I do line of business apps where the all the other developers are used to doing basic CRUD apps or are focused solely on making pretty/functional interfaces and I am getting the following a lot.
"With the way we use to do it Employee would have all the things you could possibly do with an employee." And it was true. That one "Class" had thousands of lines of code and anything you could do with an employee was there. Or, even worse, there was a table of employee data and each developer figured out how to do what they wanted to do in the event handler.
All the bad things about that approach was true but at least the developer using employee could, without going to other documents, figure out how to enroll the employee in a health plan, give a pay raise, fire, hire, transfer etc. Same goes for Manager and all the other major ideas. Or, if they used the employee other needed data tables, could just do what they wanted.
Yes, there was much duplicated code. Yes it was very brittle code. Yes testing it was way more difficult than necessary. Yes changing functionality was fear inducing and Copy Paste was a natural due to the approach.
But they could at least discover what was available by creating one class or they could do what they need to get done without having to understand the difference between interfaces, abstract classes, concrete classes etc. And they didn't have to search anything other than the methods returned by intellisense or know the tables where the data resided.
I have googled/binged and even yahoo!d but I haven't found any acknowledgement of this problem.
So maybe there isn't a problem and I am just missing something. I have racked my brain trying to figure out a solution where the developer(s) that do not work the actual behavior/design can easily discover how to do something without having to reference any external documents or scan the class names in the various components/projects to find the one that sounds like it will work.
The only thing I have been able to come up with is have these, for lack of a better name, "Table of Content Class" that does nothing more that return the actual classes (and really most of them are interfaces but they don't know the difference or even care) that other developers can use to perform the actual tasks desired. Still end up with really big classes but there is almost no behavior in them.
Is there a better way that doesn't require intimate knowledge of the middle tier where the actual implementation of SOLID takes place?
Basically what I am asking is there a way to allow CRUD type developers continue to be CRUD developers in a very complex system
