29
Basically, I've learned so far that garbage collection erases forever any data structure that is not currently being pointed to. But this only checks the heap for such conditions.
Why doesn't it also check the data section (globals, constants, etc etc) or the stack as well? What is it about the heap that it's the only thing that we want to be garbage collected?
Dark Templar
  • 6,223
8 Answers8
64
The garbage collector does scan the stack -- to see what things in the heap are currently being used (pointed to) by things on the stack.
It makes no sense for the garbage collector to consider collecting stack memory because the stack is not managed that way: Everything on the stack is considered to be "in use." And memory used by the stack is automatically reclaimed when you return from method calls. Memory management of stack space is so simple, cheap and easy that you wouldn't want garbage collection to be involved.
(There are systems, such as smalltalk, where stack frames are first-class objects stored in the heap and garbage collected like all other objects. But that's not the popular approach these days. Java's JVM and Microsoft's CLR use the hardware stack and contiguous memory.)
Jeff Grigg
  • 1,127
    +1 the stack is always fully reachable so no sense to sweep it – ratchet freak Oct 07 '11 at 18:04
    +1 thank you, took 4 posts to hit the right answer. I don't know why you had to say everything on the stack is "considered" to be in use, it *is* in use it at least as strong a sense as heap objects still in use are in use - but that's a real nitpick of a very good answer. – psr Oct 07 '11 at 18:35
  • @psr he means that everything on the stack is strongly reachable and has no need to be collected until the method returns but that (RAII) is already explicitly managed – ratchet freak Oct 07 '11 at 19:15
  • @ratchetfreak - I know. And I just meant the word "considered" probably isn't needed, it's OK to make a stronger statement without it. – psr Oct 07 '11 at 20:07
    @psr: I disagree. "_considered_ to be in use" is more correct both for stack and heap, for very important reasons. What you want is to discard what won't be used again; what you do is that you discard what is not _reachable_. You might well have reachable data which you won't ever need; when this data grows, you have a memory leak (yes, they are possible even in GC'ed languages, unlike many people think). And one might argue that stack leaks happen as well, the most common example being unneeded stack frames in tail-recursive programs run without tail call elimination (e.g. on the JVM). – Blaisorblade Oct 08 '11 at 12:55
20
Turn your question around. The real motivating question is under what circumstances can we avoid the costs of garbage collection?
Well, first off, what are the costs of garbage collection? There are two main costs. First, you have to determine what is alive; that requires potentially a lot of work. Second, you have to compact the holes that are formed when you free something that was allocated between two things that are still alive. Those holes are wasteful. But compacting them is expensive too.
How can we avoid these costs?
Clearly if you can find a storage usage pattern in which you never allocate something long-lived, then allocate something short-lived, then allocate something long-lived, you can eliminate the cost of holes. If you can guarantee that for some subset of your storage, every subsequent allocation is shorter-lived than the previous one in that storage then there will never be any holes in that storage.
But if we've solved the hole problem then we've solved the garbage collection problem too. Do you have something in that storage that is still alive? Yes. Was everything allocated before it longer-lived? Yes -- that assumption is how we eliminated the possibility of holes. Therefore all you need to do is say "is the most recent allocation alive?" and you know that everything is alive in that storage.
Do we have a set of storage allocations where we know that every subsequent allocation is shorter-lived than the previous allocation? Yes! Activation frames of methods are always destroyed in the opposite order that they were created because they are always shorter-lived than the activation which created them.
Therefore we can store activation frames on the stack and know that they never need to be collected. If there is any frame on the stack, the entire set of frames below it is longer-lived, so they don't need to be collected. And they will be destroyed in the opposite order that they were created. The cost of garbage collection is thus eliminated for activation frames.
That's why we have the temporary pool on the stack in the first place: because it is an easy way of implementing method activation without incurring a memory management penalty.
(Of course the cost of garbage collecting the memory referred to by references on the activation frames is still there.)
Now consider a control flow system in which activation frames are not destroyed in a predictable order. What happens if a short-lived activation can give rise to a long-lived activation? As you might imagine, in this world you can no longer use the stack to optimize away the need to collect activations. The set of activations can contain holes again.
C# 2.0 has this feature in the form of yield return. A method that does a yield return is going to be reactivated at a later time -- the next time that MoveNext is called -- and when that happens is not predictable. Therefore the information that would normally be on the stack for the activation frame of the iterator block is instead stored on the heap, where it is garbage collected when the enumerator is collected.
Similarly, the "async/await" feature coming in the next versions of C# and VB will allow you to create methods whose activations "yield" and "resume" at well-defined points during the action of the method. Since the activation frames are no longer created and destroyed in a predictable manner, all the information that used to be stored in the stack will have to be stored in the heap.
It is just an accident of history that we happened to decide for a few decades that languages with activation frames that are created and destroyed in a strictly ordered manner were fashionable. Since modern languages increasingly lack this property, expect to see more and more languages that reify continuations onto the garbage-collected heap, rather than the stack.
Eric Lippert
  • 45,799
  • 87
  • 126
14
The most obvious answer, and perhaps not the fullest, is that the heap is the location of instance data. By instance data, we mean the data representing the instances of classes, aka objects, that are created at run time. This data is inherently dynamic and the number of these objects, and thus the amount of memory they take up, is known only at runtime. There HAS to be some sore of recovery of this memory or long running programs would consume all of there memory over time.
The memory being consumed by class defintions, constants, and other static data structures is inherently unlikely to increase unchecked. Since there's only a single class definition in memory per an unknown number of run time instances of that class, it makes sense that this type of structure is not a threat to memory usage.
chad
  • 241
    But the heap is not the location of “instance data”. They can be on the stack too. – svick Oct 08 '11 at 00:19
  • @svick Depends on the language, of course. Java only supports heap-allocated objects, and Vala quite explicitly distinguishes between heap-allocated (class) and stack-allocated (struct). – fluffy Oct 08 '11 at 02:08
    @fluffy: those are very limited languages, you cannot assume that this holds in general since no language was precised. – Matthieu M. Oct 08 '11 at 12:47
  • @MatthieuM. That was sort of my point. – fluffy Oct 08 '11 at 16:39
  • @fluffy: so why are classes allocated in the heap, while structs allocated in the stack? – Dark Templar Oct 08 '11 at 20:52
  • @DarkTemplar: because that's how the language designer decided to differentiate between stack-allocated and heap-allocated objects. – fluffy Oct 09 '11 at 18:09
  • @fluffy it is not true that Java cannot allocate objects on the stack. While it is true that it provides no support for the programmer instructing it to do this, the virtual machine is perfectly capable of detecting many situations where it is possible to use the stack safely and converting an allocation from the heap to use the stack instead. – Jules Mar 18 '17 at 12:42
  • @Jules sure and there's also the multiple generational heaps in some implementations but that's an implementation detail, and I'm not sure what your purpose was in "correcting" me to say that Java doesn't provide a means of allocating things on the stack by saying that... it doesn't provide a means of allocating things on the stack (but sometimes it does anyway). – fluffy Mar 20 '17 at 03:25
It's worth bearing in mind the reason why we have garbage collection: because sometimes it's difficult to know when to deallocate memory. You really only have this problem with the heap. Data allocated on the stack will be deallocated eventually, so there isn't really any need to do garbage collection there. Things in the data section are generally assumed to be allocated for the program's lifetime.
Jason Baker
  • 9,625
  • 44
  • 67
  1. The size of those is predictable (constant except for the stack, and the stack is typically limited to a few MB) and typically very small (at least compared to the hundreds of MB large applications may allocate).
  2. Dynamically allocated objects typically have a small time frame in which they are reachable. After that, there is no way they can be referenced ever again. Contrast that with entries in the data section, global variables, and such: Frequently, there's a piece of code that references them directly (think const char *foo() { return "foo"; }). Normally, code doesn't change, so the reference is there to stay and another reference will be created each time the function is invoked (which could be at any time as far as the computer knows - unless you solve the halting problem, that is). Thus you couldn't free most of that memory anyway, as it would always be reachable.
  3. In many garbage-collected language, everything that belong to the program being ran is heap-allocated. In Python, there simply isn't any data section and no stack-allocated values (there are the references that local variables are, and there's the call stack, but neither is a value in the same sense as an int in C). Every object is on the heap.
  • "In Python, there simply isn't any data section". This isn't strictly speaking true. None, True, and False are allocated in the data section as I understand it: http://stackoverflow.com/questions/7681786/how-is-hashnone-calculated – Jason Baker Oct 07 '11 at 18:07
  • @JasonBaker: Interesting find! It doesn't have any effect though. It's an implementation detail and restricted to builtin objects. That's not to mention that those objects aren't expected to be deallocated *ever* in the lifetime of the program anyway, aren't, and are also tiny in size (less than 32 byte each, I'd guess). –  Oct 07 '11 at 18:12
  • @delnan As Eric Lippert it fond of pointing out, for most languages the existence of separate memory regions for the stack and heap is an implementation detail. You can implement most languages without using a stack at all (although performance may suffer when you do) and still be compliant with their specifications – Jules Mar 18 '17 at 12:54
As a number of other responders have said, the stack is part of the root set, so it is scanned for references but not "collected", per se.
I just want to respond to some of the comments that imply that garbage on the stack doesn't matter; it does, because it may cause more garbage on the heap to be considered reachable. Conscientious VM and compiler writers either null out or otherwise exclude dead parts of the stack from scanning. IIRC, some VMs have tables mapping PC ranges to stack-slot-liveness bitmaps and others just null out the slots. I don't know what technique is currently preferred.
One term used to describe this particular consideration is safe-for-space.
Ryan Culpepper
  • 1,413
  • Would be interesting to know. First thought is that nulling out spaces is the most realistic. Traversing a tree of excluded areas may well take longer than just scanning through nulls. Obviously any attempt to compact the stack is fraught with peril! Making that work sounds like a mind-bending/error-prone process. – Brian Knoblauch Oct 07 '11 at 20:31
  • @Brian, Actually, thinking about it some more, for a typed VM you need something like that anyway, so you can determine which slots are references as opposed to integers, floats, etc. Also, regarding compacting the stack, see "CONS Should Not CONS Its Arguments" by Henry Baker. – Ryan Culpepper Oct 07 '11 at 20:51
  • Determining slot types and verifying that they're used appropriately can and usually is done statically, either at compile time (for VMs using trusted bytecode) or load time (where bytecode comes from an untrusted source, eg Java). – Jules Mar 18 '17 at 13:05
Let me point out a few fundamental misconceptions you and many others got wrong:
"Why does Garbage Collection only sweep the heap?" It's the other way round. Only the simpliest, most conservative and slowest garbage collectors sweep the heap. That's why they are so slow.
Fast garbage collectors only sweep the stack (and optionally some other roots, like some globals for FFI pointers, and the registers for live pointers), and only copy the pointers reachable by the stack objects. The rest is thrown away (i.e. ignored), not scanning at the heap at all.
Since the heap is about 1000x bigger than the stack(s), such a stack-scanning GC is typically much faster. ~15ms vs 250ms on normal sized heaps. Since it's copying (moving) the objects from one space to another, it's mostly called a semi-space copying collector, it needs 2x memory and therefore mostly not usable on very small devices likes phones with not much memory. It's compacting, so it's very cache friendly lateron, unlike simple mark & sweep heap scanners.
Since it's moving pointers, FFI, identity and references are tricky. Identity is usually solved with random ids, references via forwarding pointers. FFI is tricky, since foreign objects cannot hold back pointers to the old space. FFI pointers are usually kept in a separate heap arena, e.g. with a slow mark&sweep, static collector. Or trivial malloc with refcounting. Note that malloc has a huge overhead, and refcounting even more.
Mark & sweep is trivial to implement but it should not be used in real programs, and especially not be taught as the standard collector. The most famous of such fast stack-scanning copying collector is called the Cheney Two-finger collector.
rurban
  • 137
  • The question seems to be more about what parts of memory are garbage collected, rather than specific garbage collection algorithms. The last sentence especially implies the OP is using "sweep" as a generic synonym for "garbage collect," rather than a specific mechanism to implement garbage collection. Considering that, your answer comes across as saying that only the simplest garbage collectors garbage collect the heap, and fast garbage collectors instead garbage collect the stack and static memory, leaving the heap to grow and grow until it runs out of memory. – 8bittree Mar 17 '17 at 21:40
  • No, the question was very specific and clever. The answers not so. Slow mark&sweep GC's have two phases, the mark step scanning the roots on the stack, and the sweep phase scanning the heap. Fast copying GC's have only one phase, scanning the stack. Easy as that. Since apparently nobody knows here about proper garbage collectors, the question needs to be answered. Your interpretation is wildly off. – rurban Mar 18 '17 at 06:34
What is allocated on the stack? Local variables and return addresses (in C). When a function returns, its local variables are discarded. It is not neccessary, even detrimental, to sweep the stack.
Many dynamic languages, and also Java or C# are implemented in a system programming language, often in C. You could say Java is implemented with C functions and uses C local variables and therefore that Java's garbage collector does not need to sweep the stack.
There is an interesting exception: Chicken Scheme's garbage collector does sweep the stack (in a way), because its implementation uses the stack as a garbage collection first-generation space: see Chicken Scheme Design Wikipedia.
nalply
  • 257
