The problem is that recursive comments force you to actually parse the comments section, pushing it outside the scope of a normal lexer and possibly introducing more problems.
As a refresher: A compiler usually has a number of distinct stages with different jobs, and the first stages are the lexer, which gets the input program and separates it into a sequence of tokens (each of which contains a keyword, and identifier or an operator), and the parser, which structures this sequence of tokens into an abstract syntax tree (AST).
For the scope of a lexer, remember that lexing can normally be done by regular expressions. Bracket-like structures like recursive comments cannot be parsed by regular expressions (see context-free grammars), so the lexer would have to have much additional complexity, e.g. would need to be implemented via a recursive-descent parser.
Additionally, for C and similar languages (who most famously used the /**/ comment syntax) the need never arose to comment out large chunks of code, since they had the pre-processor and unused chunks of code were just wrapped by
#if 0
#endif
which circumvented the parsing problem by delegating the problem to a second, much simpler compiler (the pre-processor).
Summarizing: Because recursive comments would make compiling more complicated, it's usually disallowed, and only languages with C-style comments, but without a preprocessor, really need it. That Java is amongst them is unfortunate, of course.
Edit: This doesn't mean recursive comments would be impossible or even very hard to do. You could use a recursive-descent lexer or could have a preprocessor before the lexer for filtering out comments. However, both approaches come with considerable cost compared to the standard model (use RE to auto-build the lexer and an EBNF to auto-build the parser), and the gain is pretty small.
