I'm intrested to know if there exists a tool that lets you input examples of valid documents and lets you then generalize from that to a reusable parser.
I can imagine this, but everytime i start learning about parsers it gets to the granularity of something like lex and yacc and it seems more complicated than my instincts say it should be.
So I'm left wondering if
  • a) it's just fundamentally that complicated and I need to see it or
  • b) there's a way to build ad-hoc DSLs for relatively simple tasks that I could learn about
Update: a simple example of an "ad hoc" dsl i might like to make quickly.
Instead of the XML
<foo>
  <item>bar</item>
  <item>bat</item>
</foo>
I might want something like:
foo
  bar
  bat
  • lines contain data items
  • indentation produces parent-child relations
My imaginary tool lets me convey the above information.
Then, in my imaginary tool, I might highlight "foo" above and right click, at which point it would prompt me to restrict the values to a choice list....
Then I might extend the first one to:
foo
  bar(5)
  bat
  • in a line, '(' and ')' surround a sub item
The above might be qualified with a boolean value that specifies recursion or not, if set to true then bar(lala(4)) might work...
This is the kind of train of thought I generally have that led me to ask the question. It's possible that now I've qualified it, the answer changes - if so I apologize in advance.
Aaron Anodide
  • 5,463
You cannot practically build a parser for a real computer language (or DSL) by just showing it examples. Learning anything by just positive examples is pretty hard (as is well known by the machine learning community); you need at least some negative examples. Pretty much you want parsers to be able to accept alternatives. If you allow them, a simple disjunctive generalization that accepts just the set of positive examples and rejects everything else works just fine but isn't useful (e.g., a "parser" for the strings "QA" "BZQ1" and "RQ" would be just "QA" | "BZQ1" | "RQ").
This article talks about machine learning to induce grammars from data. It doesn't say much about practicality. No tool I have ever seen has been effective at doing this in a general way, and the differences between "legal" and "not legal" can be incredibly subtle. Imagine trying to learn what were valid C++ programs according to the C++ standard, and rejecting the ones that MS allows that aren't legal. Even the programmers pretty much can't do this, and the C++ standards committee argues endlessly about the tricky cases.
Frankly, if you have EBNF, writing down a grammar for a DSL is generally fairly easy... if you know what the DSL should allow. Writing down a grammer that works for most parser generators is relatively hard, because they only accept limited versions of EBNF (eg., LL(k), LALR(1), ...). You can make this a lot easier by using a full context-free parsing engine such as a GLR parser which doesn't have such restrictions.
Our DMS Software Reengineering Toolkit has such a GLR parser generator, and easily accepts context free grammars. It seemingly does the impossible of parsing C++ with a straightforward BNF (the GNU folks had to build a terribly hacked LALR parser to do this for GCC); it is possible because there are context-free grammars for C++, just look in the standard!.
But parsing is just the easy part. You shouldn't spend your energy there. You need more machinery to process the DSL: building ASTs, inspecting for special cases, transforming to a target language, optimizing the code.
DMS is good for building DSLs not only because it can accept descriptions of DSLs relatively easily, but because it has most of that vast amount of machinery for processing (analyzing/transforming/...) that DSL that you will need, after you succeed in parsing.
Ira Baxter
  • 1,910
  • i actually updated my question with a few examples - as noted, sorry if that changes the answer at all - i'll edit it if it's too off... – Aaron Anodide Nov 10 '11 at 04:36
  • oh while i actually have someone's attention who knows this stuff - is there a type of parser that uses a set of competing recognizers and a state machine that takes recognition events as input and produces weights for the recognizers as outputs? so everything that can be recognized is always being looked for but only the things that are valid have non-zero weights? – Aaron Anodide Nov 10 '11 at 04:42
    I think what you are looking for is called a "lexer generator". These tools take a set of regular expressions which in effect define the "events" of interest ("this type of character string" for many types that you might define, e.g, numbers, names, ...) and combine them in an efficient finite state automaton that can tell which (or how many) of the regular expressions triggered at any point in the input stream. This is standard machinery that most parser generators use to recognize the tokens that make up the language the parser is trying to recognize. – Ira Baxter Nov 10 '11 at 05:05
DSL can be divided to 2 groups:
a) external like (mostly) write Ira Baxter: build NEW parser etc ... implement semantic
b) internal: use subset / over-set (library extensions) of real language. Then use have no-choice about syntax, must accept general syntax rule of hosting language.
Example of internal DSL in java. Copied from bigger project:
BackupService.open().setAdminEmail("aaa@yyy.ccc")
.setDatabase("xddasdas;user;pass").pefrorm().zip().transfer("sftp...).finish();
Read "evangelism" in Groovy Language community.
http://www.groovy-lang.org/dsls.html
and sample a. Xml Builder, is very near to Your idea
http://www.groovy-lang.org/processing-xml.html#_creating_xml
Jacek Cz
  • 101
Not in the general case, for the reasons given by Ira Baxter. However, this is a pretty good description of how docopt works: you give it examples of what valid command-line arguments to your program should look like, and it generates a command-line argument parser from those examples.
Mason Wheeler
  • 82,151
  • 234
  • 309
