36
I am new to Java; through my studies, I read that reflection is used to invoke classes and methods, and to know which methods are implemented or not.
When should I use reflection, and what is the difference between using reflection and instantiating objects and calling methods the traditional way?
apaderno
  • 4,014
  • 42
  • 53
Hamzah khammash
  • 481
    Check out http://stackoverflow.com/questions/37628/what-is-reflection-and-why-is-it-useful – Jalayn Dec 08 '11 at 08:47
    Please do your share of research before posting. There is lots of material on StackExchange (as @Jalayn noted) and the web in general about reflection. I suggest you read e.g. the [Java Tutorial on Reflection](http://docs.oracle.com/javase/tutorial/reflect/) and come back after that if you have any more concrete questions. – Péter Török Dec 08 '11 at 08:49
    There has got to be a million dupes. – DeadMG Dec 08 '11 at 08:53
    More than a few professional programmers would answer "as rarely as possible, maybe even never." – Ross Patterson Apr 02 '13 at 23:30
  • This article provides an example of how to improve your code using Reflection: https://levelup.gitconnected.com/write-dry-code-using-reflection-e4b9bd8581ea It's in C#, but the concepts are exactly the same. – David Klempfner Dec 02 '20 at 11:44
6 Answers6
44
  • Reflection is much slower than just calling methods by their name, because it has to inspect the metadata in the bytecode instead of just using precompiled addresses and constants.
  • Reflection is also more powerful: you can retrieve the definition of a protected or final member, remove the protection and manipulate it as if it had been declared mutable! Obviously this subverts many of the guarantees the language normally makes for your programs and can be very, very dangerous.
And this pretty much explains when to use it. Ordinarily, don't. If you want to call a method, just call it. If you want to mutate a member, just declare it mutable instead of going behind the compile's back.
One useful real-world use of reflection is when writing a framework that has to interoperate with user-defined classes, where the framework author doesn't know what the members (or even the classes) will be. Reflection allows them to deal with any class without knowing it in advance. For instance, I don't think it would be possible to write a complex aspect-oriented library without reflection.
As another example, JUnit used to use a trivial bit of reflection: it enumerates all methods in your class, assumes that all those called testXXX are test methods, and executes only those. But this can now be done better with annotations instead, and in fact JUnit 4 has largely moved to annotations instead.
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
    "More powerful" needs care. You don't need reflection to get Turing completeness, so no computation ever needs reflection. Of course Turing complete says nothing about other kinds of power, like I/O capabilities and, of course, reflection. –  Dec 08 '11 at 09:11
    Reflection is not necessarily "much slower". You can use reflection once to generate a direct calling wrapper bytecode. – SK-logic Dec 08 '11 at 10:57
    You'll know it when you need it. I often wondered why (outside of language generation) one would need it. Then, suddenly, I did... Had to walk up and down parent/child chains to peek/poke data when I got panels from other devs to pop into one of the systems I maintain. – Brian Knoblauch Dec 08 '11 at 13:41
  • @SK-logic: actually for generating bytecode you don't need reflection at all (indeed reflection contains no API for bytecode manipulation at all!). – Joachim Sauer Oct 22 '12 at 11:19
    @JoachimSauer, of course, but you'll need a reflection API to *load* this generated bytecode. – SK-logic Oct 22 '12 at 15:29
  • _"One useful real-world use of reflection is when writing a framework that has to interoperate with user-defined classes"_ - isn't that exactly what interfaces are meant for? – Aloso Mar 29 '17 at 14:03
  • Interfaces allow someone to pass you an instance of a user-defined class but if you want to actually load a class file of disk, then instanciate the class you loaded from it then you need reflection. – Peter Green Oct 10 '17 at 14:29
  • Junit is an example of "a framework that has to interoperate with user-defined classes", is it not? – bdsl Dec 06 '18 at 14:56
  • I love this answer; I just wish it had a blurb about avoiding reflection using configurations using lambdas. Like, give me an object with a list of `Function`, aka member accessors, for getting values or `BiConsumer` for setting them. Then even 3rd party libraries like ORMs can be configured without the use of reflection. I think functional programming helps a lot here. – Travis Parks Dec 18 '20 at 01:01
  • To be fair, Java lambdas were a couple of years in the future when I wrote this :-) – Kilian Foth Dec 18 '20 at 07:35
19
I was like you once, I didn't know much about reflection - still don't - but I did use it once.
I had a class with two inner classes, and each class had lots of methods.
I needed to invoke all of the methods in the inner class, and invoking them manually would've been too much work.
Using reflection, I could invoke all these methods in just 2-3 lines of code, instead of the number of the methods themselves.
Mahmoud Hossam
  • 3,817
  • 41
16
I'd group uses of reflection into three groups:
  1. Instantiating arbitrary classes. For example, in a dependency injection framework, you probably declare that interface ThingDoer is implemented by the class NetworkThingDoer. The framework would then find the constructor of NetworkThingDoer and instantiate it.
  2. Marshalling and unmarshalling to some other format. For example, mapping an object with getters and settings that follow the bean convention to JSON and back again. The code doesn't actually know the names of the fields or the methods, it just examines the class.
  3. Wrapping a class in a layer of redirection (perhaps that List isn't actually loaded, but just a pointer to something that knows how to fetch it from the database) or faking a class entirely (jMock will create a synthetic class that implements an interface for testing purposes).
Kevin Peterson
  • 429
  • This is the best explanation of reflection I've found on StackExchange. Most answers repeat what the Java Trail says (which is "you can access all these properties", but not why you would), provide examples of doing things with reflection that are much easier to do without, or give some vague answer about how Spring uses it. This answer actually gives three valid examples that CANNOT easily be worked around by JVM without reflection. Thank you! – ndm13 Jan 11 '18 at 02:28
Fundamentally, reflection means using the code of your program as data.
Therefore, using reflection might be a good idea when your program's code is a useful source of data. (But there are trade-offs, so it might not always be a good idea.)
For example, consider a simple class:
public class Foo {
  public int value;
  public string anotherValue;
and you want to generate XML from it. You could write code to generate the XML:
public XmlNode generateXml(Foo foo) {
  XmlElement root = new XmlElement("Foo");
  XmlElement valueElement = new XmlElement("value");
  valueElement.add(new XmlText(Integer.toString(foo.value)));
  root.add(valueElement);
  XmlElement anotherValueElement = new XmlElement("anotherValue");
  anotherValueElement.add(new XmlText(foo.anotherValue));
  root.add(anotherValueElement);
  return root;
But this is a lot of boilerplate code, and everytime you change the class, you have to update the code. Really, you could describe what this code does as
  • create an XML element with the name of the class
  • for each property of the class
    • create an XML element with the name of the property
    • put the value of the property into the XML element
    • add the XML element to the root
This is an algorithm, and the algorithm's input is the class: we need its name, and the names, types and values of its properties. This is where reflection comes in: it gives you access to this information. Java allows you to inspect types using the methods of the Class class.
Some more use cases:
  • define URLs in a webserver based on a class's method names, and URL parameters based on the method arguments
  • convert the structure of a class into a GraphQL type definition
  • call every method of a class whose name starts with "test" as a unit test case
However, full reflection means not only looking at existing code (which by itself is known as "introspection"), but also modifying or generating code. There are two prominent use cases in Java for this: proxies and mocks.
Let's say you have an interface:
public interface Froobnicator {
  void froobnicateFruits(List<Fruit> fruits);
  void froobnicateFuel(Fuel fuel);
  // lots of other things to froobnicate
and you have an implementation that does something interesting:
public class PowerFroobnicator implements Froobnicator {
  // awesome implementations
And in fact you have a second implementation too:
public class EnergySaverFroobnicator implements Froobnicator {
  // efficient implementations
Now you also want some log output; you simply want a log message whenever a method is called. You could add log output to every method explicitly, but that would be annoying, and you'd have to do it twice; once for each implementation. (So even more when you add more implementations.)
Instead, you can write a proxy:
public class LoggingFroobnicator implements Froobnicator {
  private Logger logger;
  private Froobnicator inner;
  // constructor that sets those two
  public void froobnicateFruits(List<Fruit> fruits) {
    logger.logDebug("froobnicateFruits called");
    inner.froobnicateFruits(fruits);
  public void froobnicateFuel(Fuel fuel) {
    logger.logDebug("froobnicateFuel( called");
    inner.froobnicateFuel(fuel);
Again, though, there is a repetitive pattern that can be described by an algorithm:
  • a logger proxy is a class that implements an interface
  • it has a constructor that takes another implementation of the interface and a logger
  • for every method in the interface
    • the implementation logs a message "$methodname called"
    • and then calls the same method on the inner interface, passing along all arguments
and the input of this algorithm is the interface definition.
Reflection allows you to define a new class using this algorithm. Java allows you to do this using the methods of the java.lang.reflect.Proxy class, and there are libraries that give you even more power.
So what are the downsides of reflection?
  • Your code becomes harder to understand. Your are one level of abstraction further removed from the concrete effects of your code.
  • Your code becomes harder to debug. Especially with code-generating libraries, the code that is executed may not be the code that you wrote, but the code you generated, and the debugger may not be able to show you that code (or let you place breakpoints).
  • Your code becomes slower. Dynamically reading type information and accessing fields by their runtime handles instead of hard-coding access is slower. Dynamic code generation can mitigate this effect, at the cost of being even harder to debug.
  • Your code may become more fragile. Dynamic reflection access is not type-checked by the compiler, but throws errors at runtime.
Sebastian Redl
  • 14,950
  • 51
Reflection allows a program to work with code that may not be present and do so in a reliable way.
"Normal code" have snippets like URLConnection c = null which by its sheer presence cause the class loader to load the URLConnection class as part of loading this class, throwing a ClassNotFound exception and exiting.
Reflection allow you to load classes based on their names in string form and test them for various properties (useful for multiple versions outside your control) before launching actual classes that depend on them. A typical example is the OS X specific code used to make Java programs look native under OS X, which are not present on other platforms.
Reflection can automatically keep parts of your program in sync, where previously, you would have had to manually update your program to use the new interfaces.
DeadMG
  • 36,794
  • 70
  • 139
    The price you pay in this case is that you lose type-checking by the compiler and refactor-safety in the IDE. It's a trade-off that I'm not willing to make. – Barend Jan 06 '12 at 09:42
