Are there any libraries in Java that come close to providing the functionality of Linq?
1I presume you mean "the syntax of LINQ" rather than "the functionality of LINQ". There are many libraries that provide the same functionality :-) – mikera Sep 12 '12 at 05:07
Java equivalent is most likely [Groovy](http://en.wikipedia.org/wiki/Groovy_%28programming_language%29). At the expense of loosing type safety though – gnat Jul 16 '13 at 18:07
You can use [Java Functional Utils to convert C#'s 101 LINQ examples](https://github.com/mythz/java-linq-examples).. – mythz Aug 01 '15 at 00:30
To get full LINQ query syntax, you would need an update to the language spec and compilers supporting the new keywords and syntax structure. This is far beyond most readers here.
In order to get Linq-like method-chain syntax in Java that looks and works like what's in C#, you need two things Java doesn't support; extension methods (static methods that can be applied to an instance as if it were an instance method), and lambda expressions (anonymous delegates). However, those two can be spoofed with existing Java constructs, if you're willing to incur a little extra coding verbosity. One thing I find particularly amazing about Java is the ability to create anonymous interface implementations; applied to an interface with a single pure function, that basically allows for simple anonymous delegates, provided you have an interface for each method signature you'll need.
So, the IEnumerable (Iterable for the Javaheads) side of Linq, as a method chain, should be possible to approximate in Java; you'd basically implement it as a fluent interface that controls a monad. You'd need a class like a LinqIterable
, implementing Iterable, that:
- can convert any Iterable input into a LinqIterable instance
- has methods for basic list processing, such as filtering, grouping, concatenation, intersection, ordering, etc that accept single-function interfaces and produce new LinqIterables, allowing chaining of these methods, hopefully in a "lazy" fashion.
- has methods to transform the LinqIterable back into "concrete" objects such as ToList, ToArray, ToMap, etc
So, you could probably define a "fluent" library that would allow a statement such as:
Map<String, Integer> results = Linq.FromIterable(sourceList)
.Where(new Predicate{public bool Op(SomeStruct in){return in.SomeString == "criteria";}})
.OrderBy(new Func{public String Op(SomeStruct in){return in.SomeOtherString;}})
.Select(new Func{public SomeOtherStruct Op(SomeStruct in){return new SomeOtherStruct(in.SomeOtherString, in.SomeInt);}})
.ToMap(new Func{public String Op(SomeOtherStruct in){return in.StringField;}},
new Func{public Integer Op(SomeOtherStruct in){return in.IntField;}});
Creation of the actual library is an exercise far beyond the scope of an answer on an internet Q&A. I just said it was possible, not easy.
Expression trees are not rocket science, but it would be a significant project to implement what .NET has in this area; not only do you need the ability to build an expression tree, you need to be able to "compile" this tree on the fly using emitted bytecodes; I don't know if Java's reflection is quite that powerful.
- 21,994
- 6
- 52
- 79
2Funnily enough extension methods and lambda expressions are both in Java 8. Perhaps LINQ is on the way? – lxs Jul 16 '12 at 15:55
4Well if you have extension methods and lambdas, you have the "Enumerable" side of .NET's Linq without a huge effort. It will still, as I said, require a change to the Java spec to allow the keywords that make a Linq query, but honestly in day-to-day Linq use I've not found too many queries that aren't just as easily expressed as a method chain, and the compiler pretty much converts Linq syntax to method chains (VS plugins exist that can convert 1:1 between most queries and chains). The next real stepping stone will be expression trees (Queryable Linq). – KeithS Jul 16 '12 at 17:25
See:
- https://stackoverflow.com/questions/1217228/what-is-the-java-equivalent-for-linq - Some say there is no equivalent or that you can utilise Lambdaj to mimic it.
- https://stackoverflow.com/questions/346721/linq-for-java-tool - There's a mention that before Java 8 you can also utilise Google collections to fake it and that Scala the language does support it as a language feature, (Scala is another popular language on the JVM).
- http://www.infoq.com/news/2007/09/quaere-linq - A Java library that in theory provides LINQ functionality (I've not tried this myself).
- 22,006
- 1
- 49
- 81
1would you mind expanding a bit on what each of these resources have and why do you recommend these as answering the question asked? ["Link-only answers"](http://meta.stackoverflow.com/tags/link-only-answers/info "what's this") are not quite welcome at Stack Exchange – gnat Jul 17 '13 at 01:32
Hmm, I guess it's a case that this Q had already been answered - should be modded as a duplicate? – Martijn Verburg Jul 17 '13 at 07:43
1@MartijnVerburg - we can't mark questions as duplicates across sites. Answers really do need to be able to stand alone. – ChrisF Jul 17 '13 at 09:00
No. Linq requires lots of langage features that Java just dosent have
- 17,695
- 11
- 67
- 88
6@Jonas: That's true, but whether they're actually strong enough to support LINQ is another matter. – DeadMG Oct 18 '11 at 17:06
Use Scala, for the reasons explained here:
use the .NET port of Scala. It gives you full native access to everything in .NET, which obviously includes LINQ.
If you can't, you can try to use libs like functionjava or lambdaj, but you won't come really close to LINQ.
1@Jonas: So? Java doesn't include anything like Linq *with* libraries. – back2dos Oct 18 '11 at 19:02
1@Jonas: Scala's *standard* library is like LINQ. Or the other way round: LINQ is just a set of functional programming idioms for C#. More on that [here](http://stackoverflow.com/questions/3785413/linq-analogues-in-scala/3787196#3787196). – back2dos Oct 18 '11 at 21:31
@back2dos: Thanks for the great link, I took the freedom to include it. – Landei Oct 19 '11 at 07:45
I'd add guava to the list of libraries that may help you achieve some of the things LINQ does.
But as others have pointed out, there is no equivalent in pure Java.
- 639
- 1
- 4
- 6
would you mind explaining more on what it does and why do you recommend it as answering the question asked? ["Link-only answers"](http://meta.stackoverflow.com/tags/link-only-answers/info "what's this") are not quite welcome at Stack Exchange – gnat Jul 17 '13 at 01:32
There isn't a native feature in java that mimics linq. However, there are several APIs that provide the same functionality.
For example, this blog post has a custom jar to replicate linq.
http://javaworldwide.blogspot.in/2012/09/linq-in-java.html
And this is an example usage of the API from the post:
Suppose we have an Animal object containing name and ID which is represented with a list of animals
. If we want to get the all the Animal names which contains 'o' from the list animals
, we can write the following query
from(animals).where("getName", contains("o")).all();
There are two other APIs referenced in the blog posting: lambdaJ and jLinq
- 21
- 1
1I'm afraid that losing both static type checking and checking of the very existence of a class member is a bit steep a price to call for a call like `where("getName", ...)`. – 9000 Sep 24 '12 at 04:26
You could use Korma, a DSL for SQL queries written in Clojure.
Syntax is pretty neat:
(select user
(with address)
(fields :firstName :lastName :address.state)
(where {:email "korma@sqlkorma.com"}))
You can call this pretty easily from Java by importing the relevant Clojure libraries and just using the normal Clojure/Java interop.
- 20,617
- 5
- 75
- 80
@Job: yes, it is designed for SQL. Though I don't see any reason that it couldn't be extended / adapted for objects as well. – mikera Sep 24 '12 at 02:15
