I am requesting a webpage running on local server port 8080 and was expecting one connection to be established between the server (port 8080) and client (random port). But one additional port is also getting created and connecting to the server with TIME_WAIT as status. So just wondering what is this time wait connection about?
Before connection to the webserver
netstat -ntap | grep 8080
tcp6       0      0 :::8080                 :::*                    LISTEN      104965/java
After connecting to the web page which returned result immediately.
tcp6       0      0 ::1:8080                ::1:53950               ESTABLISHED 104965/java
tcp6       0      0 ::1:53948               ::1:8080                TIME_WAIT   -
tcp6       0      0 ::1:53950               ::1:8080                ESTABLISHED 20656/_Postman --no
Port 53950 is the client random port to speak to server and this is understandable.
But what is the function of port 53948 with status TIME_WAIT.
After about one minute the port 53948 connection to server is closed. But the port 54950 moves to TIME_WAIT status.
tcp6       0      0 ::1:8080                ::1:53950               TIME_WAIT   -
After about few minutes - a new port (54008) is open and is in TIME_WAIT status.
tcp6       0      0 ::1:54008               ::1:8080                TIME_WAIT   -
After about 5 minutes - all of the ports are closed
Could someone explain what TIME_WAIT is about and why 2 additional ports are required.
samshers
  • 139
    Have you tried [RFC 793](https://tools.ietf.org/html/rfc793)? – Zac67 Dec 05 '20 at 14:44
  • @zac67, thx. How about the additional ports - would the RFC capture this too. I will appreciate if u can summarize in to an answer. RFC's are generally not English :-) for every one. – samshers Dec 05 '20 at 14:48
  • There is a clear diagram on page 23 that explains the different states and how to get to them. – Ron Maupin Dec 05 '20 at 16:44
  • A new socket connection uses a new ephemeral port - possibly, there's a redirect. Try your browser's network/diagnostic tools, `wget`, `curl`, or similar. Also, what you're *really* asking about is the workings of HTTP which are off-topic here as an application-layer protocol... – Zac67 Dec 05 '20 at 17:22
  • Yes, RFC's may look like an alien language, but they are perfectly clear english. I know reading is hard, and it's a long block of monospaced text, but it is very clearly documented. – Ricky Dec 05 '20 at 17:34
  • @ricky, agree with u. It just takes bit of time and patience + intel – samshers Dec 05 '20 at 17:36
  • Granted, it might take someone a while to zero in on RFC 793, but it took me a faction of a second to search for TIME WAIT ("TIME-WAIT") to highlight the text in my answer. (I'd vote to close this if "lack of research" were still a close reason) – Ricky Dec 05 '20 at 17:38
  • Does this answer your question? [What is the purpose of TIME WAIT in TCP connection tear down?](https://networkengineering.stackexchange.com/questions/19581/what-is-the-purpose-of-time-wait-in-tcp-connection-tear-down) (literally the first google result, superuser answer from 2010 is 2nd) – Ricky Dec 05 '20 at 17:39
  • I don't think this addresses the additional port issue which is also my concern @ricky – samshers Dec 05 '20 at 17:45
  • Connections are constantly being created/closed/destroyed. You're just catching them in those various states. (web traffic isn't normally a long lived, persistent socket.) As this is a localhost socket, you're seeing both ends. – Ricky Dec 05 '20 at 21:49
  • @ricky, port 53948 is my concern. What's is it's purpose. – samshers Dec 06 '20 at 03:06
  • Did any answer help you? If so, you should accept the answer so that the question doesn't keep popping up forever, looking for an answer. Alternatively, you can post and accept your own answer. – Ron Maupin Dec 16 '20 at 23:41
TIME-WAIT - represents waiting for enough time to pass to be sure
the remote TCP received the acknowledgment of its connection
termination request.
[RFC 792, p.22]
The purpose is to wait long enough for any outstanding traffic to be processed before potential reuse of the port.
Ricky
  • 31,438
  • 43
  • 84
  • I would expect tcp to be smart enough to figure out the last packet in fraction of seconds, is not it simple, the last packet would say its the last packet. In my example the last packet definitely arrived and still the `TIME_WAIT` state was held for few minutes. – samshers Dec 06 '20 at 03:25
