This came up in code review at work in context of PHP and @
operator. However I want to try keep this in more generic form, since few question about it I found on SO got bogged down in technical specifics.
Accessing array field, which is not set, results in error message and is commonly handled by following logic (pseudo code):
if field value is set
output field value
Code in question was doing it like:
start ignoring errors
output field value
stop ignoring errors
The reasoning for latter was that it's more compact and readable code in this specific case. I feel that those benefits do not justify misuse (IMO) of language mechanics.
Is such code is being "clever" in a bad way?
Is discarding possible error (for any reason) acceptable practice over explicitly handling it (even if that leads to more extensive and/or intensive code)?
Is it acceptable for programming operators to cross boundaries of intended use (like in this case using error handling for controlling output)?
Edit
I wanted to keep it more generic, but specific code being discussed was like this:
if ( isset($array['field']) ) {
echo '<li>' . $array['field'] . '</li>';
vs the following example:
echo '<li>' . @$array['field'] . '</li>';
