Should ActiveRecord-based domain models have visible properties? Why or why not?
My experience and studies have always lead me to believe that object properties should always be protected, and that data should only be manipulated/accessed through methods. This ensures that if the internals of the class need to be refactored, other objects that rely on that object do not then also need to be refactored.
I often see domain models with publicly visible properties however, and the models can be passed to say view objects which directly access those properties while building the view. I have always thought that this is perhaps the one exception to the above mentioned rule, because otherwise you would basically have to create getters and setters for objects like the view to use, or some other equally troubling sounding solution. Perhaps I am wrong on this? I would like to get some feedback on the subject.
