In my current project, I am having a hard time coming up with a good solution to create scalable integration tests that have no side effects. A little clarification on the side effect free property: it is mostly about the database; there shouldn't be any changes in the database after the tests are completed (state should be preserved). Maybe scalability and state preservation don't come together, but I really want to push for a better solution.
Here is a typical integration test (these tests touch the database layer):
public class OrderTests {
List<Order> ordersToDelete = new ArrayList<Order>();
public testOrderCreation() {
Order order = new Order();
assertTrue(order.save());
orderToDelete.add(order);
public testOrderComparison() {
Order order2 = new Order();
assertFalse(order.isEqual(order2);
orderToDelete.add(order2);
// More tests
public teardown() {
for(Order order : ordersToDelete)
order.delete();
As one might imagine, this approach yields tests that are extremely slow. And, when applied to the whole integration tests, it takes around 5 seconds to test only a small portion of the system. I can imagine this number going up when the coverage is increased.
What would be another approach for writing such tests? One alternative I can think of is having kind of global variables (within a class) and all test methods share this variable. As a result, only few orders get created & deleted; resulting in faster tests. However, I think this introduces a bigger problem; the tests are no longer isolated and it gets more and more difficult to understand & analyze them.
It might just be that integration tests are not meant to be run as often as unit tests; therefore low performance might be acceptable for those. In any case, it would be great to know if someone came up with alternatives for improving scalability.
