14
We have been slowly replacing batch command files (windows .bat) which were simply jarring up the classes compiled in the developers IDE, with more comprehensive Ant builds (i.e. get from CVS, clean compile, jar, archive, email, etc.)
I've spent a lot of time learning (and debugging issues) with Ant, so I'm most comfortable using it for these tasks. But I wonder if Ant is still in as wide usage as it was when I first started learning, or whether "the world has moved on" to something newer (and maybe slicker). (I've started to see more Maven build stuff distributed, which I've never used, for example.)
The practical import of this question, is whether I push new developers to learn Ant, or whether they should be learning something else for builds?
I'm never too on top of the trends, so it would be great to hear from other Java developers what they think is the best build tool, and what they think new developers should be learning.
Anthony Mastrean
  • 337
Sam Goldberg
  • 1,004
  • Read all the answers below and they were all great! Thanks for the insights into what improvements Maven offers over Ant. I will be looking into Maven. – Sam Goldberg Nov 17 '11 at 18:28
  • It is very few projects that are simple enough not to require tons of scripting for ant. Maven handles a lot of these things in a standard way. –  Nov 17 '11 at 23:19
  • Ant is basically a shell script in XML (and using Ant commands instead of shell commands). – user253751 Jun 30 '16 at 04:10
  • Ant is an incredible waste of time. Even when maven was terrible it was a smarter choice. Ant has no way of being integrated into an IDE and Java projects are a huge mess of files - you spend 30% of your time just jumping from file to file. – bryan hunt Sep 13 '17 at 20:21
  • @bryanhunt: we ended up using Maven for all new projects. However, I haven't found a nice way for Maven to create a deployment package for Java apps. (It's fine for copying dependencies, uploading jar.) Most of the posts I read that answer how to do it, say to use the Ant plugin. So I find I am using Ant to groom the final output from Maven. And it seems way easier to do it in Ant than to use the Maven Assembly plugin. – Sam Goldberg Sep 13 '17 at 21:02
  • @samgoldberg what was the issue with the assembly plugin? Got a link to your project? – bryan hunt Sep 27 '17 at 08:35
  • @bryanhunt: there wasn't any issue with the assembly plugin. I generally try to generate a standard directory structure (root, lib, scripts, logs) at the end of each build. From past projects (a long time ago), I remember it required writing a separate assembly descriptor xml to do this, and this xml just seemed more complicated than the equivalent ant build xml. So I ended up adding an ant task to Maven build to create directories and copy the files. Maybe it is just my lack of familiarity with the assembly descriptors? – Sam Goldberg Oct 18 '17 at 13:57
  • @samgoldberg I see this very often. I would literally just build a fat jar with a couple of cli flags - config file location (better still if it doubles up as logging config) - and an optional logging config file location (log4j.properties or similar). Then either hand off to DevOps to build apt/rpm packages, use an abstraction written in ruby/whatever or do it yourself. I've been down this route before, found your get zero respect for trying to build the packaging abstraction in Java. Better to let the system tools handle it for you. – bryan hunt Oct 19 '17 at 23:13
  • This guy explains it much better than I (at 12:30 am) can https://stackoverflow.com/a/11410078/2646250 – bryan hunt Oct 19 '17 at 23:26
I agree with others here that Maven seems to have taken over most significant projects that I've looked at.
While Ant is highly flexible, the build file is not standardized, so when you move to a new project or company, the targets are named differently, the file is structured differently, the inter-target dependencies may or may not be established, etc.
With Maven, you also get the benefit of not having to carry binary dependencies (I'm talking about jars) around in your SCM system. Lots of other great Java tools know how to read a Maven POM file (the benefit of standardization), so tools like IDEs can set up a Maven project very quickly, and build tools like Jenkins can easily execute Maven builds.
RonU
  • 548
    I should also add that using Maven makes our projects IDE-agnostic, and if you've ever been in a shop that had IDE wars, you can appreciate eliminating this religious battle! – RonU Nov 17 '11 at 16:35
I've been working with Ant and with Maven. In my experience, Maven has a very strong edge over Ant.
  • All the projects I've seen last 2 or 3 years seem to be using maven. About 3 years ago this made me wonder because maven versions used then (2.0.something) seemed to be quite unreliable and buggy. At some point though (2.1 or 2.2 I don't recall) maven became reliable and after some time spent with it I have changed my mind to opposite. Now, I'd rather be surprised seeing someone who prefers ant over maven.
On a less positive note about maven, my experience with its documentation was not so great so far. I think I've seen a product with documentation worse than that of maven but I can't remember which one (some ancient CSV library iirc).
gnat
  • 21,442
  • 112
  • 288
    Dunno, I found the [Maven Reference](http://www.sonatype.com/books/mvnref-book/reference/) quite decent. It is not perfect, and there are dark undocumented corners indeed, but still IMHO it is significantly better than the average. – Péter Török Nov 17 '11 at 16:13
  • @PéterTörök right _Maven Reference_ is my first aid too. Somehow though most of the stuff that worries me happens to end in these _dark undocumented corners_. To be precise I find these corners more "dark" than "undocumented" - I mean I feel the knowledge is there but I fail to decipher it. I dunno maybe I am unlucky. Or maybe dumb. Or maybe Maven guys just lack a decent tech writer in their gang – gnat Nov 17 '11 at 16:36
    Why, have you ever seen an open source project which *had* a decent tech writer? ;-) – Péter Török Nov 17 '11 at 17:20
  • @PéterTörök so true! :) The luxury of popular OSS projects is that there are a lot of expert guys around who "replace" doc writer. To me that was the case with Maven - there always have been some guru around whom I could ask about tricky things – gnat Nov 17 '11 at 17:56
We've been using Maven for several years. It supports Ant scripting (just like Ant supports BeanShell), so your Ant knowledge may still be useful. Maven is much more powerful, but it has some additional infrastructure requirements (you'll want an Artifactory or Nexus server to host your builds if you share components among multiple projects). It's also quite different from Ant, so you can't leverage a lot of your existing knowledge.
TMN
  • 11,313
I think Ant on its own is dead in the water; having to specify all of your classpath dependencies manually (depending on your setup) is far too manual and far to error prone. If Ant is used alongside a dependency management tool, such as Ivy, then it retains it's power and removes the need to manually manage your dependencies.
The other problem with Ant when compared to Maven is the lack of standardization, which has been mentioned in other answers. When moving from project to project or job to job, one of the most annoying things I find is having to learn the new standard for different Ant files. Maven's aim of convention over configuration means that two different projects will have very similar structure, making transition between them much easier than with Ant.
As for whether Ant is still mainstream or not, it will depend on the development environment you are working in. If the project is in a small company or a start-up, I would imagine Maven would be the natural choice and time can be taken to invest in the infrastructure, such as an Artifactory. However, large companies will have invested many years and lots of money into their Ant infrastructure (configurations, global build files etc) which will mean they will be less keen on moving away from a technology in which they have invested so much money.
Richard
  • 1,868
Maven has been on the rise for many years, and now I need to learn it. Things will always be changing, and to know that Ant is losing its position is not a bad thing.
Maven may only be the up and comer for a short time, but if it makes our job easier, then it is worth investing the time to learn.
Jon Shanks
