I think it's OK to fix obvious things - i.e., if you are 100% sure the guy whose code you're fixing would make the same - or substantially the same - fix. If the fix is more complex, it is usually polite to talk to the person whose code you're fixing - it may be that you misunderstood the intent or the reason for breakage is not what you thought it is, or maybe he intended another fix but for some reason couldn't commit it just yet (life happens, you know :).
In general, the rule usually is: you break the build - you fix the build, but there are exceptions, especially if the fix is obvious and/or the person responsible is unreachable.
Of course, if you have the case of serial build breaker - especially with the pattern "checked in, went home, build broken for days" - the responsible person needs to get some talking to about why CI systems and tests exist and how one should check before checking in :)
I asked about cases when developer forgot commit some changes etc. – nahab Nov 08 '11 at 12:03
