13
So i've been trying to learn some Embedded/Assembly programming for a bit here lately, as well as going far as trying to learn the lowest level (gates and such).
One thing puzzles me though....is how do we "get" instruction sets. I understand somewhat how gates/TTL and such works, but I don't see how we get from that to mov,add,clr etc...?
It's probably a stupid question....but I mean I think back to the first micro-processors/controllers and think....how exactly did they design an instruction set and make it work?
edit: I guess for Clarity, pretend im talking about the first microprocessor, how did they go from Binary to actually creating an Instruction Set?
    Every instruction has a value, the compiler converts your code into these instructions, based on how your code is structured. – Ramhound Sep 26 '11 at 14:52
    a couple closely related questions http://programmers.stackexchange.com/questions/81624/how-do-computers-work/81715#81715 and http://superuser.com/questions/307116/how-does-a-cpu-know-what-commands-and-instructions-actually-mean/307117#307117 – jhocking Sep 26 '11 at 15:33
    I'm not sure if I understand your question perfectly, but I think you can find your answer [here](http://en.wikipedia.org/wiki/Intel_8086), [here](http://en.wikipedia.org/wiki/Instruction_pointer) or [here](http://en.wikipedia.org/wiki/Control_unit). – e-MEE Sep 26 '11 at 15:00
  • I think [here](http://en.wikipedia.org/wiki/Assembly_language) might be instructive, too. – ghoppe Sep 26 '11 at 15:27
    _how did they go from Binary to actually creating an Instruction Set?_ Actually, "they" didn't -- it's the other way around, at least generally. The CPU designer(s) determine the operations that the CPU will perform, then they create the instruction set from that, and then they map the instructions (mnemonics) to opcodes (binary machine code). @Scott Whitlock provided a good answer below, I just wanted to address the last part of your question because your assumption, in my experience at least, is backward. – Radian Sep 26 '11 at 20:04
    This really nice book: http://www1.idc.ac.il/tecs/ is what explained it all to me, most of the chapters are availble free online. You design your own chip (in a simple hardware descript language) from nand gates, then an assembler then a compiler, then write an os in the language your created! Amazing stuff, and as someone without a com sci degree it was time well spent for me! – handles Aug 07 '12 at 13:01
  • @bplus Ah i've heard about this book, seems they have it on Amazon Kindle for 15 bucks, might be worth checking out! thanks! –  Aug 07 '12 at 13:32
  • For the most part hex op codes and assembly instructions have a 1 to 1 relationship. You go from one to the other using an assembler, disassembler, or by hand using something like [this map](http://www.mlsite.net/8086/). The designers did it because `MOV AL OB` is easier on the brain then `A0`. – candied_orange Sep 07 '16 at 14:35
7 Answers7
18
The heart of a CPU is the ALU. It's responsible for taking an instruction (like MOV) which is just some pre-defined series of binary digits, and also taking 0, 1, or 2 operands, and performing the applicable operation on them. The simplest instruction could be a NOP (no operation) which essentially does nothing. Another typical operation is ADD (adds two values).
The ALU reads and writes data from and to "registers". These are small memory locations internal to the CPU. Part of the instruction (2 to 3 bits for each input depending on how many registers you have) indicates which register to read from. There are units in the CPU external to the ALU that handle loading required data (and the instruction) from memory into registers, and writing the result from registers back into memory. The location to write the result will also be encoded into another 2 or 3 bits.
The choice of "op codes", which is the binary number that represents an operation, is not arbitrary. Well-chosen opcodes reduce the complexity of the ALU. Each bit or group of bits tends to enable and disable certain logic gate in the ALU. For instance, an ADD instruction would have to enable the output stage to choose the result of the internal adding logic. Likewise, a MUL instruction would choose the result of the multiply logic. Depending on the design, it's quite likely that both the adder and multiply circuits both actually perform their operation on the input operands, and it's just the output selection (what gets written to the output bits of the ALU) that changes.
Scott Whitlock
  • 21,874
  • 60
  • 88
    I guess what im asking, is how do they choose? And how do they actually go about assigning it? –  Sep 26 '11 at 15:31
    @Sauron: Reread the 3rd paragraph again and try to understand binary arithmetic and digital circuits. I can represent an instruction set with 256 instructions by an 8bit line in a digital circuit. That means I need 8 io ports on my hardware devices to transfer every possible state (2 states per line ^ 8 lines = 256 possible states). The processing unit can then decide what to do with that digital input signal. A digital circuit means you have two hardware states: Hi and Lo, voltage or no voltage. That's where the binary comes from. Binary representation is the one closest to the metal. – Falcon Sep 26 '11 at 15:47
  • @Sauron: Also, by the wording of your question, I can tell that you haven't understood instructions and number conversions properly. If I represent it in hex, decimal, octal or binary does not matter much to a human, it's the same content. For the common digital computer it'll always be binary. Because we have two states per line. So any number will be transmitted as a binary signal in these circuits. It's the only way to represent it for a common computer. – Falcon Sep 26 '11 at 15:53
    @Sauron - look up [Digital Multiplexers](http://en.wikipedia.org/wiki/Multiplexer#Digital_multiplexers) to see how a digital circuit can choose from one of several values. If you have an 8-bit bus, you just need 8 of these binary digital multiplexers in parallel. – Scott Whitlock Sep 26 '11 at 15:58
    @Falcon Ok.......I think that makes more sense. I keep forgetting that in the end it all goes down to binary signals....and even an instruction such as "mov" is still represented as binary. –  Sep 26 '11 at 16:05
    @Sauron - Do some research on the CPU, it will help you understand, what op codes are and how they work. Why certain op codes are choosen is not important, even asking the "why" question, doesn't make a great deal of sense. Understanding how they are choosen might help you understand more about the CPU and its structure. – Ramhound Sep 26 '11 at 16:15
    @Sauron: Right. "mov" is just an alias for a number to associate it with its behaviour within the circuit. To us humans it's easier that way. And this number is transmitted in binary within the machine's circuits. – Falcon Sep 26 '11 at 16:27
    I don't like this answer because it is possible to design a Turing complete computer without an ALU, just a simple LU will do. – hotpaw2 Jan 05 '12 at 08:03
    @hotpaw2 - In the context of the question this is the correct answer. Your answer does not address the author's question which basically amounts to "how are op codes selected" and in the case of modern design would require an ALU. – Ramhound Jan 05 '12 at 14:36
  • @ScottWhitlock, What's a good book you recommend for a beginner trying to learn bare-metal (both theory and practical)? – Pacerier Apr 09 '17 at 22:39
  • @Pacerier - I first learned by picking up a book on x86 assembly language when I was a teenager, and then took computer engineering which included some courses on CPUs. The only thing I read after that which contributed to CPU knowledge was a book on multi-threaded programming on Windows. So, I can't really recommend a good book on it as that wasn't the way I learned it. – Scott Whitlock Apr 10 '17 at 09:53
I will take your question literally and discuss mostly microprocessors, not computers in general.
All computers have some sort of machine code. An instruction consists of an opcode and one or more operands. For example, the ADD instruction for the Intel 4004 (the very first microprocessor) was encoded as 1000RRRR where 1000 is the opcode for ADD and RRRR represented a register number 0-15 (0000-1111 in binary).
All other instructions that reference one of the 16 4-bit registers (such as INC, ISZ, LD, SUB, XCHG) also use the low 4-bits to encode the register number, and various encodings of the top 4-bits to specify the opcode. For example, ADD, SUB, LD and XCHG use opcodes 1000, 1001, 1010, and 1011 (all in binary) combined with the register field. So you can see how a pattern is used to simplify the logic.
The very first computer programs were written by hand, hand-encoding the 1's and 0's to create a program in machine language. This was then programmed into a ROM (Read-Only Memory). Now programs are generally written into electrically-erasable Flash memory, in the case of microcontrollers, or run out of RAM, if microprocessors. (The latter still needs some sort of read-only memory for booting.)
Machine language gets tedious real fast, so assembler programs were developed that take a mnemonic assembler language and translate it, usually one line of assembly code per instruction, into machine code. So instead of 10000001, one would write ADD R1.
But the very first assembler had to be written in machine code. Then it could be rewritten in its own assembler code, and the machine-language version used to assemble it the first time. After that, the program could assemble itself (this is called bootstrapping).
Since the first microprocessor was developed long after mainframes and minicomputers were around, and the 4004 wasn't really suited to running an assembler anyway, Intel probably wrote a cross-assembler that ran on one of its large computers, and translated the assembly code for the 4004 into a binary image that could be programmed into the ROM's.
tcrosley
  • 9,541
  • 41
A computer at a very low level can be represented by a data path and control. Googling these together may give you a lot of reading as it is fundamental in digital architecture/design.
I'll do my best to summarize:
As mentioned here, at the heart we have an ALU - what needs to be known about the ALU (and other parts of the CPU) is that it is reconfigurable for different operations. More specifically, we have the ability to reconfigure the data path, which is how parameters are fetched, what operation to do, and where they are stored afterwards. Imagine being able to manipulate these three things - this is our control.
So how do we accomplish this? As mentioned already again, we can take advantage of low level digital logic and create multiplexers for different paths. Multiplexers are controlled using a set of bits for input - where are these bits taken from? Encoded from the instructions themselves. The takeaway: Instructions like mov, add, etc are just a set of bits that tell a CPU how to configure its datapath for a particular operation. What you're reading (mov, add) is the human readable form (assembly language) and our program defines a procedure of datapaths and operations.
I apologize if this is an oversimplification of more complex processes to those who are more knowledgable in this area. FYI, the electrical engineering stack-exchange would be a great place to ask this question as it deals with very low level logic.
Jon
  • 141
if I understand your question I dont understand how bin/hex or assembly are related.
I assume the meat of your question is how do I get from the basic gates, AND, OR, NOT to instructions like move, load, store, add, etc.
I have my own little teaching instruction set I made from scratch that has some of the details of say how an add and subtract work from basic gates and things like that http://github.com/dwelch67/lsasim.
Look for the Code (something something something) book from Petzold. May start way to elementary but walks you slowly from nothing to do with computers and electronics into binary, hex, and into the basic gates, etc.
Are you asking about how you would build one from scratch today, or how did they do it back in the day? Today you would start with a definition of the instruction set. you just sit down and write it out, you think about the types of instructions you must have the loads and stores and moves and alu stuff, and then how many registers, how big the registers, this in part affects the instruction size, you think about the instruction size...
Let me stop and ask you how do you write a program? Starting with a blank screen on a text editor? You have some idea of the task you are trying to solve the variables you might need, the functions, the programming language, etc. And each person is different but to some extent you do a little of this (say defining and writing functions), a little of that (making header files with reusable defines and enums and structs and stuff), and a little of the other thing (just code, fill the functions with variables and code). And you circulate around the different tasks, in the end you feel you have a balance of code size, speed, readability, quality, functionality, etc. No different with hardware design. hardware designers use programming languages (vhdl, verilog) as well and go through the same process, the programming is only slightly different to software, the primary difference is that different lines/modules of hardware programs execute simultaneously where software executes linearly.
Just like coming up with a software program you balance the desires, performance, size, features, etc. You might have some design rules forced on you either that you wanted or that your boss made you do, etc. As with software design well after the initial design into implementation you may find out that you have some big mistakes and have to go back to initial design and change the instruction set, big or small changes. Might get so far as to have a compiler and simulated processor to find you really needed a couple of specific instructions that dramatically improve the quality of the compiled code, performance, etc.
So you have invented some instruction set from scratch, you have used some experience with hardware design to group similar instructions with similar bit patterns so they can be more easily decoded, not just for hardware language programming but it saves on power and gates and all that good stuff. These days you would make some sort of a simulator, my understanding is ARM was a software simulator first then the hardware designs came later, dont know if that is true but sticking with that story. This depends on the team some teams may be just hardware folks and want to just get into programming in the hdl, some like me may want to do a little of both. These days good hardware language simulators are available so you dont have to build any hardware you compile and simulate and do much of your debugging with a hardware simulation program/package. the software team can develop assemblers and compilers for the instruction set and using simulated ram and rom feed programs to the simulated processor and put it through its paces. we have simulated a full linux boot on a processor I worked on not long ago, took many hours but it worked (found a cache bug in the logic that way).
So now for what I really think you were asking. How do you get from basic gates to a processor with an instruction set. Well basic gates AND, OR, NOT are really analog, they dont have a concept of time, you cant instantly change the voltage on the inputs and as you change that voltage the outputs start to change. gates are made of transistors and transistors are amplifiers, take the input multiply it by some number and allow that much current to flow on the other side. when we use them as logic gates we are actually oversaturating them, the input voltage is so high or low that the transistor can only drive max voltage or no voltage (current). basically the transitor is turned into a switch. long story short, there is no concept of time. In order to have an instruction set we have to have instructions happen in order we have to sequence through the program, we have to have a concept of now we are on this instruction, and in the next time slot we will work on that instruction. Just like the game of turning an amplifier into a switch you play similar games with using basic logic gates with a clock. the clocks come from magic crystals in a can (not worth getting into that here) that make voltages that turn on and off at some fixed rate. use that voltage in logic equations and you can start to sequence things.
very very briefly think of this truth table:
0 0 0
0 1 1
1 0 1
1 1 0
in binary:
0 + 0 = 1
0 + 1 = 1
1 + 0 = 1
1 + 1 = 10 (2 decimal)
focusing on the lsbit only, a one bit adder, the truth table above describes a one bit adder. It also describes an XOR gate. One input is true or the other but not both.
To get more than one bit you have to look at carry bits carry in and carry out and you need a three bit adder two operands and a carry in with two outputs, carry out and the result bit. Once you have that three input two output adder you can cascade that as wide as you want. But this is still analog, the gates change instantly.
How you turn this analog adder into an ADD instruction, is you have some logic that looks at the instruction which is sitting as inputs to these gates you have arranged. some of the bits in the instruction say, this is an add instruction, some of the bits say that one operand is such and such register, maybe register 7, other bits may say the other operand is register 4. and depending on the architecture you might have another register defined in the instruction that says put the result in register 2. Now more logic sees this as I need register 7's contents to be routed to one input of the alu adder and register 4's inputs routed to the adder, and you route the output of the adder to register 2. Since the clock is part of this logic there is a period of time from the beginning of the clock period to the beginning of the next clock period where all the analog signals settle down and resolve the logic equation they are wired to do. Not unlike when you flip a light switch you change the lights state from say off to on. it takes a period of time for that light to warm up and basically get into a steady state. Not much different here.
There is some logic that says things like if this clock period is the execution phase of an AND instruction, then the next clock period I am going to save the result in the output register. at the same time I am going to fetch the next instruction etc. So for modern processors where the alu execution is often just one clock period because the analog logic can resolve the logic equations that fast. Older processors you had to count to some number leave the adder wired up, wait for x number of clock cycles for the adder logic to resolve, then sample the result from the output, feed the alu different inputs, wait x number of clock cycles for that to resolve, repeat forever or until the power goes off.
What do I mean by logic equations? just that, if you want you can think of it in terms of AND, OR, NOT gates. For each input bit to the alu adder circuit there is an equation, likely a very long equation which includes the clock, which includes the flip flops (individual/single memory bits) that contain the current instruction (plus the equations that feed each of those memory bits) and on and on. Take a single software function you have written, in the language you have written it, assuming this is a function that takes the inputs, performs a task and then finishes and returns a result. Think of all the possible combinations of inputs and what the different execution paths are through that function. You may have written it in some high level language but you could probably even in that language rewrite it to be more primitive and more primitive using many nested if-then-else structures. and go lower down into assembly language perhaps. Not unlike the equations I am talking about, the hardware programmer doesnt program in these long winded equations any more than you probably program in long winded if-then-else trees in assembly language when the programming language of choice saves so much of that. Just like the compiler you use turns your small source code into long winded assembly with lots of if-then-elses, there is a compiler that takes the hardware programming language code and turns it into a logic equations. Just like when you take one program written (to be portable) in C and compile it for different instruction sets the assembly and machine code is different, depending on where you plan to build your chip or what programmable chip if you use a cpld or fpga you are using the hardware programmers program resolves to different lists of logic equations based on the logic blocks available from that chip builder or programmable device.
Now going back to the first cpu (which today we would consider a microcontroller but then it was a cpu). You did all of the above on paper, and you didnt use hardware programming languages you actually wrote the logic equations, but you even more carefully chose the bit patterns for the instructions to make the number of gates and the wires to connect those gates as simple as practical. On paper, by hand you had to both create the long list of wired up logic gates and then you had to draw the actual components on a blown up version of the silicon mask. even today chips are done using what is similar to a photographic or silkscreen like process in laymans terms so you would take these blue prints if you will and shrink them then apply them to the silicon layers.
here again back in the day everyone had a better handle on assembly and not only might you end up doing some assembly programming you might not have had a text editor nor an assembler you might have had to write your first programs by hand on paper, then using a reference manual, by hand converted that to machine code, ones and zeros. On some of those computers you might have had to load the ram by flipping switches, flip the address bits, flip the data bits until they match the numbers on your paper, flip the clock bit up then down and you have loaded one memory location with one byte of one instruction of your program, repeat a few hundred times more and hope you make no mistakes.
In the same way that the first lets say C compiler was probably written in some other language then it became self hosting by being re-written in C and compiled by the first C compiler then again by itself. Then the C compilers were used to invent other programming languages which then became self-hosting. We invented operating systems and text editors that built upon themselves, and it is all black magic left for a few folks behind the curtain in the corner to do...
yes, very long winded, it is a big question needing years worth of study and experience to truly grasp. look at my lsasim, I dont claim to be an expert in anything, but it is an instruction set, there is both a simulator that executes the instruction written in C, and another implementation of the processor implemented in a hardware programming language that can be simulated using different tools. Plus a crude assembler and some other tools and such. Perhaps, by examining some of this, in particular the hardware programming language code it might close the gap on what I assume you were asking. If I have not closed that gap or have made a long winded tangent please let me know i will happly remove this answer (assuming I am able to I dont hang out at programmers exchange much).
old_timer
  • 969
  • This really doesn't answer the author's question, it at least doesn't add anything to the discussion, that the accepted answer didn't cover. Your binary math is not 100% correct 1 + 1 is 0 with an overflow of 1. Depending on the size of the registry it would either be 2 or 0. – Ramhound Jan 05 '12 at 14:28
  • @dwelch DAMN! I'm your die heart fan if nothing less. +1 – AceofSpades Jan 13 '12 at 12:42
CPUs operate on 0's and 1's. All instructions had a sequences of bits that defined them. Thsi was machine code. That hard for humans to read and write. As a first step we grouped the 0's and 1's into 4 bits sequences and used 0 through F to represents them. This reduced the numbers we had to memorize, but it still was not easy to remember the hex code for instructions.
So we started using assembly which had "words" like MOV and ADD. The assembler would replace the instructions with the correct set of 0' and 1's converting the assembly "listing" to machine code.
Eventually we developed "higher" level languages where "instructions" could represent entire sequences of machine code.
Caleb
  • 38,959
  • 94
  • 152
Jim C
  • 883
  • FYI, octal was used as a binary shorthand before hexadecimal. – ocodo Sep 26 '11 at 23:28
  • Slomojo is right, Octal, base 8 used 3 bits, was used along with hex, base 16 used 4 bits. Octal had the advantage in that everyone knew what numbers 0 to 7 represented. People how did not use Hex were often mystified by the "digits" A to F. – Jim C Sep 27 '11 at 17:53
I recently came across this Q/A and about a year ago or so when I started traveling down this path; I would have found this to be a very good resource and reference page in regards to related questions of my own.
Part 1: -Preface-
A little bit about myself:
In the mid to late 80's when I was still in Elementary School, I would take apart junk stereos, VCR, and other electron devices that were from the 50's through the 80's and would look at the circuit boards and always wanted to know how did they work... How did they actually acquire the broadcast signal, produce audio, video, do this and that etc... I could recognize the individual parts here and there such as a resister, capacitor, diode and transistor, but didn't know what they did or how they functioned at such a young age.
Throughout the years I've always been exceptional in Mathematics, Physics and Chemistry. I understood math to a high degree and could even read some simple or basic circuitry from my middle school and high school days which came later, but I never made it to learning about the logic gates and how they were constructed... I did however learn Boolean Algebra in High School from my Logic, Probability and Statistics Honors class. All of my math and science classes were honors classes. I didn't take Calculus until my second semester at a community college. I tested out of College Algebra and took Trigonometry as a refresher course. My highest level of math from the classroom is Calculus II of a single variable.
I've been playing video games since I was about 3 or 4 years old. As a child I had the Atari, the NES, Sega Genesis and the PS1. As I got older and into my late teens and early 20's I had acquired the PS2 and the SNES with preferred select titles. This also doesn't account for PC gaming that goes as far back as Doom!
I've always been an avid Console and PC gamer and this doesn't include pinball and arcade games.
I was given my first PC when I was about 12 years old for Christmas in the early 90's. The days of DOS 6.0 and either Win 3.11 or OS/2. Since then I've always been familiar with the "Windows" family of operating systems and all of the systems I've had were Intel Architecture. I've had limited experience with Apple or Mac from school or college, but I never had the privilege to work on Linux systems. I do have Cygwin and I've tried my hand at learning bash, but I'm so accustomed to Dos or the Command Prompt syntax.
In the early 90's I would get a copy or two of PC-World and would type in the code snippets into QBasic which I didn't know very well and would try to make those programs work. The only one that was successful was a program to turn key presses on the home row of keys into different ring tone sounds. I don't mean the ring tones on a cell phone I mean a continuous frequency as long as you held the key down.
It's always been a passion of mine to not only want to know how electronic devices worked within the circuity at the digital and logical level, to learn how to program a computer, but I've always had the desire to want to make my own video games. Even back in the early 90's I wanted to make the games Frogger and Tetris...
This became my leading motivation and desire to tackle one of the toughest types of programming or software development within the field of Computer Science and that is 3D Game Engine Design. There are other fields in Computer Science that are just as tough, however any sophisticated game engines will typically or usually include almost all of them as the individual components or sub engines require their techniques and or properties.
I had some background in programming from my High School days but this was limited to the horrible Visual Basic. I started to pick up and learn C/C++ around 2002 - 2003 not until a few years after I have graduated from High School in 1999. Even to this day I do not have any college class experience in Computer Science or Computer Engineering, but through dedication and determination, I have learned just about every concept there is when it comes to computers, hardware, programming, algorithms, etc. and I still continue to learn as much as I can...
During the early days of learning C/C++, I did have access to the internet but the internet then was in its early stages, websites like Amazon, Youtube, Facebook etc. didn't even exist yet, it was still the days of 56k dial up modems which tide up your phone line if you didn't have a second dedicated line. It would take minutes just for an image to render onto the screen, never mind continuous video playback.
So when it came to research and learning how to program in C++, resources were limited and most were in text format. When attempting to tackle the projects from the early internet tutorial days, many of those projects were not fully complete, the writers were either professionals or college students and they made many assumptions that the reader was already familiar with many of the needed concepts such as compilation, linking and debugging and library integration.
For someone who doesn't know anything about those topics, they are at a loss because they don't know what went wrong, nor how to fix it, and how to get it to work properly. It took me many hours of trial and error in those days with very limited resources. Asking for help such as we can now with this website or looking for detailed explanations that you can find on cppreference wasn't available! If you personally didn't know anyone, there weren't that many you could turn to for assistance!
As time went on I did improve some of my knowledge here and there, and eventually the internet improved to DSL, and now High Speed internet, websites became more interactive, videos started to show up, quality of videos became better with time, sites such as Youtube started to show up and things became a little easier on the research side. More and more tutorials became readily available, some were good and useful where others taught bad practices...
I had also spent plenty of time finding and acquiring the necessary tools for development. I had to learn the language syntax, the compiler and compiling process, linking, building and debugging. Then I had to learn about the different available libraries and APIs that are out there and how to configure my projects or solutions to link all of those dependencies.
Over the years I have watched the C++ language grow, evolve and adapt over time. In the beginning it stayed nearly the same for many years, but in the last 10 years it has changed dramatically within this short span since its inception.
I mention all of this because C++ is one of the toughest languages to fully master because of its versatility, power, rich feature set and the ability to allow you to shoot yourself in the foot! And even with all of its caveats, it is one of the most powerful and preferred languages that is used in the top leading industry as a standard for this type of development because when it is done correctly it is fast, concise, reliable and uses the smallest foot print.
Since then I've been self taught in C/C++ for many years with the intent and focus on learning 3D Graphics Programming and Game Engine Design. I have put in 100's to 1,000's of hours of searching, research and much more into reading, learning and applying that knowledge into the designing of useful working products and applications. I have always had the will and desire to want to learn more to improve my skill sets and craft.
This was the first stage, then I had started reading and working with initially DirectX 9.c, which I have done in C/C++ and even C#. Then I moved onto DirectX 10 and Legacy OpenGL 1.0. From their came DirectX 11 and OpenGL 3.x - 4.x and now I have even tried my hand at Vulkan.
I have built successful game engines working through various online tutorials both in text and video formats. I already stated that I had a strong background in math but it was limited to Calculus I & II. I had to teach myself Vector Calculus which I had some knowledge of from my Calculus based Physics class in college but as for Linear Algebra with Affine Transformations and Analytical Geometry I had to learn them on my own when certain equations, functions, methods, algorithms and concepts were needed. Then I had to learn how to translate those into efficient, readable, reliable, reusable code that was generic and bug free as possible putting in hundreds to thousands of hours of debugging.
It has been a marvelous journey learning the topics and algorithms that include memory management, reference counting, instancing, recursion and much more that are used within many if not all of the components of a game engine where they are vast. I could list all of them here but that would be enough information to fill 3 or 4 answer space worth of write up. However, I will include the list of the general topics just not their sub topics.
Here are the topics or subject list in what consists of a fully functional game engine which includes all of the various rending techniques, setting up the rendering and shader pipelines, shading and lighting techniques via shaders, pre and post processing, frame buffers, back buffers, image loading, audio and model loading and parsing, creating primitive shapes with color material properties, texture and normal coordinates with manual texture mapping, object transformations, camera types, scene graph hierarchies, manager classes for textures, audio, fonts, & shaders and memory management, logging system with exception handling, multi-threaded and parallel programming techniques, networking, physics engine, collision detection, particle generator, animation, game AI, terrain generation, sky boxes and sky domes, water rendering, foliage and more..., GUI's with textured font for text rendering, HUD overlays, inventories, map and macro generation, state system and state machines, and finally writing a parser to create your own scripting language to automate much of these objects to have the ability to change data values within the engine without having to recompile just by loading in the data files to populate the data objects and structures within their respective containers at application startup.
Throughout the years on and off I've been intrigued to want to learn assembly language, from their I wanted to learn about compilers, assemblers and simple operating systems, I mean their internal workings, how they are built and designed.
Time went on and then I side stepped a bit and started to get into learning hardware emulation. I focused specifically on the NES but wanted to learn hardware emulation of CPU's in general. This lead me into learning about the instruction set in which I already knew the concept and what it was as I was already familiar with Intel's x86 family to some degree, but now I had to learn the 6502 Instruction Set.
Yet by diving into this, I ended up doing more research and started to learn about the Instruction Set Architecture from an Engineering perspective. This got me into learning about how the CPU is built from the logic gates and how the logic gates are built from transistors along with other various electrical components. So I ended up learning about this from two perspectives top down and bottom up. Both methods were very effective and I think that learning from both helps to build that bridge or gap where the software meats the hardware.
From this, I had to refresh on my Boolean Algebra and I ended up learning about K-Maps, Implication Tables, State Machines both Mealy and Moore and various other things that relate Binary Logic and Arithmetic to the Physical Logical Gates and Integrated Circuits. And this brings me to the resent past where I started to work with Logisim, and started to learn HDL, VHDL, Verilog etc...
I've been learning all of this on my spare time when I could throughout the past 15 - 18 years.
Here are some of the sites and links that have guided me through out the years. Many of these are recent as many of the sites I originally learned from either no longer exist, I have lost their links and don't remember, or search engines pushed them in the far back of their searching lists...
  • Languages - C++
  • 3D Graphics Tutorials and Resource Websites
  • Youtube series and channels these cover the topics above as well as hardware, computer and electrical engineering. There are too many to list so I will list a few of them here that I find the most useful and resourceful. I won't provide the links but you can search youtube for these channels.
    • 3Blue1Brown - Advanced Mathematics
    • Bisqwit - Advanced C/C++ Programming (Application Projects) - NES Hardware Emulator
    • Jason Turner - Advanced Modern C++ programming techniques
    • javidx9 - Advanced C/C++ Programming (Application Projects) - NES Hardware Emulator / Some Assembly
    • MIT OpenCourse - College Courses in Mathematics and Computer Science
    • Bilkent Online Courses - College Courses in Computer Science and Computer Engineering (CPU Design MIPS)
    • The Cherno - Advanced C/C++ Programming Topics and Applications - Game Engine Development
    • Ben Eater - Hardware Engineering - Practical Application via Breadboards
    • Neso Academy - Hardware Engineering - Theory and Concepts
    • Socratica - Python programming
    • Simply Put - Hardware Engineering - Theory and Concepts
    • Bitwise - Advanced C/C++ Designing an Assembler via Hardware Emulation
    • Bo Qian - C++ Topics in data structures and algorithms.
    • LineByLine - Vulkan Programming
    • Joshua Shucker - Vulkan Programming
    • www.MarekKnows.com - C++, 3D Math and Game Engine Development
And these don't take into account of some of the various books I have on these topics.
-Note- Please do not vote on this as this is only a message to the reader of my own personal experience and is void of any attempts to answer or reference the original question. In the next couple of days when I have the time; I'll add a follow up answer to give my thoughts about the OP's question while providing useful links as a reference and set of resources and I'll update this answer as well to include some links here and to modify this note. It is late and I currently don't have the time to proofread and edit what I have already written. I'll do this when I can".
  • I just updated this answer or post. I was going to add the 2nd Part that will actually answer the question, however I don't have enough reputation points to do so. It's going to take me some time to build up the needed reputation points before I can add my second answer. This post is not the actual answer but I'll be using it as reference and look up table into the reasoning of my true answer. It is necessary to have some of the listed resources above to help bridge the gap between software and hardware. – Francis Cugler Dec 07 '19 at 05:15
-2
At it's core, a CPU is usually just a state machine. So you'll need to understand how logic gates and flip-flops or registers combine to making state machines.
A state machine takes inputs and the current state, runs them through boolean (and potentially arithmetic) logic, and then provides outputs and a next state. One of the inputs can be the instruction register. One of the outputs can be an enable and a selection for the source to reload the instruction register, maybe also increment or load another register acting as a program counter. With that, plus some addressable memory, you can sequence through instructions.
Once you have a way to sequence instructions, you can use logic to decode these instruction bits, plus the current state, into another bunch of control bits. Some of these control bits can act as inputs to control a bunch of logic that can do arithmetic and word-wide logic, call it an ALU. Other bits can load stuff up or select inputs for the ALU. Other bits can say where to store the results of the ALU. Or load addressing registers. Or write to memory or other outputs. Etc.
Part of designing an instruction set is just figuring out which combinations of bits, when decoded, control all the registers and state machine sequencing. This had been done and (re)optimized thousands of different ways.
There are at least 3 levels of university textbooks on this non-trivial subject.
hotpaw2
  • 7,938
  • 47
    This doesn't explain how MOV operation is coverted into binary value. This doesn't mention the instruction MOV operation is a value, its a keyword that we use, so we don't have to memorize a 16 to 32 bit binary value. – Ramhound Jan 05 '12 at 14:30
