Possible Duplicate:
When are Getters and Setters Justified
Why exactly is having public and private accessors like these:
private string foo;
public string Foo
    get
        return foo;
    set
        foo = value;
considered better than just having public ones like this:
public string Foo;
The end result seems to be the same.
Tom Squires
  • 17,695
  • 67
  • 88
  • In which language? In Python for instance it isn't. –  Nov 18 '11 at 16:56
  • Im using c#. Edited to clarify – Tom Squires Nov 18 '11 at 16:57
  • Also see [Getters and Setters in functional languages](http://programmers.stackexchange.com/questions/96429/getters-and-setters-in-functional-languages) for the functional side of things. –  Nov 18 '11 at 17:31
  1. Properties do not have the same semantics as public variables:
  • Reflection works differently on variables vs. properties, so if you rely on reflection, it's easier to always use properties.
  • You can't databind against a variable.
  • Changing a variable to a property is a breaking change, if you decide you want to add validation or other logic later.
  1. Automatic properties make it easier to use public properties exclusively.
Glorfindel
  • 3,137
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
So you can protect the internal state of your classes.
You can set the property to have validation happen during set (some argue this should be done with a method)
You can hide variables that the user of the class should never see nor modify.
I don't care about your internal counter, or whatever other variables you need. And modifying certain variables in a class will completely break it.
CaffGeek
  • 8,033
  • 32
  • 38
    The OP is referring to the common case of exposing a private field via a public property, without validation logic. He wonders, why not just make the field public? The property is not hiding anything, and no internal state is being protected. – Robert Harvey Nov 18 '11 at 17:29
  • Ah, I misunderstood. However, they ARE still different as you outlined in your reply. I've +1'd your response. – CaffGeek Nov 18 '11 at 17:39
In this example it's proabably not any advantage, but when systems get large and complex it can really come in useful to restrict a classes "access points".
Martin
One reason might be that you want to perform some validation or additional operations in the setter.
(Sorry mis-read this first, have edited my answer)
Alb
  • 3,359
