Spaces should always be used, because tabs alone aren't sufficiently flexible for many styles, and intermixing tabs and spaces (nearly) always produces an absolute mess.
For an example of one style that generally needs spaces, consider something like:
call_some_function(parameter1,
parameter2,
parameter3,
parameter4,
parameter5,
parameter6,
parameter7);
Unless you're willing to re-name all your functions to be an exact multiple of the tab size (minus one for the parenthesis) tabs alone simply won't do this.
As to mixing tabs and spaces, you almost immediately run into a serious problem: tabs are not consistently expanded the same way. Some software treats a tab as equivalent to a specific number of spaces. Other software will expand a tab modulo a specific number of spaces -- e.g., an item after a tab will always start at a column number that's a multiple of (say) 8.
Even if you can ensure against spaces getting mixed with your tabs, you still have a problem: tabs also play poorly with variable-width fonts. This problem arises when (for example) you want aligned trailing comments:
a.m = 9; // this is the slope
a.i = 4; // this is the intensity
a.x = 1; // this is the x-intercept
As they stand right now, those all line up perfectly. Viewed with a variable width font, however, things get ugly. With spaces, the comments may (often will) get slightly mis-aligned. With tabs, however, the misalignment often becomes quite radical:
Suddenly the small difference in width between the 'i' and the 'm' or 'x' in our variable-width font has been magnified to an entire tab stop.
The bottom line is that almost any change in how you view code with tabs, no matter how seemingly trivial, can and usually will produce an unreadable mess.
To answer your other questions: other have already pointed it out, but I can't imagine anybody in a programming editor (or much of anything else) actually using the space bar to insert the spaces, so your question about: "typing spacespacespacespace" is irrelevant because nobody does that to anyway. Likewise with back-spacing: it's hard to imagine an editor that would require pressing BkSpc four times to go to a previous tab stop, so (again) the question is irrelevant.
Bottom line: tabs are fine if you (and only you) will ever look at your code, and you only ever do so with a single editor that you never reconfigure (at all!) Those conditions, however, are so close to impossible to enforce that there's only one reasonable answer: never use tabs at all.
