Has anyone worked with Meraki's CMX raw data feed and can help answer some questions?
I came here to ask because I have found no conversations about Meraki's CMX API elsewhere and I imagined that network engineers are still more likely to know about this service than BI teams or developers.
We have recently set up Meraki access points in a few of our retail stores to report on foot traffic. We set up the data feed to point to a SQL server database with almost live results. Our plan is to have a nightly routine to summarize the data to report on similar metrics as the Meraki dashboard. I have combed through the data we currently have and read through the documentations but notice that not everything is explained. Here are some points I am struggling with.
1. RSSI not fully explained
  • an RSSI value of 0 and 102 are disproportionaly higher than any other RSSI value. I assume that a 0 value indicates connected but I am not sure what 102 is for? Max strength or an error?
2. Documentation does not support multiple cases when there are an odd amount of pings or a small number of them
  • I have noticed instances where there may be two or three pings in a given 20 minute slot that are about 3 minutes apart. This would suggest that this device was a visitor based on Meraki's documentation but could also be read as a slow passerby, window watcher or someone sitting parking their car out front. Anyone have an idea how Meraki handles these?
  • Another case would be when there are only two pings and both are above the RSSI thresholds and greater than 5 minutes apart but less than 20 minutes. Again, this would suggest another visitor but I would argue to be a another passerby.
  • My other point of confusion is with strong single pings. I imagine if a phone has a strong ping and only when then they are a passerby but it surprises me not to see multiple pings.
3. Documentation does not explain methodology of tracking visitors that stay longer than 20 minutes
  • Are all segments broken up in 20 minute intervals then summed together to create time in store?
Let me know if you want me to add the links to the documentation I have read. Any help would be super helpful.
Dengar
  • 171
  • Did any answer help you? if so, you should accept the answer so that the question doesn't keep popping up forever, looking for an answer. Alternatively, you could post and accept your own answer. – Ron Maupin Jan 04 '21 at 18:05
So I haven't used the CMX APIs, but i can answer your first question regarding RSSI. So RSSI is a measure of signal strength. Basically the higher the number the stronger the radio signal strength. I do have a lot of experience setting up Meraki's wireless APs as well as troubleshooting Wireless issues. An RSSI value less that 40 usually means a poor signal and usually means that the client either cant connect to the network, or has intermittent data loss.
For your context, in general CMX triangulates where a client is in a wireless space by using the reported RSSI values coming from the various APs. As long as the APs are placed in the Meraki portal in the correct location on the floor map the dashboard will be able to triangulate an estimated position. I would imagine the raw data you are receiving is what the dashboard gets pre triangulation calculations.
Hopefully I helped your understand of RSSI values.
Trevor Butler
  • 311
