If a device has a dhcp pool defined:
ip dhcp pool DATA
  network 192.0.2.0 255.255.255.0
  default-router 192.0.2.1
  domain-name test.net
But it also has a DHCP helper setup on the interface:
interface GigabitEthernet0/1
  ip address 192.0.2.1 255.255.255.0
  ip helper-address 198.51.100.10
Then what is the result? Is the DHCP addresses given from the helper? or from the local pool?
glallen
  • 362
  • I would have to lab this out to be sure, but I believe you will get an offer from both the local pool and from the DHCP server 198.51.100.10 (if it exists). If I get a chance later, I will try to run this in my lab to confirm. – YLearn Jun 13 '14 at 14:52
You would get two possible DHCPOffer's from the device's internal DHCP pool and the DHCP server defined by the helper-address, but it's up to the client to decide which DHCPOffer to accept and to then unicast a DHCPRequest to the DHCP server of choice.
Often clients choose the DHCP server with the fastest DHCPOffer. Unless your device's CPU is bogged down, I would expect typical clients to select the DHCP pool more often than not. You'd expect a little less latency in a L2 operation vs L3 which is required to get to the DHCP server via the helper-address.
generalnetworkerror
  • 7,094
  • 32
  • 65
