I am planning to use boost libraries, as it is quiet rich, and will save lots of time. But my question is, what are the guidelines i have to follow, so that
  1. I can replace some part of boost with standard C++ as and when they are supported, considering so many new features are coming in C++11.
  2. Also, how to encapsulate them in a way so that i have to change least when i change platform/compiler/boost version.
  3. Also is there a category which suggest, which portion of the library to use and avoid, considering stability and standard.
Jalayn
  • 9,789
  • 39
  • 58
rakesh
  • 151
For questions 1 and 2 the answer is relatively straightforward through boost itself - the boost::tr1 library wraps the original "TR1" (technical report 1 I think) parts of the C++11 standard in a way that you will get your native implementation if it's available or the boost implementation if it's not, in the std::tr1 namespace.
For 3: all libraries in boost are quite stable, though some are not ideal (boost::python has memory leaks when embedding python, for example), and some are very complex (spirit, MPL) and you may want to avoid them for those reasons.
Joris Timmermans
  • 8,998
  • 60
