Recently after upgrading several MetroE circuits (L2 connectivity) from 100Mbps to 1Gbps, I noticed that large file transfers fail between some sites; however, the transfer only fails in direction. For instance, consider the following example.
From -> To
A -> B = Fail
B -> A = Success
A -> C = Success
C -> A = Success
B -> C = Success
C -> B = Success
Each site is a routed segment behind a L3 switch located at the site. The L3 switch connects to the provider's CPE media converter, which in turn connects to the provider's network via fiber. Static routing is used between L3 switches.
            *Site A*                      *Site B*
    L3 Switch <-> CPE <--- Provider ---> CPE <-> L3 Switch
                              CPE
                           L3 Switch
                            *Site C*
The provider performed end-to-end testing of the circuits from the CPEs and reported no loss. However, I see many duplicate ACKs in a packet capture on the hosts before the transfer fails.
If I remove the L3 switches from the equation, and connect two hosts directly to the CPE device at each site, the file transfer completes successfully.
    Host A <-> CPE <--- Provider ---> CPE <-> Host B
If I place hosts on either side of a L3 switch, interVLAN routing works without a hitch and the file transfer completes successfully.
    Host A1 <-> L3 Switch <-> Host A2
The issue only seems to occur when data traverses the provider between two routed segments.
    Host A <-> L3 Switch <-> CPE <--- Provider ---> CPE <-> L3 Switch <-> Host B
I have verified a number of things - interface statistics are clean (no errors), cpu and memory utilization low, speed and duplex match (client and CPE), MAC and ARP tables correct, etc.
What could be the issue?
Update 1
Packet captures from hosts A and B can found at the following URL:
https://www.dropbox.com/sh/5m2yohgxieelo59/AADed-0EWOkdmFIe0qT45_uQa
The issue originally occurred using Juniper EX3200 switches running 12.3R6.6. I subsequently downgraded the switches to 11.4R6.6, but this did not resolve the issue.
I was able to replicate the issue using Juiper EX2200 switches running 12.3R6.6 and 11.4R6.6. I was also able able to replicate issue using Dell 6224 switches running 3.3.11.2.
Currently, only the CPE (ge-0/0/0) and a single host (ge-0/0/1) is connected to a Juniper EX3200 at each site. While troubleshooting the issue, I stripped the configuration of any extraneous parameters, so the configuration is fairly basic. The configuration is essentially the same at each, but with different IP addresses. Below is a snippet.
    # show interfaces
    ge-0/0/0 {
        unit 0 {
            family ethernet-switching {
                port-mode access;
                vlan {
                    members WAN;
    ge-0/0/1 {
        unit 0 {
                port-mode access;
                vlan {
                    members LAN;
    vlan {
        unit 10 {
            description WAN;
            family inet {
                address 192.168.X.X/27;
        unit 100 {
            description LAN;
            family inet {
                targeted-broadcast;
                address 172.X.X.1/22;
    # show vlans
    WAN {
        vlan-id 10;
        l3-interface vlan.10;
    LAN {
        vlan-id 100;
        l3-interface vlan.100;
Update 2
Today I noticed that if I scp a file from the L3 switch, Juniper EX3200, at site A to L3 switch, Juniper EX3200, at site B, the scp transfer is also affected by the issue.
I find this especially interesting since the transfer is originating from the CPE facing interface on the WAN VLAN, because if I trunk a VLAN between the affected sites through the EX3200 switches, switched file transfers complete successfully between hosts at site A and B.
Paul Garrett
  • 191
    Hi Mike, Thanks for the suggestion. I know from speaking with my provider that they configure MTU in excess of 9000. I am able to pass 1472 bytes in both directions, which is what I would expect the defacto 1500 MTU. Using mturoute confirmed this. Any ping over 1472 fails with the don't fragment bit set. – Paul Garrett Jul 09 '14 at 00:44
  • Please sniff the file transfer that fails from *both sides* simultaneously, and post the results on cloudshark. We also need details about the "L3 switch" portion of the question. Things like manufacturer, model, firmware version, configuration, port numbers connected to, etc... – Mike Pennington Jul 09 '14 at 01:34
  • By the time the file transfer failed, the captures were around 19MB, which is too large for clouldshark, so I uploaded the captures to dropbox and shared the link. I updated the post to include the additional information you requested. – Paul Garrett Jul 09 '14 at 13:18
  • Please consider adding [more details](http://meta.networkengineering.stackexchange.com/questions/292/network-engineering-question-checklist) to the question – Mike Pennington Jul 11 '14 at 00:21
  • A bit late to comment I guess, but I'm glad I found this post. I'm in the process of working with the provider to hopefully fix this same issue. I've reviewed every config several times over, replaced l2/l3 devices and nothing. LBs not the issue either. I'm sure my results will be the same, "issue with the provider network". a. – Alejandro Feb 09 '16 at 00:14
  • There was an issue with the provider's network. No additional details were available. – Paul Garrett Jul 20 '14 at 01:30
  • Did any answer help you? if so, you should accept the answer so that the question doesn't keep popping up forever, looking for an answer. Alternatively, you could post and accept your own answer. – Ron Maupin Jan 03 '21 at 20:03
On the Firewall if you are using an SRX, check what your security flow sessions are set to and if it is reaching the limit.
#show security flow session summary
Benjamin Dale
  • 9,296
