14
Why is it that when I perform a show interface command I see that Last input always shows never?
FastEthernet1/31 is up, line protocol is up (connected)
  Hardware is C6k 100Mb 802.3, address is 000d.bd5a.e94e (bia 000d.bd5a.e94e)
  Description: Server
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation ARPA, loopback not set
  Full-duplex, 100Mb/s
  input flow-control is off, output flow-control is unsupported
  ARP type: ARPA, ARP Timeout 04:00:00
  **Last input never**, output 00:03:19, output hang never
  Last clearing of "show interface" counters 1y3w
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 4 packets/sec
  5 minute output rate 13000 bits/sec, 20 packets/sec
     148174387 packets input, 16331478383 bytes, 0 no buffer
     Received 465 broadcasts (0 multicast)
     0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     0 input packets with dribble condition detected
     798328682 packets output, 102549789248 bytes, 0 underruns
     0 output errors, 0 collisions, 0 interface resets
     0 babbles, 0 late collision, 0 deferred
     0 lost carrier, 0 no carrier, 0 PAUSE output
     0 output buffer failures, 0 output buffers swapped out
As you can see, when I run the command a couple minutes later the other counters have incremented.
  Last input never, output 00:01:39, output hang never
  5 minute output rate 14000 bits/sec, 20 packets/sec
     148176042 packets input, 16331609502 bytes, 0 no buffer
     798337129 packets output, 102550523914 bytes, 0 underruns
Aaron
  • 1,637
Mike Marotta
  • 2,057
  • 26
There are several interface counters that don't work as well as they used to. Sometimes this is because the chassis/router has a 'fast' switching mode (CEF, or something else), and that particular 'bucket' never gets hit. Another reason might be that that particular counter only works in L3 mode instead of L2 mode. This kind of stuff is quite common, unfortunately on cisco products, particularly on the 6500 which has an enormous amount of legacy code/architecture weighing it down.
Aaron
  • 1,637
Most switch traffic is now processed entirely in hardware (i.e. the ASICs) as this is the fastest/best way to do so. The last input and output fields are only updated when there is traffic that is software or process switched.
On some platforms there are features that you can enable that will cause traffic to be processed in software, which will decrease switch performance. These fields are nice to still have around so you can see when traffic is not being hardware switched.
YLearn
  • 27,141
  • 59
  • 128
