We have several embedded pcs on farms in the UK and US. Among other connections these talk to our server sending a small packet of data (100 - 600 bytes) every 20 seconds.
Over DSL this is fine. Over satellite connections, we lose most of the packets.
We're using TCP, and tcpdump on the client shows the sequence:
-> syn                   (send)
<- syn ack               (receive)
-> ack
-> push ack
<- ack                   (spoofed?)
-> fin ack
<- ack                   (spoofed?)
<- fin ack
-> ack
The server, however, sees:
<- syn                   (receive)
-> syn ack               (send)
<- ack
<- fin ack
-> fin ack
<- ack
I think I'm correct in saying the extra acks the client receives are spoofed by the satellite end point in order to speed up the connection
We have ~100 DSL sites and 3 satellites. The DSL are all fine, and the satellites are all broken in the same way.
What's happening to the data? It gets through maybe one time in 20.
edit I can ping the server from the client in question. The clients all have a reverse ssh tunnel to the server which is working fine. We can ssh in, and also download data. It's just this upload that has problems.
DSL connection - successful
root@mini2440:~ tcpdump port 1080 -vv
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
14:55:20.126968 IP (tos 0x0, ttl 64, id 29228, offset 0, flags [DF], proto TCP (6), length 60)
    client > server: Flags [S], cksum 0x1877 (incorrect -> 0x5ebd), seq 21640692, win 14600, options [mss 1460,sackOK,TS val 1485260760 ecr 0,nop,wscale 1], length 0
14:55:20.194124 IP (tos 0x0, ttl 51, id 0, offset 0, flags [DF], proto TCP (6), length 60)
    server > client: Flags [S.], cksum 0xf10a (correct), seq 4087778233, ack 21640693, win 14480, options [mss 1452,sackOK,TS val 43969567 ecr 1485260760,nop,wscale 4], length 0
14:55:20.194465 IP (tos 0x0, ttl 64, id 29229, offset 0, flags [DF], proto TCP (6), length 52)
    client > server: Flags [.], cksum 0x186f (incorrect -> 0x3bcb), seq 1, ack 1, win 7300, options [nop,nop,TS val 1485260773 ecr 43969567], length 0
14:55:20.197225 IP (tos 0x0, ttl 64, id 29230, offset 0, flags [DF], proto TCP (6), length 403)
    client > server: Flags [P.], cksum 0x39c5 (correct), seq 1:352, ack 1, win 7300, options [nop,nop,TS val 1485260774 ecr 43969567], length 351
14:55:20.197564 IP (tos 0x0, ttl 64, id 29231, offset 0, flags [DF], proto TCP (6), length 52)
    client > server: Flags [F.], cksum 0x186f (incorrect -> 0x3a6a), seq 352, ack 1, win 7300, options [nop,nop,TS val 1485260774 ecr 43969567], length 0
14:55:20.267543 IP (tos 0x0, ttl 52, id 26507, offset 0, flags [DF], proto TCP (6), length 52)
    server > client: Flags [.], cksum 0x530f (correct), seq 1, ack 352, win 972, options [nop,nop,TS val 43969587 ecr 1485260774], length 0
14:55:20.271456 IP (tos 0x0, ttl 52, id 26508, offset 0, flags [DF], proto TCP (6), length 52)
    server > client: Flags [F.], cksum 0x530d (correct), seq 1, ack 353, win 972, options [nop,nop,TS val 43969587 ecr 1485260774], length 0
14:55:20.271771 IP (tos 0x0, ttl 64, id 29232, offset 0, flags [DF], proto TCP (6), length 52)
    client > server: Flags [.], cksum 0x186f (incorrect -> 0x3a46), seq 353, ack 2, win 7300, options [nop,nop,TS val 1485260789 ecr 43969587], length 0
8 packets captured
Satellite connection - unsuccessful
15:14:50.027783 IP (tos 0x0, ttl 64, id 13618, offset 0, flags [DF], proto TCP (6), length 60)
    client > server: Flags [S], cksum 0x1884 (incorrect -> 0x1b8a), seq 2040495825, win 14600, options [mss 1460,sackOK,TS val 16534499 ecr 0,nop,wscale 1], length 0
15:14:50.029731 IP (tos 0x0, ttl 63, id 0, offset 0, flags [DF], proto TCP (6), length 60)
    server > client: Flags [S.], cksum 0x3451 (correct), seq 51102354, ack 2040495826, win 5792, options [mss 1460,sackOK,TS val 67452903 ecr 16534499,nop,wscale 7], length 0
15:14:50.034910 IP (tos 0x0, ttl 64, id 13619, offset 0, flags [DF], proto TCP (6), length 52)
    client > server: Flags [.], cksum 0x187c (incorrect -> 0x5d38), seq 1, ack 1, win 7300, options [nop,nop,TS val 16534500 ecr 67452903], length 0
15:14:50.036082 IP (tos 0x0, ttl 64, id 13620, offset 0, flags [DF], proto TCP (6), length 173)
    client > server: Flags [P.], cksum 0x8d87 (correct), seq 1:122, ack 1, win 7300, options [nop,nop,TS val 16534500 ecr 67452903], length 121
15:14:50.036351 IP (tos 0x0, ttl 64, id 13621, offset 0, flags [DF], proto TCP (6), length 52)
    client > server: Flags [F.], cksum 0x187c (incorrect -> 0x5cbe), seq 122, ack 1, win 7300, options [nop,nop,TS val 16534500 ecr 67452903], length 0
15:14:50.037547 IP (tos 0x0, ttl 63, id 64893, offset 0, flags [DF], proto TCP (6), length 52)
    server > client: Flags [.], cksum 0x790d (correct), seq 1, ack 122, win 46, options [nop,nop,TS val 67452911 ecr 16534500], length 0
15:14:50.076479 IP (tos 0x0, ttl 63, id 64894, offset 0, flags [DF], proto TCP (6), length 52)
    server > client: Flags [.], cksum 0x78e4 (correct), seq 1, ack 123, win 46, options [nop,nop,TS val 67452951 ecr 16534500], length 0
15:14:51.076273 IP (tos 0x0, ttl 63, id 64895, offset 0, flags [DF], proto TCP (6), length 52)
    server > client: Flags [F.], cksum 0x74e4 (correct), seq 1, ack 123, win 46, options [nop,nop,TS val 67453974 ecr 16534500], length 0
15:14:51.076482 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 52)
    client > server: Flags [.], cksum 0x57be (correct), seq 123, ack 2, win 7300, options [nop,nop,TS val 16534708 ecr 67453974], length 0
9 packets captured
There was no ICMP traffic in either case.
Johan
  • 183
  • Is any of the traffic reaching the servers? i.e. pinging them? – GerryEgan Feb 13 '14 at 12:09
  • Yes, I can ping the server from the client in question. The clients all have a reverse ssh tunnel to the server, and this is working fine. We can ssh in, and also download data. It's just this upload that doesn't work. – Johan Feb 13 '14 at 12:54
  • It would help if we had two comparison pcaps from the same machine: A) across DSL and B) across satellite. The information in the question isn't sufficient to assist in diagnosis. Please capture both TCP and ICMP... give us a dropbox, google drive or other "cloud" link to the pcaps if possible – Mike Pennington Feb 13 '14 at 14:16
  • We don't have any machines with both DSL and satellite. I can run tcpdump on two separate machines, one with DSL and the other satellite, both with the same software and talking to the same server. – Johan Feb 13 '14 at 14:40
  • Is that the data you needed? I just saw your dropbox suggestion, so I'm guessing you expected more data... – Johan Feb 13 '14 at 15:26
  • native pcaps on dropbox are the perfect world... just be sure that when you give us the pcaps that they really illustrate the problem when it happens – Mike Pennington Feb 13 '14 at 15:52
  • How's this: https://www.dropbox.com/sh/himjkaayg3vaujv/_pEHgIwu4B – Johan Feb 13 '14 at 16:39
  • On the surface, that looks fine... if nobody else jumps in before me, I'll take a look when I have time after work – Mike Pennington Feb 13 '14 at 19:29
The timestamps on your satellite pcap entries do imply tcp acknowledgement spoofing. Most devices that perform acknowledgement spoofing can be configured to bypass acceleration based on some combination of source/ destination IP address, source/ destination port; standard ACL concepts. This could be a feature that is configurable in the satellite modems (or nearby device) at your hub and spoke locaitons.
Wide area optimization or acceleration solutions are also common in such network architectures. Again, these solutions should provide a method to bypass your traffic that's having problems. Devices such as Riverbed Steelhead, Cisco WAAS, Bluecoat, and Citrix Cloudbridge/ Wanscaler are examples of technologies that might impact your application. A discussion with your provider (or network guy) should reveal if such technologies are in use on your network; if so, request bypassing your affected traffic in these devices to see if behavior changes. Best of luck.
packetloss
  • 196
  • This is a good theory; WAN acceleration is a common tactic in trying to thwart high-latency (satellite) connections. – Ryan Foley Feb 14 '14 at 22:01
  • Given that the client was getting acks the server wasn't sending, I assumed it had to be spoofing. Would this cause packets to be dropped, however? – Johan Feb 18 '14 at 16:57
  • Johan, this would be very hard to troubleshoot further without 1) tcp header information (sequence numbers are important here) and 2) the equipment string, including satellite modems, Performance Enhancing Proxies and/or WAN optimization gear. Just a thought here, given ssh does not appear to be affected, have you given any thought to tunneling your custom application data through an ssh tunnel? – packetloss Feb 18 '14 at 23:31
