I'm a huge fan of writing asserts, contracts or whatever type of checks available in the language I'm using. One thing that bothers me a bit is that I'm not sure what the common practice is for dealing with duplicate checks.
Example situation: I first write the following function
void DoSomething( object obj )
Contract.Requires<ArgumentNullException>( obj != null );
//code using obj
then a few hours later I write another function that calls the first one. As everything is still fresh in memory, I decide not to duplicate the contract, since I know that DoSomething
wil check for a null object already:
void DoSomethingElse( object obj )
//no Requires here: DoSomething will do that already
DoSomething( obj );
//code using obj
The obvious problem: DoSomethingElse
now depends on DoSomething
for verifying that obj is not null. So should DoSomething
ever decide not to check anymore, or if I decide to use another function obj might not be checked anymore. Which leads me to writing this implementation after all:
DoSomething( obj );
//code using obj
Always safe, no worries, except that if the situation grows the same object might be checked a number of times and it's a form of duplication and we all know that's not so good.
What is the most common practice for situation like these?
