I'll start by pointig out that networking issues have always left me scratching my head. There is something about routing especially that I just haven't had that "Oh I get it" moment yet, so it's likely this is a very basic misconfiguration.
I am trying to set up a Cisco ASA 5505 to be connected with a public IP address on one interface, and to have the second interface connect to our internal network. Right now our internal network is on 192.168.1.0/24, and the public IP we have from the ISP is in the 125.x.x.x range.
I have set up 3 interfaces on the ASA,
Inside
IP: 192.168.1.3 Mask: 255.255.255.0 Ports 1-6 Sec Level 100
Outside
IP: 125.x.x.x Mask: 255.0.0.0 Port 0 Sec Level 0
Management
IP: 10.0.0.1 Mask: 255.255.255.0 Port 7 Restricted to management Restrict flow to Outside (had to do this for licensing reasons)
I have an access rule on the firewall that allows IP traffic from any source on the inside network to any less secure network (there is one for both IPv4 and 6).
With the internet-facing router connected to port 0, I connect a computer to port 1 with IP 192.168.1.20
, Mask 255.255.255.0
and gateway 192.168.1.3
. Using this PC I can ping 192.168.1.3
but no further - I cannot ping the public IP address or 8.8.8.8
If I connect the same PC directly to the router and assign it the public IP address directly I can access the internet no problem. I believe that the issue here is that I need to add some static routes to show the path from inside<->outside, but I just do not grok them well enough to know how to structure them. Any help or suggestions would be very much appreciated.
Edit: See below the running config, with some redactions.
: Saved
ASA Version 8.2(1)
hostname AUS-FW-01
domain-name =============.com.au
enable password ============= encrypted
passwd ============= encrypted
names
name 10.61.76.0 CNC-network
name 10.61.73.0 LAN-network
name 192.168.1.0 LEGACY-network
name 10.61.75.0 RANDD-network
name 10.61.74.0 WIRELESS-network
name 10.61.73.5 InternalGateway
name 192.168.1.200 DCServer
name 192.168.1.214 MUVS-TP description Trueform Print Server
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.3 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 125.x.x.10 255.255.255.252
interface Vlan12
no forward interface Vlan2
nameif Management
security-level 0
ip address 10.0.0.1 255.255.255.0
management-only
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 12
ftp mode passive
clock timezone EST 10
dns domain-lookup outside
dns server-group DefaultDNS
name-server =============
same-security-traffic permit intra-interface
access-list outside_access_in remark Email access
access-list outside_access_in extended permit tcp any LEGACY-network 255.255.255.0 eq smtp
access-list outside_access_in remark ActiveSync Email Access
access-list outside_access_in extended permit tcp any LEGACY-network 255.255.255.0 eq https
access-list outside_access_in remark Pronto Trueform Printing
access-list outside_access_in extended permit tcp any LEGACY-network 255.255.255.0 eq lpd
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu Management 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface smtp DCServer smtp netmask 255.255.255.255
static (inside,outside) tcp interface https DCServer https netmask 255.255.255.255
static (inside,outside) tcp interface lpd MUVS-TP lpd netmask 255.255.255.255
access-group outside_access_in in interface outside
route inside LAN-network 255.255.255.0 10.61.79.2 1
route inside LEGACY-network 255.255.255.0 InternalGateway 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.61.79.0 255.255.255.0 inside
http LAN-network 255.255.255.0 inside
http 10.0.0.0 255.255.255.0 Management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn username ============= password ============= store-local
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:=============
: end
asdm location LAN-network 255.255.255.0 inside
asdm location WIRELESS-network 255.255.255.0 inside
asdm location RANDD-network 255.255.255.0 inside
asdm location CNC-network 255.255.255.0 inside
asdm location LEGACY-network 255.255.255.0 inside
asdm location InternalGateway 255.255.255.255 inside
asdm location DCServer 255.255.255.255 inside
asdm location MUVS-TP 255.255.255.255 inside
PS: I wasn't sure if this was a better fit here or on SF. I have no problem with it being moved.
