in this question OP has presented a site where some puzzle are available. He described the problem about solving them. I was curious is that really so problematic. The first one was really easy, so I tried next one this time from the end that should be the hardest one (puzzle).
And here I have some problem with understating it or probably I am messing something.
Let focus on the example:
Data:
M1 C1 C2 277317
M2 C2 C1 26247
M3 C1 C3 478726
M4 C3 C1 930382
M5 C2 C3 370287
M6 C3 C2 112344
Result:
617317
2 3 6
My problem is that relying on the assumption that
any one compound can be used in a chemical reaction to create any other compound
The solution could be
508878
2 6 5
Why ? In the content of the task, we do not have sad anything about that we have to start with compound one then from this get two then from two, three etc.
So the result should be to have all cheapest compounds, basing on the assumption we dont need to care how it was created. So this reduce our problem to structure like this.
M1 C2 277317
M2 C1 26247
M3 C3 478726
M4 C1 930382
M5 C3 370287
M6 C2 112344
And from this list we should pick the lowest cost for each compound.
So how did the achieve that solution, 2 3 6
By me they have used to complex logic for that, their basic assumption was that
C1 -> C2 is the same as C2 -> C1 so they have used a rank (hash code)
17 * 37 * 1 * 2 == 17 * 37 * 2 * 1
(for this post i have used easier representation using the bit shift and bit-wise or that is more less the same)
M1 001 | 010 = 011 277317
M2 010 | 001 = 011 26247
M3 001 | 100 = 101 478726
M4 100 | 001 = 101 930382
M5 010 | 100 = 110 370287
M6 100 | 010 = 110 112344
After such operation the set of solution is reduced to this form
M1 3 277317
M2 3 26247
M3 5 478726
M4 5 930382
M5 6 370287
M6 6 112344
So now I don't have the information about compounds, but only a rank that provide the solution.
We had three compounds on start we have three ranks so is seams to be correct, and the result is the same that in the example (cost 508878 machines 2 6 5).
My observation is that the content of the puzzle is very funny but have a lot of holes in the limitation about the method that should be applied to achieve the result.
So concluding, what i am messing ?
