23
Consider these methods:
public List<Employee> GetAllEmployees()
    using (Entities entities = new Entities())
        return entities.Employees.ToList();
public List<Job> GetAllJobs()
        return entities.Jobs.ToList();
public List<Task> GetAllTasksOfTheJob(Job job)
        return entities.Tasks.Where(t => t.JobId == job.Id).ToList();
Using block is the same and has been repeated 3 times here (of course, more than 100 times in the real application). How is it possible to implement DRY (Don't Repeat Yourself) principal for using block? Is it considered a breach of DRY principal at all?
Update: I'm not talking about what has been implemented inside the using block. What I actually mean here, is the using (Entities entities = new Entities()). This line is repeated 100 times or more.
David
  • 2,724
Saeed Neamati
  • 18,142
  • 87
  • 125
    is this C# ? The answer to your question could be language dependant – David Aug 26 '11 at 12:38
  • Yeah @David, sorry that I didn't mention my language. How it can affect the answer? – Saeed Neamati Aug 26 '11 at 12:41
  • some languages can have particular syntax that can help you factor a bit of your code. I don't know C#, but in Ruby, I think you could use blocks to factor the using part. – David Aug 26 '11 at 12:50
  • The [using statement](http://msdn.microsoft.com/en-us/library/yh598w02.aspx) actually provides C# language support to apply the DRY principle to help avoid repetitive coding while managing resource disposal with the [Dispose design pattern](http://msdn.microsoft.com/en-us/library/b1yfkh5e.aspx). That doesn't mean we can't find ways to make things DRYer! Personally, I think of DRY as a recursive process. – John Tobler Aug 26 '11 at 17:10
8 Answers8
24
One idea would be to wrap it with a function that takes a Func.
Something like this
public K UsingT<T,K>(Func<T,K> f) where T:IDisposable,new()
    using (T t = new T())
        return f(t);
Then your above code becomes
    return UsingT<Entities,List<Employee>>(e=>e.Employees.ToList());
    return UsingT<Entities,List<Job>>(e=>e.Jobs.ToList());
    return UsingT<Entities,List<Task>>(e=>e.Tasks.Where(t => t.JobId == job.Id).ToList());
I made Entities a type param too, because I'm assuming you have more than one type you're doing this with. If you're not, you could remove it and just use the type param for the return type.
To be honest though this sort of code doesn't help readability at all. In my experience the more Jr co-workers have a really tough time with it as well.
Update Some additional variations on helpers you might consider
//forget the Entities type param
public T UsingEntities<T>(Func<Entities,T> f)
    using (Entities e = new Entities())
        return f(e);
//forget the Entities type param, and return an IList
public IList<T> ListFromEntities<T>(Func<Entities,IEnumerable<T>> f)
        return f(e).ToList();
//doing the .ToList() forces the results to enumerate before `e` gets disposed.
Brook
  • 1,835
    +1 Nice solution, although it doesn't address the actual problem (not included in the original question), i.e. the many occurences of `Entities`. – back2dos Aug 26 '11 at 13:18
  • @Doc Brown: I think I beat you to it with the function name. I left the `IEnumerable` out of the function in case there were any non-`IEnumerable` properties of T that the caller wanted returned, but you're right, it would clean it up a bit. Perhaps having a helper for both Single and `IEnumerable` results would be good. That said, I still think it slows down recognition of what the code does, especially for someone who is not accustomed to using lots of generics and lambdas (eg your coworkers who are NOT on SO :) ) – Brook Aug 26 '11 at 13:18
  • +1 I think this approach is fine. And readability can be improved. For example, put the "ToList" into `WithEntities`, use `Func>` instead of `Func`, and give "WithEntities" a better name (like SelectEntities). And I don't think "Entities" needs to be a generic parameter here. – Doc Brown Aug 26 '11 at 13:20
  • @Doc Brown: I did not try it but can extension methods be generic? If so, one could change your method into an extension method of "Entities", which would enhance readability further. – Doc Brown Aug 26 '11 at 13:24
  • @Doc Brown: yes they could be extensions, but then the caller would still have to new-up and dispose of their own instance of entities, which sort of defeats the purpose in this case :) – Brook Aug 26 '11 at 13:25
  • @Brook: you are right, I missed that. From the other comments I see the OP uses Dispose here because of transactions. So as an improvement he should try to change that API - transactions should not be coupled to new/Dispose, then it would be much easier to improve the code. – Doc Brown Aug 26 '11 at 13:30
  • @Doc Brown: I agree 100%. Didn't realize `using` was being used for transaction scoping. Someone needs to integrate some DI... – Brook Aug 26 '11 at 13:33
    To make this work, the constraints would need to be `where T : IDisposable, new()`, as `using` requires `IDisposable` in order to work. – Anthony Pegram Aug 26 '11 at 13:43
    @Anthony Pegram: Fixed, thanks! (that's what I get for coding C# in a browser window) – Brook Aug 26 '11 at 13:48
23
To me this would be like worrying about foreach-ing over the same collection multiple times: it's just something that you need to do. Any attempt to abstract it further would make the code much less readable.
Ben Hughes
  • 2,009
  • Great analogy @Ben. +1 – Saeed Neamati Aug 26 '11 at 14:51
    I don't agree, sorry. Read the comments of the OP about the transaction scope and think about what you have to do when you have written 500 times those kind of code, and then notice that you will have to change the same thing 500 times. This kind of code repeating may be ok only if you have <10 of those functions. – Doc Brown Aug 26 '11 at 16:39
  • Oh, and not to forget, if you for-each the same collection more than 10 times in a very similar manner, with similar-looking code inside of your for-each, you should definitly think about some generalization. – Doc Brown Aug 26 '11 at 16:46
    To me it just looks like you are making a three liner into a oneliner... you're still repeating yourself. – Jim Wolff Nov 08 '12 at 15:22
  • It's context dependant, if the `foreach` is over a very large collection or the logic within the `foreach` loop is time consuming for example. A motto I have come to adopt: Don't obsess but always be mindful of your approach – Paul C Jan 29 '13 at 13:58
It sounds like you are confusing the "Once and Only Once" principle with the DRY principle. The DRY principle states:
Every piece of knowledge must have a single, unambiguous, authoritative representation within a system.
However the Once and Only Once principle is slightly different.
[The DRY] principle is similar to OnceAndOnlyOnce, but with a different objective. With OnceAndOnlyOnce, you are encouraged to refactor to eliminate duplicated code and functionality. With DRY, you try to identify the single, definitive source of every piece of knowledge used in your system, and then use that source to generate applicable instances of that knowledge (code, documentation, tests, etc).
The DRY principle is usually used in context of actual logic, not so much redundant using statements:
Keeping the structure of a program DRY is harder, and lower value. It's the business rules, the if statements, the math formulas, and the metadata that should appear in only one place. The WET stuff - HTML pages, redundant test data, commas and {} delimiters - are all easy to ignore, so DRYing them is less important.
Source
Phil
  • 3,660
  • 26
I fail to see the use of using here:
How about:
public List<Employee> GetAllEmployees() {
    return (new Entities()).Employees.ToList();
public List<Job> GetAllJobs() {
    return (new Entities()).Jobs.ToList();
public List<Task> GetAllTasksOfTheJob(Job job) {
    return (new Entities()).Tasks.Where(t => t.JobId == job.Id).ToList();
Or even better, as I don't think you need to create a new object every time.
private Entities entities = new Entities();//not sure C# allows for that kind of initialization, but you can do it in the constructor if needed
As for breaching DRY: DRY doesn't apply on this level. In fact no principle really does, except that of readability. Trying to apply DRY at that level is really just architectural micro-optimization, which like all micro-optimization is just bike-shedding and doesn't get any problems solved, but even risks to introduce new ones.
From my own experience, I know that if you try to reduce code redundancy at that level, you create a negative impact on code quality, by obfuscating what was really clear and simple.
Edit:
Ok. So the problem is not actually the using statement, the problem is the dependency on the object you create every time. I would suggest injecting a constructor:
private delegate Entities query();//this should be injected from the outside (upon construction for example)
    using (var entities = query()) {//AFAIK C# can infer the type here
//... and so on
back2dos
  • 29,980
  • 73
  • 114
    But @back2dos, there are many places where we use `using (CustomTransaction transaction = new CustomTransaction())` code block in our code to define the scope of a a transaction. That can't be bundled into a single object and in every place you want to use a transaction, you should write a block. Now what if you want to change the type of that transaction from `CustomTransaction` to `BuiltInTransaction` in more than 500 methods? This seems to me to be a repeating task and a breach example of DRY principal. – Saeed Neamati Aug 26 '11 at 12:29
    Having "using" here closes the data context so lazy loading is not possible outside of these methods. – Steven Striga Aug 26 '11 at 13:00
  • @Saeed: That's when you look into dependency injection. But that seems to be to be quite different from the case as stated in the question. – user Aug 26 '11 at 13:02
  • @Saeed: Post updated. – back2dos Aug 26 '11 at 13:15
  • @WeekendWarrior Is `using` (in this context) still a more unknown "convenient syntax"? Why it's so nice to use =) – Paul C Jan 29 '13 at 14:03
Not only using is duplicate code (by the way it is duplicate code and actually compares to a try..catch..finally statement) but the toList also. I would refactor your code like this:
 public List<T> GetAll(Func<Entities, IEnumerable<T>> getter) {
        return getter().ToList();
    return GetAll(e => e.Employees);
    return GetAll(e => e.Jobs);
    return GetAll(e => e.Tasks.Where(t => t.JobId == job.Id));
Cohen
  • 161
Since there is no business logic of any sort here except for the last one. Its not really DRY, in my view.
The last one doesnt have any DRY in the using block but I guess the where clause should change where ever it used.
This is a typical job for code generators. Write and cover code generator and let it generate for each type.
arunmur
  • 411
  • No @arunmur. There was a misunderstanding here. By DRY, I meant `using (Entities entities = new Entities())` block. I mean, this line of code is repeated 100 times and is getting repeated more and more. – Saeed Neamati Aug 26 '11 at 12:23
  • DRY primarily comes from the fact that you need to write test cases that many times and a bug at one place means you have to fix it at 100 places. The using(Entities ...) is too simple a code to break. It does not need to be split or put in another class. If you still insist on simplifying it. I would suggest a Yeild call back function from ruby. – arunmur Aug 26 '11 at 13:17
    @arnumur - using is not always too simple to break. I often have a good bit of logic that determines which options to use on the data context. It is very possible that the wrong connection string could be passed in. – Morgan Herlocker Aug 26 '11 at 13:28
    @ironcode - In those situations it makes sense to push it off to a function. But in these examples its pretty tough to break. Even if it does break the fix is often in the definition of the Entities class itself, which should be covered with a separate test case. – arunmur Aug 26 '11 at 14:47
  • +1 @arunmur - I agree. I usually do that myself. I write tests for that function, but it does seem a bit over the top to write a test for your using statement. – Morgan Herlocker Aug 26 '11 at 16:49
Since you're creating and destroying the same disposable object over and over, your class is itself a good candidate for implementing the IDisposable pattern.
class ThisClass : IDisposable
    protected virtual Entities Context { get; set; }
    protected virtual void Dispose( bool disposing )
        if ( disposing && Context != null )
            Context.Dispose();
    public void Dispose()
        Dispose( true );
    public ThisClass()
        Context = new Entities();
        return Context.Employees.ToList();
        return Context.Jobs.ToList();
        return Context.Tasks.Where(t => t.JobId == job.Id).ToList();
This leaves you only needing the "using" when creating an instance of your class. If you don't want the class to be responsible for disposing the objects, then you could make the methods accept the dependency as an argument:
public static List<Employee> GetAllEmployees( Entities entities )
public static List<Job> GetAllJobs( Entities entities )
public static List<Task> GetAllTasksOfTheJob( Entities entities, Job job )
Sean
  • 219
My favorite bit of uncomprendable magic!
public class Blah
  IEnumerable<T> Wrap(Func<Entities, IEnumerable<T>> act)
    using(var entities = new Entities()) { return act(entities); }
    return Wrap(e => e.Employees.ToList());
    return Wrap(e => e.Jobs.ToList());
    return Wrap(e => e.Tasks.Where(x ....).ToList());
Wrap exists only to abstract that out or whatever magic you need. I'm not sure I would recommend this all the time but it's possible to use. The "better" idea would be to use a DI container, like StructureMap, and just scope the Entities class to the request context, inject it into the controller, and then let it take care of the lifecycle without your controller needing to.
Travis
  • 1,329
  • Your type paramaters for Func,Entities> are in the wrong order. (see my answer which has basically the same thing) – Brook Aug 26 '11 at 17:33
  • Well, easy enough to correct. I never remember what the right order is. I use `Func`s enough I should. – Travis Aug 27 '11 at 01:53
