** Width, Height */
private int mWidth, mHeight; // Width and height of view
/** Implement this to fulfill a request to draw the view on the screen */
abstract void onDraw();
/** Implement this to fulfill a request to move the view across the screen */
abstract void onMove(Point delta);
/** Implement this to fulfill a request to resize the view */
abstract void onResize(int width, int height);
Implement this to fulfill a request to drag this view. Can be similar
to onMove, except you will want to hook the point where the view is
"dropped", which would be the last point in the drag.
We'd consider a drag to be a left mouse click, mouse movement, and mouse
un-click.
abstract void onDrag(Point delta);
/** Called by other classes that desire to draw this View */
public final void draw() {
onDraw();
/** Called by other classes that desire to move this view */
public final void move(Point delta) {
onMove(delta);
/** Called by other classes that desire to resize this view */
public final void resize() {
onResize();
public final void drag(Point delta) {
onDrag(delta);
public Point getPosition() {
return mPosition;
You will hook your framework to funnel the various events into this view, but more than likely, your framework has a similar class ready for you.. Once you have that, you can extend it to make your other elements
Much like MindMapView, except it can contain other MindMapViews
abstract class MindMapContainer extends MindMapView {
private ArrayList<MindMapView> mViews;
public ArrayList<MindMapView> getViews() {
return mViews;
public MindMapThought(...) {
super(...);
public void addView(MindMapView view) {
mViews.add(view);
public void removeView(int index) {
// Subclasses must call super() if these are overridden!
@Override
protected void onMove(Point delta) {
for (MindMapView view : mViews) {
view.move(delta);
// Do similar for the following
implement onDraw();
implement onResize(int width, int height);
implement onDrag(Point delta);
Once you have the base classes defined, you can LOOP over each sub-view to move it along with the others
public class MindMapThought extends MindMapView {
@Override
protected void onDraw() {
canvas.draw(...);
implement onMove(Point delta);
Finally, you can create something that moves as a group
public class MindMapThoughtContainer extends MindMapViewContainer {
MindMapThought thought1 = new MindMapThought();
MindMapThought thought2 = new MindMapThought();
MindMapThoughtContainer thoughts = new MindMapThoughtContainer();
thoughts.add(thought1);
thoughts.add(thought2);
Point delta = new Point(5,5);
// Move the thoughts container, its' onMove event will iterate its sub-views
// and move them along by the same delta
thoughts.move(delta);
You can have any number of concrete (actual implementations) types as long as they extend MindMapView so that they use the same interface.
As for the specifics of wiring up the design, consult your frameworks documentation.
