150
Is this an antipattern? It is an acceptable practice?
    try {
        //do something
    } catch (Exception e) {
        try {
            //do something in the same line, but being less ambitious
        } catch (Exception ex) {
            try {
                //Do the minimum acceptable
            } catch (Exception e1) {
                //More try catches?
Mister Smith
  • 2,867
  • Can you give us us case for this? Why can't you handle every error type in the top level catch? – Morons Nov 09 '11 at 16:43
    I've seen this kind of code recently, performed by unexperienced programmers who don't really know what they are calling inside the try blocks, and they don't want to bother testing the code. In the code sample I've seen, It was the same operation but performed each time with fallback parameters. – Mister Smith Nov 09 '11 at 16:50
  • @LokiAstari -Your example is a try in the Finally Section.. Where there is no Catch. This is a nested in the Try section.. It's different. – Morons Nov 09 '11 at 17:50
    Why should it be an anti-pattern? –  Apr 09 '12 at 21:40
    +1 for "more try catches?" – JoelFan Apr 09 '12 at 22:11
  • It's not an antipattern, it's only ugly. – Thomas Junk Jun 06 '15 at 07:03
  • I have a situation where I am working in an EJB. Every exception that gets thrown out of the EJB gets wrapped in an EJB Exception, and the real cause ends up halfway down a 500 line stack track. Java prohibits you from having a multiple exception catch with the catch-all Exception. I am going to wrap important sections in a try-catch as you proceed through the process method, then catch the exception to report the specific issue, then rethrow it to the outer exception handler. – David Oct 29 '15 at 18:54
13 Answers13
127
This is sometimes unavoidable, especially if your recovery code might throw an exception.
Not pretty, but sometimes there are no alternatives.
Oded
  • 53,326
  • 166
  • 181
  • if you do the try catch one after another then surely the code inside the second try will be executed even if the first catch clause is not invoked? – AndrewC Nov 09 '11 at 16:35
  • @AndyC - And if your nested `catch` throws? – Oded Nov 09 '11 at 16:38
    Yes this is sort of what I was trying to get at. Of course there comes a point in your nested try/catch statements where you just have to say enough is enough. I was making a case for nesting as opposed to sequential try/catch's, saying that there are situations where you only want the code inside the second try to execute if the first try falls over. – AndrewC Nov 09 '11 at 16:40
  • @Oded Even if the second catch throws, i don't see why it can't be done sequentially. Of course, it would need some boolean flags to check if the previous try-catch succeeded. – Mister Smith Nov 09 '11 at 16:53
  • @MisterSmith - If the point of nesting `try{}catch{}` blocks is to avoid bubbling the exception, then having a nested `catch{}` throw will not work. – Oded Nov 09 '11 at 16:58
    @MisterSmith: I'd prefer nested try-catches to sequential try-catches that are partially controlled with flag variables (if they were functionally the same). – FrustratedWithFormsDesigner Nov 09 '11 at 17:11
  • 43
    try{ transaction.commit(); } catch { try{ transaction.rollback(); } catch { seriouslogging() } notsoseriouslogging(); } is an example of a necessary nested try catch – Thanos Papathanasiou Nov 09 '11 at 17:16
  • A good exemple of such place is logging an error. First you try to log it into DataBase if it fail you log it to a file – Rémi Jun 25 '14 at 16:00
    At least extract the catch block to a method, guys! Let's at least make this readable. – Mr Cochese Jun 25 '14 at 18:01
65
I don't think its an antipattern, just widely misused.
Most nested try catch's are indeed avoidable and ugly as hell, but there are times you can't help it.
try {
} catch {
    logerror();
    try {
    } catch {
        seriousLogging();
Also, you'll need an extra bool somewhere to signify the failed rollback...
  • 2,462
It's okay. A refactoring to consider is pushing the code into its own method, and using early exits for success, letting you write the different attempts to do something at the same level:
try {
    // do something
    return;
    // fall through; you probably want to log this
try {
    // do something in the same line, but being less ambitious
    return;
    // fall through again; you probably want to log this too
try {
    // Do the minimum acceptable
    return;
    // if you don't have any more fallbacks, then throw an exception here
//More try catches?
Once you have it broken out like that, you could think about wrapping it up in a Strategy pattern.
interface DoSomethingStrategy {
    public void doSomething() throws Exception;
class NormalStrategy implements DoSomethingStrategy {
    public void doSomething() throws Exception {
        // do something
class FirstFallbackStrategy implements DoSomethingStrategy {
class TrySeveralThingsStrategy implements DoSomethingStrategy {
    private DoSomethingStrategy[] strategies = {new NormalStrategy(), new FirstFallbackStrategy()};
        for (DoSomethingStrategy strategy: strategies) {
            try {
                strategy.doSomething();
                return;
                // log and continue
        throw new Exception("all strategies failed");
Then just use the TrySeveralThingsStrategy, which is a kind of composite strategy (two patterns for the price of one!).
One huge caveat: don't do this unless your strategies are themselves sufficiently complex, or you want to be able to use them in flexible ways. Otherwise, you're larding a few line of simple code with a huge pile of unnecessary object-orientation.
Tom Anderson
  • 3,022
The logic is fine - it can make perfect sense in some situations to try a fallback approach, which could itself experience exceptional events.... hence this pattern is pretty much unavoidable.
However I would suggest the following to make the code better:
  • Refactor the inner try...catch blocks out into separate functions, e.g. attemptFallbackMethod and attemptMinimalRecovery.
  • Be more specific about the particular exception types that are being caught. Do you really expect any Exception subclass and if so do you really want to handle them all the same way?
  • Consider whether a finally block might make more sense - this is usually the case for anything that feels like "resource cleanup code"
mikera
  • 20,617
  • 75
  • 80
I don't think it's automatically an anti-pattern, but I'd avoid it if I can find an easier and cleaner way to do the same thing. If the programming language you're working in has a finally construct, that might help clean this up, in some cases.
  • 46,105
  • 126
  • 176
Not an anti-pattern per se, but a code pattern that tells you need to refactor.
And it's pretty easy, you just have to know a rule of thumb which is writing no more than a try block in the same method. If you know well to write related code together, usually is just copying and pasting each try block with its catch blocks and pasting it inside a new method, and then replace the original block with a call to this method.
This rule of thumb is based on Robert C. Martin's suggestion from his book 'Clean Code':
if the keyword 'try' exists in a function, it should be the very first word in the function and that there should be nothing after the catch/finally blocks.
A quick example on "pseudo-java". Suppose we have something like this:
try {
    FileInputStream is = new FileInputStream(PATH_ONE);
    String configData = InputStreamUtils.readString(is);
    return configData;
} catch (FileNotFoundException e) {
    try {
        FileInputStream is = new FileInputStream(PATH_TWO);
        return configData;
        try {
            FileInputStream is = new FileInputStream(PATH_THREE);
            return configData;
            return null;
Then we could refactor each try catch and in this case each try-catch block tries the same thing but in different locations (how convenient :D), we have only to copy paste one of the try-catch blocks and make a method of it.
public String loadConfigFile(String path) {
    try {
        FileInputStream is = new FileInputStream(path);
        return configData;
        return null;
Now we use this with the same purpose as before.
String[] paths = new String[] {PATH_ONE, PATH_TWO, PATH_THREE};
String configData;
for(String path : paths) {
    configData = loadConfigFile(path);
    if (configData != null) {
        break;
I hope that helps :)
Adrián Pérez
  • 181
  • good example. this example is truly the kind of code we have to refactor. however some other times, nested try-catch is necessary. – linehrr Jun 03 '18 at 22:49
It is surely decreasing the code readability. I would say, if you have chance, then avoid nesting try-catches.
If you have to nest try-catches, always stop for a minute and think:
  • do I have the chance to combine them?
    try {
      ... code
    } catch (FirstKindOfException e) {
      ... do something
    } catch (SecondKindOfException e) {
      ... do something else
  • should I just simply extract the nested part into a new method? The code will be much more clean.
    try {
      ... code
       panicMethod();
    private void panicMethod(){
    try{
    ... do the nested things
It is obvious if you have to nest three or more levels of try-catches, in a single method, that is a sure sign of time for refactor.
CsBalazsHungary
  • 1,389
I've seen this pattern in network code, and it actually makes sense. Here's the basic idea, in pseudocode:
try
   connect;
catch (ConnectionFailure)
   try
      sleep(500);
      connect;
   catch(ConnectionFailure)
      return CANT_CONNECT;
   end try;
end try;
Basically it's a heuristic. One failed attempt to connect could just be a network glitch, but if it happens twice, that probably means the machine you're trying to connect to really is unreachable. There are probably other ways to implement this concept, but they'd most likely be even uglier than the nested tries.
Mason Wheeler
  • 82,151
  • 234
  • 309
I solved this situation like this (try-catch with fallback):
$variableForWhichINeedFallback = null;
$fallbackOptions = array('Option1', 'Option2', 'Option3');
while (!$variableForWhichINeedFallback && $fallbackOptions){
    $fallbackOption = array_pop($fallbackOptions);
    try{
        $variableForWhichINeedFallback = doSomethingExceptionalWith($fallbackOption);
    catch{
        continue;
if (!$variableForWhichINeedFallback)
    raise new ExceptionalException();
Adrian
I've "had" to do this in a test class coincidentially (JUnit), where the setUp() method had to create objects with invalid constructor parameters in a constructor that threw an exception.
If I had to make the construction of 3 invalid object fail, for example, I would need 3 try-catch blocks, nested. I created a new method instead, where the exceptions where caught, and the return value was a new instance of the class I was testing when it succeeded.
Of course, I only needed 1 method because I did the same 3 times. It might be not such a good solution for nested blocks that do totally different things, but at least your code would become more readable in most cases.
MarioDS
  • 429
I actually think it's an antipattern.
In some cases you might want multiple try-catches, but only if you DONT KNOW what kind of error you are looking, eg:
public class Test
    public static void Test()
        try
           DoOp1();
        catch(Exception ex)
            // treat
        try
           DoOp2();
        catch(Exception ex)
            // treat
        try
           DoOp3();
        catch(Exception ex)
            // treat
        try
            DoOp1();
            DoOp2();
            DoOp3();
        catch (DoOp1Exception ex1)
        catch (DoOp2Exception ex2)
        catch (DoOp3Exception ex3)
If you don't know what you're looking for you HAVE to use the first manner, which is IMHO, ugly and not functional. I guess the latter is much better.
So, if you know what KIND of error you are looking for, be specific. No need for nested or multiple try-catches inside the same method.
George Silva
  • 371
    Code like the one you showed does indeed not make any sense in most if not all cases. However, the OP was referring to *nested* try-catches, which is a quite different question than that for multiple consecutive statements. – JimmyB Nov 09 '11 at 18:59
In some cases a nested Try-Catch is unavoidable. For instance when the error recovery code itself can throw and exception. But in order to improve the readability of the code you can always extract the nested block into a method of its own. Check out this blog post for more examples on nested Try-Catch-Finally blocks.
codelion
  • 109
There nothing mentioned as Anti Pattern in java anywhere. Yes we call few things good practice and bad practice.
If a try/catch block is required inside a catch block its required you cant help it. And there is no alternative. As a catch block can't work as try part if exception is thrown.
For Example :
String str=null;
try{
   str = method(a);
catch(Exception)
try{
   str = doMethod(a);
catch(Exception ex)
  throw ex;
Here in the above example method throws exception but the doMethod (used for handling method exception) even throw exception. In this case we have to use the try catch within try catch.
some thing which is suggested not to do is ..
try
  .....1
catch(Exception ex)
try
  .....2
catch(Exception ex)
try
  .....3
catch(Exception ex)
try
  .....3
catch(Exception ex)
try
  .....4
catch(Exception ex)
Dave Jarvis
  • 743
  • this doesn't seem to offer anything substantial over prior 12 answers – gnat Sep 29 '15 at 19:53
  • In fact, the code which you said "not to do" is sometimes the correct/better choice. It just needs to be structured properly, e.g. with each try-catch section moved to its own method. Whether it is good or bad depends on the level of essential complexity (unavoidable code complexity) resulting from complexity in requirements. In non-transactionally-oriented (e.g. non-CRUD) software systems, exception handling can evolve into something like a state-machine; it is apparent that each action within each state has its try-catch block so that the state machine itself is protected. – rwong Oct 26 '20 at 22:25
  • Of course, any advice applied to the extreme can become bad. If a programmer converts each line of code into a try-catch block, it will look excessive to the extreme to the code reviewer. Though, sometimes this is exactly what framework does: each single callback (from framework code to user-defined code) is wrapped in a try-catch. It is just hidden from view, because each try-catch block sits in its own method. – rwong Oct 26 '20 at 22:27
