I'm struggling to phrase this question correctly, hence the poor title.
Basically I have a simple Chrome extension that I am developing for work. It is in use at the moment and as I am using it regularly I am constantly thinking of improvements or extra features it could have.
My file structure is like this (I'm on a mac)
~/Sites/Chrome_extensions/{my employers name}/CharCounter/
CharCounter/ contains all the files needed for the Chrome extension.
Whenever I am happy with a new version of my extension I pack it in Chrome and the resulting .crx file is called CharCounter_{version number}.crx
So for example, the most recent is called CharCounter_1.3.3.crx. However, the development folder currently always has the same name. If I want to roll back and continue developing a previous version I can't.
I have decided to start using git however I'm unsure how to tackle my version control.
Should I set up my git repository in
then when I decide I am making a big enough change to the extension to warrant a new version number I duplicate the CharCounter folder and add _{new version number} to it? Thereby having several CharCounter folders each with a different version number appending to them.
or should I set it up in
~Sites/Chrome_extensions/{my employers name}/CharCounter/
and never duplicate the CharCounter folder but just make a new commit every time I make a new version?
How do you tackle version control? Does using git do away with having to keep multiple versions (current and legacy) of your code in folders called folder_version_X.Y.Z or is that still a good idea?
The best solution would indeed be tags, perhaps something that might get what you want is to (partially) implement a workflow as illustrated here.
To make it easier to work with such a workflow a git extension has also been made which can be found here
This would allow you to:
  • Switch back to a previous version if that needs some bug fixing
  • Work on multiple new features at the same time (If this ever occurs)
  • Make sure you always have a fully working branch
The later.
Create a new repository for every project. When you build a version you want to create a tag for it.
Josh K
  • 23,019
  • 65
  • 100
