13
Suppose you have two NICs with the same MAC address, but not necessarily the same IP address. What is the least possible separation (in terms of number of switches, routers, different IP subnets etc.) needed that would still allow traffic between the NICs?
LapplandsCohan
  • 233
  • Is that really common enough to be a problem, or are you asking a hypothetical question? – Mike Waters Jan 31 '20 at 19:18
    Welcome to Network Engineering! If this question is not hypothetical, you may have an [XY Problem](https://meta.stackexchange.com/questions/66377/what-is-the-xy-problem). One can normally [change the MAC reported by network cards](https://en.wikibooks.org/wiki/Changing_Your_MAC_Address), or in the case of a bonded setup, configure the upstream network device to handle the configuration. – ti7 Jan 31 '20 at 19:38
    The question stems from that I on one ESXi server need to be able to run two virtual machines that needs to have the same MAC address and still be able to communicate with each other. (The actual software on the VMs is hardcoded to only load if the VM has a specific MAC address.) I already found answers how to solve it on ESXi (using a 3rd VM with several NICs as router and connect the other VMs to that one), but I am also interested in the theoretical solution to a hypothetical problem, hence my question here. – LapplandsCohan Jan 31 '20 at 21:17
    If the software is just checking that a VM has a specific MAC and not, say, refusing to communicate over only an interface with that MAC, you could probably add a second virtual NIC, connected to nothing, and assign the magic MAC to that. (Though I can also imagine that the software might look only at the first NIC, so maybe reverse them.) – Reid Rankin Feb 01 '20 at 01:07
  • @ReidRankin: Now we are back at solutions to my actual problem, but I want to understand the theoretical parts behind it. – LapplandsCohan Feb 02 '20 at 01:01
  • @LapplandsCohan Totally respect that. Still, wanted to mention it just in case you were looking for a quick-fix as well. – Reid Rankin Feb 02 '20 at 01:04
    @LapplandsCohan If the software has such strict requirements, you may not be allowed to do this. – Thorbjørn Ravn Andersen Feb 02 '20 at 10:32
    I'm familiar with lots of software that uses the MAC address for licensing purposes, but does not require that traffic flow over a specific interface. – Randall Feb 02 '20 at 14:25
You can't have that within the same link-layer segment. Identical MAC addresses will disable reliable switching/bridging.
The NICs need to be in different L2 segments - at least one router in between. Also, they would have to be in different IP subnets to enable normal routing. For a router to see identical MAC addresses in different subnets is not normally a problem.
The number of switches in between doesn't matter - each broadcast is propagated throughout the broadcast domain (=L2 segment), so each NIC messes up the source-address table for the other on every participating switch. Of course, both NICs could be in different VLANs since those represent separate segments.
[edit] As has been pointed out by Jörg, the "router" above can very well be an L3 switch that is used as a router. Note that the switching/bridging function of an L3 switch can not cope with identical MACs within the same segment either.
[edit2] Also, (see comments, I thought that was pretty obvious) having multiple NICs with identical MACs is a bad thing. Generally, MACs are supposed to be unique (at least within a site's scope) in order to avoid problems that may be hard to diagnose.
If need be (thx Ron!) you need to separate those NICs into their own broadcast domains/L2 segments/ESXi port groups and use a router to enable IP communication between them. Make sure your router or L3 switch is fine with duplicate MACs across its L3 interfaces. Do not replace the router without prior testing. Running that router inside a VM might have its own tribulations.
Disclaimer: I have no experience running something like that in an ESXi environment - since a vSwitch works somewhat differently from a hardware switch - it has considerably more insight - there may be unexpected problems (unless you distribute the VMs to different hosts). In any case, duplicate MACs will likely require the "MAC address changes" option on the port group. They might even require running separate vSwitches in addition to using separate port groups.
Zac67
  • 81,287
  • 67
  • 131
  • It may not be 100% clear from your last sentence: while a switch won't work, and there has to be a router in between, that router could of course be the same device as a switch. The sort of switches that are on-topic on this site almost always have at last some L3 capabilities, (Which technically makes them no longer switches, or rather switches plus routers in one device.) – Jörg W Mittag Jan 31 '20 at 12:29
  • @JörgWMittag I was referring to the network function, trying not to complicate the answer too much. By function, an L3 switch in a router role *is* a router. – Zac67 Jan 31 '20 at 12:32
  • Regarding "both NICs could be in different VLANs". In a network where the switches assign VLANs to ports on the basis of ethernet addresses, this will go wrong, as they are both in the same "VLAN-selection-set" or whatever you might want to call it. – jonathanjo Jan 31 '20 at 12:33
  • @jonathanjo Of course, using more advanced functions than simple bridging and routing opens up a jar of potential problems with non-unique MACs. I don't think the OP was thinking of those though. – Zac67 Jan 31 '20 at 12:36
  • @Zac67 I'm sure you're right! You might care to add a little to your answer about how there aren't supposed to be duplicate MAC addresses on most equipment, unless you're using locally-administered addresses. Does anybody actually do that? You see it in hobbyist equipment of course, and I suspect some low-grade ehter equpiment doesn't use registered addressing. – jonathanjo Jan 31 '20 at 12:55
    The OP was referring to [this question](https://serverfault.com/q/1001146/324849) on [sf]. – Ron Maupin Jan 31 '20 at 16:00
  • @jonathanjo, setting the MAC addresses on NICs was pretty common on token ring networks. I also saw some of that carry over to ethernet with old-school network administrators. I could not ever understand the effort involved. – Ron Maupin Jan 31 '20 at 16:03
  • @RonMaupin very interesting. I can't understand the effort either; in fact, using the ethernet address as a serial number/fingerprint is really useful for tracking purposes. – jonathanjo Jan 31 '20 at 16:36
  • @jonathanjo, remember that was often before IP really took off in companies, and you had things like SDLC, IPX, etc. Also, the LANs were usually much smaller than what you see today. – Ron Maupin Jan 31 '20 at 16:51
    Yes, on Server Fault I asked for a specific solution in ESXi, but I was also very curious to the theoretical answer to a general situation, a question for which this forum seemed more appropriate. – LapplandsCohan Jan 31 '20 at 21:29
  • MACs are supposed to be globally unique when it's a universal address, which is most of the time. https://en.wikipedia.org/wiki/MAC_address#Universal_vs._local – studog Jan 31 '20 at 23:31
  • The Cisco 6500 SUP-2T (experience about 5 years ago) allocates the same MAC address to all its virtual interfaces (unlike Cisco workgroup switches). This works fine until you cable two VLANs back-to-back (I was waiting for delivery of a firewall ...). – grahamj42 Feb 01 '20 at 10:33
    @studog, that is a myth. The OUI is what must be globally unique. Beyuond that, the IEEE lets the OUI owner assign the rest of the MAC address as it sees fit. Many companies that own OUIs will repeat MAC addresses in different parts of the world. For example, Wi-Fi requirements are different in different areas. You cannot use a US Wi-Fi adapter in Europe, or vice versa, so a manufacturer can reuse MAC addresses between those areas, and that saves it from having to buy more OUIs. – Ron Maupin Feb 01 '20 at 14:56
  • @RonMaupin IEEE guidance seems pretty clear to me: "With some exceptions, particularly with regard to protocol identifiers, each EUI is intended to be globally unique and bound to a hardware device instance or other object that requires unique identification." Your example would be one of the exceptions I suppose. – studog Feb 03 '20 at 13:32
  • @studog, there are many examples of repeated use of MAC addresses. HP has reused old Compaq MAC addresses from 10 or 10/100 Mbps ethernet interfaces that wers sold in the 1990s in one part of the world on 1 Gbps interfaces sold more recently in a different part of the world. Manufacturers that sold token ring and FDDI that were acquired have had those MAC addresses reused on ethernet and/or Wi-Fi. The IEEE has no actual requirements for the OUI owners to never reuse MAC addresses, and it really does happen all the time. – Ron Maupin Feb 03 '20 at 14:51
  • @RonMaupin I'm not arguing whether it happens or not. The IEEE really does say it is intended to be unique. Forgot the link last comment: https://standards.ieee.org/content/dam/ieee-standards/standards/web/documents/tutorials/eui.pdf – studog Feb 03 '20 at 15:45
Zac has put a great answer together. But I wanted to add a simplified answer along the same lines.
Identical MAC, not within a single layer 2/broadcast domain.
There are probably a lot of devices out there with the same MAC address, but because the minimum required separation is at this very low level it doesn't cause issues.
Another consideration to keep in mind, there might be some systems that rely on MAC address for identification/tracking, and for this reason I'd hope to never have this issue within a single area of a corporate network.
skrap3e
  • 443
Zero separation is possible. TLDR Yes you can do it in plain ehternet where there is no any restriction applied.
If communication between VMs is based on IP protocol there will be no issue. Even if it plain L2 protocol there is no issue also if protocol can differentiate communication node not only by MAC address(for example IP protocol).
Because ARP (address resolution protocol) is based not only on Layer 2 address scheme(MAC address) but additionally on IP address scheme. That is why in local network we can have MIM attack (man in the middle attack) then someboby is mocking not only yours MAC address but IP address also and can intercept all on you local traffic. This type of attack can be mitigate by security policy on ethernet switches say by applying some type of policy on eth-port where there can be only one(Hello Duncan McLeod %) ) unique MAC address per ethernet port possible.
    Nice theory - but only if you've got no switching in between. – Zac67 Feb 01 '20 at 23:17
  • There are NICs that will not send a frame with the same source and destination address, and there are NICs that will simply loop back a frame with the destination address that is the same as the source NIC. – Ron Maupin Feb 01 '20 at 23:42
  • Even if you do have switch between you can have two nics with identical MAC. Only port policy can prevent two identical MAC on different ports . If you do not have one, nothing is prevent it. https://serverfault.com/questions/462178/duplicate-mac-address-on-the-same-lan-possible – Alex Ignatov Feb 03 '20 at 01:14
  • "_Only port policy can prevent two identical MAC on different ports ._" A switch MAC address table has only one entry for each MAC address. Having two hosts with the same MAC address causes flapping, and many switches have a problem with that. – Ron Maupin Feb 03 '20 at 19:13
