13
Multicasting seems provide an efficient method of routing networking traffic from a source to multiple end users, especially at this moment in time with teleconferencing, streaming media, online collaboration tools in high use. Looking into it, it appears to be seldom used for such applications, why is this?
d1n037
  • 133
  • Comments are not for extended discussion; this conversation has been [moved to chat](https://chat.stackexchange.com/rooms/136816/discussion-on-question-by-jackaroo-dave-why-isnt-multicasting-more-popular). – Ron Maupin Jun 05 '22 at 04:31
Because multicast is one source to many receivers, and thus two way communications (and anything using TCP connections) won't work. That makes it unfit to use for teleconferencing, online collaboration and many more applications.
Streaming media would work, but many people like to be able to pause the stream for example, and that wouldn't be possible with multicast.
To add to that, multicast is quite complex to implement, especially between networks. It is used however, but mostly only within networks. Many consumer networks I know use multicast to provide IPTV with a fallback to regular unicast if functions like time shifting are activated.
Teun Vink
  • 16,953
  • 44
  • 70
    Just to add: multicast has *no security mechanism*. Outside of a controlled network, it could easily be used for DoS attacks - amplifying a low-bandwidth data stream to an extreme total bandwidth that overloads links or even the whole network. – Zac67 Sep 03 '20 at 10:18
    It also comes down to setting up and maintaining multicast isn't trivial. Many engineers have next to no experience with it. IPv6 aside, I've only seen multicast routing in the enterprise once - decades ago, it was for video conferencing, and yes, it was easily broken. (today, the most common scenario I *read* about is music-on-hold, and ntp.) – Ricky Sep 03 '20 at 14:33
    pausing a stream can still work if you use large buffers on the client side (maybe disk, or just RAM). Or if you just multicast to people watching live (or with a small buffer behind), with other users falling back to personal unicast if they fall farther behind than they're willing to buffer. If most users are watching live, that can still save a lot of core network bandwidth for some widely-watched streams during their initial broadcast. (Although the biggest streams probably mirror to distributed CDN endpoints, reducing backbone traffic anyway.) All this *if* multicast were supported... – Peter Cordes Sep 04 '20 at 10:10
  • I don't know if it is unreliable or I'm just incompetent, but I was once using multicast for service discovery and I had constant issues with Windows listening only on a wrong network device and/or other problems that somehow killed the multicast subscription. – AndreKR Sep 04 '20 at 10:42
  • Probably the vast majority of streaming traffic is on-demand (e.g. Netflix), not live streaming. The surge in zoom meetings during the pandemic has obviously increased the live streaming share, but I'll bet on demand still far outpaces it (I haven't been able to find actual statistics). – Barmar Sep 04 '20 at 16:25
  • @Barmar Think about services like Twitch and YouTubeTV/Sling/etc, though. – Dai Sep 06 '20 at 03:42
13
Multicast is one of those ideas that sounds nice in principle but doesn't really scale to a network like the internet. It requires routers to keep track of a bunch of extra state, has significant potential for denial of service attacks and also has significant problems from a billing perspective. The result of this is that ISPs generally said no to multicast.
Multicast can be a useful tool within networks you control. It gets used for reimaging PCs in enterprise/academic scenarios and for distributing TV services by IP based "triple play" providers but it's of no use if you want to make a service that operates on the open internet because the providers don't support it.
Peter Green
  • 12,935
    It was designed in the before times, in the long-long ago, when nobody needed to care about security, because the internet consisted of few people, and they all behaved. That is *definitely* not true today! – Ricky Sep 03 '20 at 19:33
Multicast was once a popular choice for applications which had the following characteristics: a sequence of events with a similar structure but different values, each new value replacing all earlier values. There are no resources to buffer, or even notify the publisher if an event if was lost, you would just wait for the next event.
Data recorders for physical events and stock market tickers work on this principle. In financial markets most multicast systems now include a parallel request-response system for recovery of lost events.
patsw
